Max airspace behind rear seat 2015 double cab
Discussion in 'Audio & Video' started by Ma Deuce, Sep 2, 2014.
  1. Sep 2, 2014 at 8:28 PM
    Ma Deuce
    Ma Deuce [OP] Well-Known Member
    Joe
    Colorado
    I'm waiting on a 2015 to arrive and I would really like to be able to shoe horn (3) JL 10W0s behind the rear seat. I want to put them in a shared chamber and I want to get 2.06' of total air space to account for the displacement of the woofers themselves and still give me .65' per sub.
    Is this possible to do while retaining the rear seats?
    Thanks for the help
  2. Sep 3, 2014 at 9:11 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Trust me, ive researched this a TON and the only answer i can get is that no, you cannot make 2.0 cu. ft. of airspace back there. My goal was 2 ported 10's which required at least 2.0 cu ft. but i am going with 1 12 instead so i can have the right amount of airspace. I think you max out around 1.7 cu.ft. and if someone tells you differently, dont just take their word for it, ask for dimensions or some kind of proof.
    Ive never understood why someone would want 3 subs anyway, 2 subs would sound alot better if they were in the same size box as 3. the airspace is crucial.
  3. Sep 3, 2014 at 1:08 PM
    Ma Deuce
    Joe
    Colorado
    Thanks for the info about the airspace, I appreciate it.
    If you are talking about identical subs though, 3 subs will always be louder than 2 if you have them in the proper airspace with proportional power. Putting 2 subs in a box built for three is going to make the subs lose SPL, SQ and they won't be able to take as much power to them. (Edit: You will probably get a little more ultra-low end bass, but not worth it IMO)
    I modeled a few different subs and scenarios on WinISD and the 3 W0s came out on top. If I absolutely can't get them to fit I'll probably go with 3 W1s instead in a slightly smaller box.
  4. Sep 3, 2014 at 8:07 PM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    I can build one that will fit 3 w0's behind the seats with 2.06 cu ft of air space. PM me if you want more details or a design.
  5. Sep 4, 2014 at 6:34 AM
    ranger098
    Brian
    Minnesota
    OP, this is where you ask for proof. not to say he's wrong, but i've had multiple others say they got 2.0 in a box and once i measured up their plan it was indeed not 2.0. Curious here though, if this is possible maybe i can get my 2 10's!
  6. Sep 4, 2014 at 7:41 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I've got a box for two 12"s, behind my seats, and I figure I have around 1.9-2cu.ft. of space. What I did was to cut the top, bottom and sides, actually screw them with L-brackets to the truck body for sealing, and then silicone heavily around the inside of the box. It takes time to form the sides to fit the bracing bar across the middle of the back wall, and around the upper seat bracket mounted to the floor. There's some build pics here, that show my process. There's no "back of the box", I'm using the back wall of the truck as the back wall of the box. It can be done, but you have to grab your balls, and screw into the truck with some metal tapping screws.
  7. Sep 4, 2014 at 7:52 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    There is definitely enough room back there to get 2 cu ft in an enclosure.
    Also, how did you come up with 2.06? You'll want 1.95 for three of those w0 subs. JL accounts for their driver displacement in their enclosure volume specifications.
  8. Sep 4, 2014 at 7:54 AM
    Ma Deuce
    Joe
    Colorado
    Some one handed drill action, sounds like a blast! :)
  9. Sep 4, 2014 at 7:55 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    Hmmm, and where did you get that idea? :rolleyes:
  10. Sep 4, 2014 at 8:17 AM
    Ma Deuce
    Joe
    Colorado
    Good call! I totally read that wrong on their site. Thanks for pointing that out,
  11. Sep 4, 2014 at 8:19 AM
    ranger098
    Brian
    Minnesota
    I'd be curious to see some dimensions and or calculations because with the box builder calculators i use, ive never been able to get 2.0 cu.ft back there. Not even using .5" mdf and excluding speaker displacement. That notch you need to make on the back wall takes out a lot of space, and the wedge shape takes a lot out too.
  12. Sep 4, 2014 at 9:26 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    C'mon Shane. Sorry for not giving you credit, but no need to bust my balls!:eek::cool::sorry:
    Anyways, there is room to be had, and you can make it work, that's the point I was trying to get across. It's all good, shaneckc really helped me out on my build, that's for sure.
  13. Sep 4, 2014 at 9:36 AM
    Ma Deuce
    Joe
    Colorado
    It's worded a little vague so I went ahead and asked them. JL customer service is great.
    Mike West (JL Audio)
    Sep 04 11:56
    Hello Joe.
    The volume listed in the chart is the net volume. So looking at that alone, you'll need to add in the woofer displacement and any brace displacement in order to get the gross volume.
  14. Sep 4, 2014 at 9:51 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    Ah, ok. I even checked it against their recommended cubic enclosure dimensions and it was so close to their recommended space that I assumed they were accounting for driver displacement. I didn't realize that the driver displacement was only 0.03 cu ft. My bad.
    2.052 gross cu ft, it is!
  15. Sep 4, 2014 at 3:51 PM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    sorry to threadjack a bit... but....
    will the 2014 sub boxes fit in the 2015's? (DC/single 10)
  16. Sep 5, 2014 at 5:15 AM
    Ma Deuce
    Joe
    Colorado
