max tires size
Discussion in '1st Gen. Tacomas' started by oregon.country, Aug 20, 2010.
  1. Aug 20, 2010 at 3:13 PM
    oregon.country
    oregon.country [OP] Well-Known Member
    Mackenzie
    Oregon
    02 4x4 TRD Black
    Level kit, and rancho coil over shocks.
    I'm looking to put knew tires on my 2002 ext cab tacoma just don't know how big of tires I can fit under it. I have a leveling kit on it and would like to go 33's but I'm not sure they will fit with out some cutting. Anyone know how big of tires I can fit under it without cutting it? Also Pictures of your truck with tires and rims would be sweet. Thanks for the help.
  2. Aug 20, 2010 at 3:14 PM
    MSUtacoboy
    MSUtacoboy Well-Known Member
    MS
    2008 Silver DC 4x4 Trd off-road
  3. Aug 20, 2010 at 5:15 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    This is my stock 1998 TRD 4x4 with 32"x11.50x15". I get a little rub when turning the wheel hard to the left and going through a bump. I have not trimmed my wheel wells yet.
  4. Aug 20, 2010 at 6:56 PM
    KentuckyTaco
    KentuckyTaco Well-Known Member
    P-Town
    02 xcab 4x4
    K&N filter w/deckplate mod Dynomax muffler Tinted windows Maglite mod Line-x spray in bedliner Blacked out taillights/3rd brake light
    Ive got an 02 xcab as well with a set of 265/75/16 maxxis bighorns and they rub a little, not lift though
  5. Aug 20, 2010 at 8:34 PM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    i got 31 10.50 MTs on my truck with no lift and stock rims and it is vary close to rubbing i would say going any bigger then a 32 would be pushing your luck with no lift and stock rims
  6. Aug 20, 2010 at 8:46 PM
    bivey
    bivey Well-Known Member
    A 32 is as big as u can go without some rubbing
  7. Aug 22, 2010 at 9:49 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. OME aal with OME nitrochargers out back. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    265/70/16's are stock on the trd's. Will 33's fit with a 3in lift/leveling kit?
  8. Dec 13, 2010 at 1:10 PM
    R6Racer
    R6Racer Member
    Ontario Canada
    03 PreRunner
    tacoma-king... is your truck a 2WD?
    I have an 03 2WD PreRunner with the 2.7 & I am trying to figure out if I can mount a set of Michelin LTX M/S 31x10.5" 15's that I have, onto my stock 15" rims without any rubbing probs.
    Thanks
  9. Dec 13, 2010 at 1:26 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    265/75/16...i rub on tight turns
  10. Dec 13, 2010 at 2:01 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    Acording to some build threads, yes. 33's will fit on a 3" lift with alot of trimming. Maybe slight rub but Idk..? :confused:
    OP- the biggest size with no lift or trimming Im sure is 265/75.
  11. Dec 15, 2010 at 4:24 PM
    R6Racer
    R6Racer Member
    Ontario Canada
    03 PreRunner
    Just an FYI for anyone interested.
    The 31x10.5 15's fit, on stock wheels (for now at least) with no rubbing at all.
    03, 2WD, 2.7L, 6 lug, PreRunner, Ext cab.
  12. Dec 18, 2010 at 8:08 AM
    tacomafj
    tacomafj New Member
    Rick
    Ohio
    96 Tacoma
    FJ Wheels, 265/70/17 tires, 1999 Engine, Transmission, Transaxle
    32" tall tire will not come close to rubbing if it is on the right wheel. I have fj wheels on my 96 Tacoma and running 265/70/17 (31.8 tall) tires and have plenty of clearance with no lift. I easily clear the 285/70/17 as well but do not like the look of the 285/70/17 (32.8 tall)tire, too tall and skinny looking. I also would not recommend running running a 32 x 11.5 x 15 on the stock 15 x 7 tacoma wheel either. Minimum wheel size for that tire is 8" wide wheel your asking for the tire to pop off the wheel after hitting a pot hole or anything else in the road or doing any off roading. Aftermarket wheels also will determine how tall of tire you can run since they run different backspacking and offsets which will cause rubbing issues.
