max tire size on stock rims
Discussion in 'Wheels & Tires' started by Cancer FREE, May 21, 2012.
  1. May 21, 2012 at 9:21 AM
    Cancer FREE
    Cancer FREE [OP] Active Member
    Kimowahapalu
    Seal Beach, Ca.
    2012 DCLB 4X4 TRD Sport
    Bilstein 5100's up front set @ 2.5 inch with 1 inch block in back UPDATE as of 06/14: 4inch rough country upfront with Bilsteins set at .85 for total lift of 4.85 and rear with 2 inch block with Bilsteins 5100's shocks. UPDATE as of 0615 4 inch lift Rough country with Bilsteins set at 2.5 and rear 2 inch add a leaf with 3 inch block sitting on 285/75-17 34's...
    If I'm correct my stock rims on my 2012 4X4 are 17X9 and it has 265/65/17. My question is if I level the front what the max size tires I can put on the stock rims?
  2. May 21, 2012 at 9:30 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    265/70/17
  3. May 21, 2012 at 9:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. You can go taller but that means running a narrower tire.
    When you say you want to level it out, I'm assuming you're leveling it with either a coilover or a spacer kit and not thinking of running taller tires on just the front? Not trying to be insulting, but some people might not see anything wrong with that...
  4. Aug 7, 2012 at 6:11 PM
    Dynamic
    Dynamic Member
    Las Vegas/Seattle
    Tacoma 4x4 V6 SR5 Upgrade Offroad Pkg.
    Done: All new skid plates, locking gas cap, snugtop xtra vision cap, diff mod breather, mudflap mod, rokr t505 Plan to do: backup camera full time switch, fog bypass on hi beams, winch, rock sliders, cb radio, pa system, engine led light, rims, larger tires
    I have a 2010 tacoma 4x4 and my stock tire is 245/75/16 without changing the rim size and I am still at stock with no leveling kit, and no spacers what is the max tire size I can run without cutting the fender and getting overspray from the tires onto the fenderwell or side of truck when driving as I do not have rubber fenderwells???
  5. Aug 7, 2012 at 10:12 PM
    RightCoaster
    RightCoaster Well-Known Member
    Patrick
    Myrtle Beach
    2012 SR5 4CYL 5SPD, 2020 DCSB TRDOR 6SPD, 2023 DCLB SR5
    Also interested on this one <thumbup>
  6. Aug 7, 2012 at 10:16 PM
    ColtsTRD
    Scott
    AZ
    the question was answered!
    read...lol
  7. Aug 7, 2012 at 10:36 PM
    RightCoaster
    Patrick
    Myrtle Beach
    I didn't know if the rim size would matter. I thought the max tire size was referring to a 17" rim vs. a 16" one.
  8. Aug 7, 2012 at 10:41 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    The question was answered for 17's not 16's which he is asking. Also your post is pointless! Read... lol
    I believe from my limited research that the largest tire size for 16 with out mods would be 265/75.
  9. Aug 8, 2012 at 8:58 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It's the most common question on this entire site, that's why there's a thread stickied at the top of the forum entitled "Largest tires sizes on stock suspension". The same size restrictions apply for stock wheels.
    http://www.tacomaworld.com/forum/wheels-tires/67550-largest-tacoma-tire-sizes-stock-suspension.html
    The stock 17's are 7.5" wide, not 9"
  10. Aug 9, 2012 at 5:03 PM
    RightCoaster
    Patrick
    Myrtle Beach
    I have minimal knowledge when it comes to tire sizing and purchases. The size of the rim threw me off on which tires were compatible etc. My mistake.
