Max size tire with no scrubbing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trd2011, May 12, 2011.
  1. May 12, 2011 at 8:00 AM
    trd2011
    trd2011 [OP] Well-Known Member
    Jacob
    Mississippi
    '15 TRD Sport
    Sportsman camo seat covers, 265/70R17 Kumho MT's, 20% Tint, 5000K HIDs
    I have a 2011 TRD. Im wanting to put Toyo MT 285/75-16's on stock rims. Im going to add a 3/1 lift kit from lowrangeoffroad.com. Will this size tire scrub? Will I need to remove my front mud flaps? Any suggestions would be appreciated........
  2. May 12, 2011 at 8:02 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yes, you will rub a bit most likely... You will probably have to trim or take off your mudflaps and do a little bit of body trimming, but not much. That would be for a 3" lift. I am not quite sure what a 3/1 lift is
  3. May 12, 2011 at 8:06 AM
    trd2011
    Jacob
    Mississippi
    '15 TRD Sport
    3/1 lift from lowrangeoffraod.com is 3" lift in the front and 1" lift in the back
  4. May 15, 2011 at 7:17 PM
    soupman77
    soupman77 Well-Known Member
    Alan
    Texas
    08' 4DR Tacoma LB 4x4 TRD Sport
    Revtek 3" Leveling kit with 1.25" in rear. Grillecraft mesh grill with TRD emblem, Hella 500's mounted behind grille, horn relocation, blacked out lower valence, allpro offroad bumper, blacked out roof, and so much more to do...
    I had to cut some of the underbody and remove the front mud flaps, even with 3" front leveling and 1.25" in the back to accommodate 285's on stock wheels. From what I understand, you may also need to get some different wheels to adjust for the offset or get wheel spacers. I went with the spidertraxx wheel spacers from www.lowrange.com. If you get spacers, don't buy junk...forum members made this very clear. Im loving the look and the ride isn't too bad. Good luck!
