Matching Suspension Heights
Discussion in 'Suspension' started by dza1284, Mar 31, 2011.
  1. Mar 31, 2011 at 6:00 PM
    dza1284
    dza1284 [OP] Well-Known Member
    CA
    08 OR Short Bed Dbl Cab
    Bilstein 5100, 2" AAL, Grille, BHLM, Footwell LED, Dash LED, Aero exhaust
    Recently had new shocks and AAL installed on my truck. Today I noticed that in the rear one side is .5"-1" lower. Is this a large concern? Should they be exactly the same? Is it possible that one AAL has settled a little more than the other?
  2. Mar 31, 2011 at 6:01 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Which side is lower? Drivers side?
  3. Apr 1, 2011 at 8:31 AM
    dza1284
    CA
  4. Apr 1, 2011 at 8:49 AM
    KPT
    09 Prerunner
    I take it the front is 1/2" to 1" lower too on the drivers side?
    Did they install an extra spacer on the drivers side to combat the "taco lean"?
  5. Apr 1, 2011 at 10:03 AM
    dza1284
    CA
    Front is pretty much level. All that was installed was 4 new shocks and 2 AAL.
  6. Apr 1, 2011 at 11:12 AM
    KPT
    09 Prerunner
    hmmm are both the aal's right side up?
    How long has it had to settle?
  7. Apr 1, 2011 at 12:30 PM
    dza1284
    CA
    I remeasured on a better surface and it is not as bad as I thought. Thanks for your help.
  8. Apr 1, 2011 at 5:55 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Gas tank...
