Maximum tire size w/ 5100's??
Discussion in 'Wheels & Tires' started by GEENYUSS, Jun 13, 2010.
  1. Jun 13, 2010 at 3:45 PM
    GEENYUSS
    GEENYUSS [OP] Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports LCA, Bilstein 5125’s, All-Pro Exp Leafs, 285/75/16 BFG KM3s
    im sure this has been asked many times i appologize. im new to the forum and need some help on tire size. i just bought a 2010 double cab trd 4x4. i bought a set of 5100's and have the fronts at 1.75 and the tsb in the rear seems to sit pretty good. im getting the "thug" rims in either a 16/17". can i fit a 285 tire w/ little trimming? or is a 265 the max? also any recommendations on brand of tire to get. thanks this forum is awesome
  2. Jun 13, 2010 at 4:55 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You'll ideally want to set the billys at 2.5" in order to fit the 285's. With the 1.75" setting you'll rub. I'm sure someone will pop into this thread and say they got them to fit, but you'd really be cramming them in there and have to trim a lot. You'll have to trim even at 2.5" to fit the 33's.
    Before you buy the rims, make sure they have 4.5" backspacing or less as well.
  3. Jun 13, 2010 at 5:52 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    285s will probably rub even at 2.5.
  4. Jun 15, 2010 at 10:51 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    with a little trimming they ought to fit. Hell, I cut quite a bit but im running 35x12.50's on 3" of lift.
