Max tire size question again
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bluesman51, Jan 17, 2024.
  1. Jan 17, 2024 at 9:57 PM
    Bluesman51
    Bluesman51 [OP] Member
    2023 TRD Offroad
    none yet
    Beginning to look at putting new shoes on my 23 Tacoma TRD Offroad. Want to use the stock wheels. I have seen many posts saying 265R75/16 are as big as I can go without rubbing issues. However while researching different tires that are listed as 265R75/16 I am seeing specs that show inflated diameters from 31 to just under 32 inches. So my question is what is really the max diameter in inches you can run on a stock TRD Offroad?
  2. Jan 17, 2024 at 10:02 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I believe there have been a few who on the stock sport wheels (17”) ran 255/80R17 which is about 33”. That is a very tight fit though. I run 255/75R17 on my sport wheels and they fit fine, they are larger than the size you’re looking at by about half an inch and they fit great.
    I would say anything marketed as 265/75R16 will work. Also, there should not be that much of a variation in tire height when comparing the same size. They have to adhere to being close to the right size. The differences you are seeing in the specs are probably differences in how they were measured. I personally don’t look at heights, I look at revs/mile. That is the most useful way to figure out how big a tire really is.
  3. Jan 17, 2024 at 10:02 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Wheel width, backspacing, and offset are huge factors as well. Are you asking the biggest size on stock TRD OR wheels with no spacers?
    71tattooguy likes this.
  4. Jan 17, 2024 at 10:04 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    255/85R16 narrow for the win. Aside from that, 39”s.
  5. Jan 17, 2024 at 10:21 PM
    Bluesman51
    2023 TRD Offroad
    none yet
    Want to stay with stock wheels, no spacers, no lift. The stock tires are fine in sand but here in north Florida I do run into clay based mud from time to time and the stock Goodyears are not happy. Looking at either Mickey Thompson Baja Boss ATs or Nitto Ridge Grapplers so far. I do not want tires that are crazy loud on pavement.
  6. Jan 17, 2024 at 10:28 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    On occasion 265/75r16 will touch mud flaps but that is generally all. I ran 265/70r17 dura tracks on a +1 offset and had no issues with an aftermarket mud flap.
  7. Jan 17, 2024 at 11:23 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    255/85R16, push the lower control arms forward at an alignment and you are fine.
  8. Jan 18, 2024 at 6:00 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
  9. Jan 18, 2024 at 6:12 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    The solution to there being too many "biggest tire I can run" threads always seems to be to create yet another "biggest tire I can run" thread.
    As if the responses, conflicted as they may be, are going to change....
  10. Jan 18, 2024 at 6:15 AM
    7mMike
    7mMike Well-Known Member
    Nh/vt
    If you’re not scared of cutting the options are unlimited.
  11. Jan 18, 2024 at 10:40 AM
    Bluesman51
    2023 TRD Offroad
    none yet
    I guess I need to reword my question. The size tire I want to run is 265R75/16 on the stock wheels, nothing larger. I do not want to modify or cut anything to make room for the tires not to rub. As all of the tires I am considering are expensive I hope to get it right the first time. Again, my concern is that the tire diameter spec varies from 31 to just under 32 inches on tires that are listed 265R75/16. So, will a 32 inch tire work without rubbing? Also, is anyone running Mickey Thompson Baja Boss ATs on a stock Tacoma TRD?
  12. Jan 18, 2024 at 10:52 AM
    BLtheP
    Plano, TX
    You will be fine.
