Maxed out at 133KMH - 83MPH
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SandyHouston, Jul 22, 2021.
  1. Jul 22, 2021 at 9:19 AM
    SandyHouston
    SandyHouston [OP] Member
    Hey everyone,
    I have a 2020 OR, I have regeared to 5.29s and also added the OV Tune to compliment the 5.29s. I knew I would loose top end, but I didn't think this much would be lost. As you can see, I am maxed out at 133km/h at 3200 RPMs 6th gear. I tried to get more out of it, but it would just rev and the speedometer would not get any higher. My question to you is, is this a tune issue or is this a gear issue or a combination of both? Any information would be greatly appreciated!
  2. Jul 22, 2021 at 9:22 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Sounds like a tune issue cause you should be able to rev out 6th no problem regardless of what gears you have
    sdshack, Wixo and SR-71A like this.
  3. Jul 22, 2021 at 9:23 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    It's because of the gears. You need to use vFtuner to reset the truck's max speed. If you tuned yourself, it's really simple. If someone else tuned your truck, they should have made the adjustment for you, and should correct it free of charge.
    I have not geared my truck, although I have tuned a few regeared trucks. My basic understanding the speed limiter/gearing relationship is this:
    Stock gear size = 3.90
    New gear size = 5.29
    Stock max speed (based on stock tires) = 112mph
    3.90 / 5.29 * 112 = 82.57 mph is your new max speed because the truck "thinks" it's going 112.
    willie2, sdshack, Wixo and 2 others like this.
  4. Jul 22, 2021 at 9:23 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Read thru the OV tune thread, there are fixes.
    Did you tune yourself, or get someone else? You need the specific 5.29 tune.
  5. Jul 22, 2021 at 9:24 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Weirdly, the speed limiter is sensed on the AT output shaft speed. An easy edit or 5.29 vF Tune will correct that.
    SR-71A and Skydvrr like this.
  6. Jul 22, 2021 at 9:25 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Your fishbowl needs filling.......
    Murd3rd likes this.
  7. Jul 22, 2021 at 9:26 AM
    SandyHouston
    Thanks for your reply. This has been tuned by Matthew Wilson at Orange Virus tuning. This has the 5.29 tuning pack with 33's on it. Does anyone know the step by step on how to reset the max speed? I purchased the kit to tune myself, I just need a little help on a guide to get this done. Must go faster. Thanks!
  8. Jul 22, 2021 at 9:27 AM
    SandyHouston
    I tuned myself using the tunes from OV. This has a specific tune for the 5.29 gears with 33 tires.
  9. Jul 22, 2021 at 9:29 AM
    SandyHouston
    As per my post, my truck has an OV Tune specific for the 5.29 gears. I am trying to understand how this was missed.
  10. Jul 22, 2021 at 9:29 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    If you can hit 88mph you can go back in time and never install the tune .
    Malvolio and Skydvrr like this.
  11. Jul 22, 2021 at 9:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is weird. The 5.29 tune should have you sorted, but the easy way is to edit your tune like so:
  12. Jul 22, 2021 at 9:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed, but the edit in the post above is very easy. I'd use your 5.29 tune as the starting point.
  13. Jul 22, 2021 at 9:34 AM
    Dank Donkeh Luvver
    Eric
    Maryland
    If I recall correctly, they didn't "miss" this. They had reasons to NOT change the global speed limiter - most likely liability related.
  14. Jul 22, 2021 at 9:36 AM
    PiryongS
    PiryongS Well-Known Member
    Great Scott!!!
    Malvolio and GOTSAND?18[QUOTED] like this.
  15. Jul 22, 2021 at 9:36 AM
    SandyHouston
    Ok, so riddle me this then. What is the max speed reached without tuning or gearing, complete stock, for a 3rd gen Tacoma before the governor kicks in?
  16. Jul 22, 2021 at 9:37 AM
    coopcooper
    alberta canada
    110mph give or take
  17. Jul 22, 2021 at 9:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not quite. The 5.29 tune allowed the speed limiter to go back to the Stock setting. Something like 108? It was said that the drag limit is right around there also.
  18. Jul 22, 2021 at 9:39 AM
    SandyHouston
    Thanks for that. So for the record, I will set my max speed in the tune to 110 mph or for us canucks, 177km/h. Just to clear up any liability concerns. (We don't know how to sue in Canada, btw.)
  19. Jul 22, 2021 at 9:39 AM
    coopcooper
    alberta canada
    or just remove the limiter
  20. Jul 22, 2021 at 9:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Most all values in the vF software are Science Units.
