Master Key Replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maineman, Oct 28, 2009.
  1. Oct 28, 2009 at 7:42 AM
    Maineman
    Maineman [OP] Member
    Maine, but working in CA
    06 PreRunner XCab
    Hi Everyone,
    I just bought a used 06 PreRunner. It came with only one key. I guess it is a chipped key because it can start the engine (although the handle part of it is much thinner than my other Tacoma chipped keys).
    But I want to buy a key that will remotely operate my power door locks. Do I have to get this from a dealer? Any idea for cost?
    Thanks for your help.
  2. Oct 28, 2009 at 9:34 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    just did this yesterday. went to an independent toyo guy. great dude. he still wrestled $271 from my clutches. i got a new factory key, and remote fob.
    dealership wanted $410ish. but their method is cleaner...apparently they program the chip to match the car. my guy, got the truck to reconize two chips. make sense?
  3. Oct 28, 2009 at 5:22 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    OEM key blanks can be purchsed on ebay for about $15.00. You can also get a remote for less than $20.00 on ebay as well.
    The remote will usually came with instructions so you can program it yourself.
    The key will need to be cut and programmed for about $40.00.
    This is all hoping that you have the keyless entry option in your truck already.
    Marc M
  4. Oct 28, 2009 at 8:47 PM
    Maineman
    06 PreRunner XCab
    "This is all hoping that you have the keyless entry option in your truck already. "
    Oh, I hadn't considered that. Even though this truck has power windows and locks, there's a chance that it doesn't have the keyless entry option? Hmm. How can I check this?
  5. Nov 1, 2009 at 9:13 PM
    Maineman
    06 PreRunner XCab
    Thanks guys.
    Anybody know how I can determine if my truck has the "keyless entry option"?
  6. Nov 1, 2009 at 9:36 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Isn't the flashing light on the center console part of the keyless entry system?
  7. Nov 2, 2009 at 6:15 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    I had a spare master key made. (no xtra fob) cost 49.00 from toyota parts, then another 59.00 to fuckn program! Made me feel better when my friends wife's honda pilot cost him 260.00 for same thing:D
  8. Nov 2, 2009 at 4:24 PM
    spp
    spp OC, Kalifornia
    OC California
    That is the engine immobilizer that requires a chip in your key. My 2007 5-lugger didn't have that but the 2010 PreRunner does. Saves on ins a little but keys are expensive amd have to be programmed in.
  9. Mar 29, 2010 at 9:39 AM
    BIG EYE
    BIG EYE Well-Known Member
    David
    San Diego, CA
    Sold
    Sorry to bump an old post, but it shows I am using the search :D
    Does the new key need to be programmed and cut by the dealer, or is there other places that can do it?
  10. Mar 29, 2010 at 10:13 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    All of this brings to mind the black/grey key thing... we know the "master" key is black, but what the hell is the gray key? The manual calls it a "valet" key. It used to be that the valet key would do everything except unlock a glove box.
    My valet keys will do everything. They start the truck, they open the doors. Even the dealer can't tell me the difference.
    You guys know?
  11. Mar 29, 2010 at 10:18 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Sure, you can't use the Valet key (gray one) for programming, the black master key is needed for that.
    They set it up that way so the valet parking the car can't make a duplicate and then drive away with you're rig
  12. Mar 29, 2010 at 1:22 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Great...
    My fiance lost my spare set of keys (they were on her key ring which she lost) yesterday.
    I was hoping they weren't chipped.
  13. Mar 29, 2010 at 3:41 PM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    I would guess that a good locksmith would be able to do it if they had the right equipment.
    Marc M
  14. Mar 29, 2010 at 4:07 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My Taco is pretty standard issue (4cyl, 2wd) except it has the SR5 #2 package: PW, PDL, PM, cruise, remote keyless entry, along with some shiny trim pieces. All the fob does is lock and unlock the doors, and panic mode. Nothing more. The key is still required for engine starting and the keys are not chipped (I got some blanks off Amazon and they work fine after double-cut at local hw store)
  15. Mar 29, 2010 at 4:15 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    The local ACE hardware has a sign by the door that says they can make/cut chipped keys.
  16. Mar 21, 2014 at 8:50 PM
    Lickster
    Lickster Member
    Rick
    N. Idaho
    just ordered truck ,being built to specs
    No Mods yet - that'l change
    This still falls under keys and such...
    I had a 94 SR5 and a heavy keyring, so as we all know eventually the key wears out to the point that it cant be copied. Well I talked to a good friend who was a toy mech for my local dealer, and he told me that there is a complete record of your truck, including the number code to the keys,these were manual keys, fixed to the inside panel of the passenger door. basically removing that panel and you should know everything that is about that truck, and apparently toyota dosen't let that info out.
  17. Mar 22, 2014 at 6:17 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I always insist on 2 sets when I buy a vehicle. When I bought my 2013 Tacoma and found out they dropped the valet I made the dealer cut a 3rd key.
  18. Aug 3, 2015 at 5:08 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    Good grief. My Taco only came with 1 black key, which turned out was not the master key. The dealer required that I drop the truck off for the day to cut and program a key. Originally it was estimated at $115, but now that it is a master key the price jumped to an estimated $260. Apparently they have to erase all the programming and reprogram that system. I need a second key so whatta ya gonna do?
    Well, they just called a few minutes ago and said the tech was having issues with programming (the issue being the computer wouldn't take the new program) and they want to keep the truck overnight and work on it tomorrow. It occured to me that he had to erase the existing code and now that it won't take the new code it's blank and essentially won't lock, start, etc... I fear an expensive computer thingy replacement is coming down the pike.
    Not a good start to my first Taco owning experience!
    :annoyed:
  19. Aug 4, 2015 at 7:34 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Holy shit .... Checkered Flag in Virginia Beach $115 ... sorry ... I normally hate those guys who post negative but this may save others some $$$.
  20. Aug 4, 2015 at 3:33 PM
    916carl
    Carl
    Picked up Kate today with the new Master key. Got me for $251. They did a general inspection and the only thing they found was the front brakes need to be done (@2mm). Dealer quote was $350, Pep Boys was $125 cheaper. They also checked the frame as part of the rust recall and (no surprise) it's fine.
    Keep track of your keys! Paying for a copy is expensive...
