master cyclinder push rod length
Discussion in '1st Gen. Tacomas (1995-2004)' started by Danno 1948, May 27, 2017.
  1. Apr 6, 2018 at 5:09 PM
    Stealth97
    Stealth97 Well-Known Member
    2018 Barcelona Red DCSB SR V6 4x4
    Old thread, I know but just came across it... I have an 04, front brakes dragging and inconsistent pedal... serviced calipers and replaced booster, Same issue, brakes still drag and stick. Will unplug abs module and report back....
  2. Jan 12, 2019 at 11:57 PM
    pontoon
    pontoon Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    Did disabling ABS fix your issue?
  3. Jan 13, 2019 at 1:11 AM
    Stealth97
    No, setting proper booster rod length resolved it.
    cruiserguy likes this.
  4. Jan 9, 2020 at 7:28 PM
    Carseatcop
    Carseatcop New Member
    Brad
    2006 Blue Tacoma
    Total Chaos Long travel front with King Coilovers. Fiberglass front fenders and bed sides.
    Hey guys new to this forum and my first post. A lot of great advise so far. Not sure if I missed it somewhere in the thread but how do you adjust the booster rod length? I have been dealing with front brake lock up issues on my sons 06 taco. We did a Wilwood caliper/rotor swap. After had several issues with brake lockup. Decided to replace the MC just to make sure that wasn’t the issue. When I took the old MC off I measured the distance from the surface of the booster to the tip of the pushrod, and from the mounting surface of the MC to the depth of the contact surface within the MC where the push rod mates up. It appeared to be about 2mm too long. Not sure why but the new master cylinder had more clearance by measurement and had about a 2mm gap. I’m assuming that was the issue. Been driving it now for 4 days now and no issues yet, and the new brakes stop the 35’s perfectly. But if anything comes up I’d like to know how to make adjustments.
  5. Jan 10, 2020 at 4:21 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Not sure for the second gen Tacoma you're working on. You're in the first gen section. But in previous page post number 8 has a pdf that might be what you're looking for
  6. Jan 10, 2020 at 6:13 AM
    Stealth97
    You'll need to pull the master and the easiest way to measure the pushrod length is a tool like this - it worked for me.
    https://www.amazon.com/Power-Brake-Booster-Adjustment-Tool/dp/B079QGXY55
    I dumped $600 into the brakes on this truck then traded it after owning less than a year :crazy:
  7. Jan 12, 2020 at 8:58 PM
    Carseatcop
    Brad
    2006 Blue Tacoma
    Thanks for the reply. I was able to take the actual measurement, but not sure how to make an adjustment to the push rod if needed. How do you lengthen or shorten it?
  8. Jan 15, 2020 at 4:33 PM
    Stealth97
    Carseatcop[QUOTED] likes this.
  9. Jan 15, 2020 at 6:40 PM
    Carseatcop
    Brad
    2006 Blue Tacoma
    Thanks for the help!
