Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Feb 28, 2013 at 5:33 PM
    #1981
    TacoDaddy
    TacoDaddy Just call me Daddy
    Brian
    Costa Mesa, CA
    '11 Sport
  2. Feb 28, 2013 at 5:34 PM
    #1982
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i hasd the same noise but thank god it wasnt the bushings
  3. Feb 28, 2013 at 6:23 PM
    #1983
    JohnnieFive
    JohnnieFive Well-Known Member
    Johnny
    Anaheim, Ca
    07' Tacoma PreRunner TRD Sport
    Dropped of the Taco to get lifted. Should have it back tomorrow afternoon!
  4. Feb 28, 2013 at 9:28 PM
    #1984
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    thx man! love your new stance too :cool:
  5. Feb 28, 2013 at 9:35 PM
    #1985
    TacoTony
    TacoTony Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Any word of a group buy?
  6. Feb 28, 2013 at 9:38 PM
    #1986
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    You are a month late. Me and Tacochaos were in the group buy for ours spindles.
  7. Feb 28, 2013 at 9:41 PM
    #1987
    TacoTony
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Nooooooo!!!!! How much were they
  8. Feb 28, 2013 at 9:43 PM
    #1988
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    I'm sure it's been posted somewhere but what are your hub to fender measurements I want to see if I would've been higher had I gone spindles instead of springs
  9. Mar 1, 2013 at 9:59 PM
    #1989
    JohnnieFive
    Johnny
    Anaheim, Ca
    Got it back this afternoon, had the install done by Suspension Specialists here in Anaheim. 4" Maxtrac lift up front 1" in the back, it has a bit of a bro lean but I don't mind it.
  10. Mar 1, 2013 at 10:19 PM
    #1990
    TheGloryFades
    Seth
    Arizona
    '13 toaster
    So much bro lean it's upside down
  11. Mar 2, 2013 at 12:42 PM
    #1991
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    I first had the spindles up front and a 2" block in the rear and I still was way higher in the front
  12. Mar 3, 2013 at 3:56 AM
    #1992
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Alright so Im bored at work, read through the first 38 pages and saw alot of nice lifts and results! Once I read that far it got repetitive as the same questions kept poppin up :eek:
    Finally decided to type out how the install went with these bad boys. Originally I thought the easy part was gunna be the brake lines so I saved it for last (Obviously this was a mistake!). Taking the hub off was abit tricky but everything was smooth until I got to the actual installation of the maxtracs. It became clear that on the backside driverside spindle, where the UCA ball joint bolt goes in, the spindle was not milled out enough to even get a socket onto it....eventually we rigged it to where we got it to work but it was a headache for about 10min.
    Then moving onto the brake calipers...driver side and passenger side bolt mount points/holes on the spindle for the calipers also was not milled out enough to allow for the bolts to slide into the holes. had to grind off some of the brake caliper to allow it to slide all the way onto the mount point and allow the bolt to slide in.
    Soooo....onto the brake line headache! Some may have noticed i posted an emergency thread for help gettin the brake line nuts off....reading the beginning pages of this thread would have been helpful :rolleyes:. At the time, I had already rounded off the fantastic peice of shit aluminum brake line nut on the driver side. I did not have flare nut wrenches (or even knew what they were) nor a pipe wrench. It was getting dark, the closest vato zone or store that carried any of that was about 30min away, and I had work in the morning so the time called for desperate measures. I actually unbolted the brake line mount bracket attached to the frame and stretched the hard lines straight down (yes i know not the greatest thing to do) BUT this gave me a ton of extra brake line while still using the stock lines! We just simply tac welded the bracket to the bump stop mount and called it a day.
    Overall, I feel like everything else near that spindle needs some super beefin up cuz the maxtracs are so damn beastly lookin! I love the height and clearance i got out of it. I still need to raise the rear quite a bit, more than likely expo leaf pack.
    My current setup: 5100s set at 0 with OME 885s and da maxtracs. rear has TSB 4 leaf pack with 1.5" Toytec AAL. My current tire set up: 285/70R17 Nitto TG in front, same size BFG ATs in rear with XD Cranks 5.0 BS -12mm offset NO WHEEL SPACERS!
  13. Mar 3, 2013 at 6:32 AM
    #1993
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    T4C0CH40S,
    Can you post up a front, head on shot? I am curious how much your front tires stick out with that backspacing. Also, do you have 12mm offset or negative 12mm offset??
    Thanks
  14. Mar 3, 2013 at 6:38 AM
    #1994
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    yessir! oh and yes i meant -12mm offset
  15. Mar 3, 2013 at 7:49 AM
    #1995
    sfcadams
    Dan
    Elizabeth, Indiana
    nice...
  16. Mar 5, 2013 at 12:24 PM
    #1996
    blitton08
    blitton08 Well-Known Member
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Maxtrac Spindles, Bilstein 5100s set 0 in front with Eibach Springs, 2.5" block in rear with OME Dakar Leaf Springs
    I currently have Maxtrac spindles and bilsteins set at 0 but i'm looking to set the bilsteins at 1.75. I'm having trouble finding a solution for my rear to level me out. I currently have 2.5" blocks and stock leafs. Should I just AAL? replace everything in the back with new leaf springs? or get a larger block? Keep in mind that I do not off road unless traveling through a trail or pasture to get to a camp site. Nothing rough.
  17. Mar 5, 2013 at 1:54 PM
    #1997
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    I have my billys at 1.75 plus the 1.6 eibachs..I have stock 4 leaf pack, 2" block, 1.5 aal..and im front high..I need 2 more inches in rear to be level..im going with an alcan 6" lift leaf pack..you can probably go with the all pro expos
  18. Mar 5, 2013 at 2:09 PM
    #1998
    blitton08
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Thanks
  19. Mar 6, 2013 at 9:50 AM
    #1999
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    X2!
  20. Mar 6, 2013 at 8:14 PM
    #2000
    JohnnieFive
    Johnny
    Anaheim, Ca
    Another pic from today with the new wheels and tires
