Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Mar 7, 2013 at 8:23 AM
    #2001
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    Finally got my spindles back from powder coat! Going on tomorrow night :) Now time to see how big of a bro lean i get : /
  2. Mar 9, 2013 at 1:34 PM
    #2002
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    These are next on my list! Right after I get my homertaco grill
  3. Mar 9, 2013 at 1:37 PM
    #2003
    blitton08
    blitton08 Well-Known Member
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Maxtrac Spindles, Bilstein 5100s set 0 in front with Eibach Springs, 2.5" block in rear with OME Dakar Leaf Springs
    Alright, before I spend all my money I want to check and see if anyone here has this setup or any advice on this setup. Maxtrac spindles w/ bilsteins set at 1.75 in the front. In the rear, 2.5" blocks w/ Dakar leaf pack which will add 2.5". I dont have the money for eibach springs plus something to level my back out or I would. What do yall think about this setup? will it ride like crap? Thanks
  4. Mar 9, 2013 at 2:54 PM
    #2004
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Should ride just fine! I have stock shocks up front and a 4" block in the rear so yours will ride better than mine. Mine rides a little rougher than stock but I also have 6.5" of lift and 33" mts! I don't do much offloading either
  5. Mar 9, 2013 at 4:32 PM
    #2005
    TacoDaddy
    TacoDaddy Just call me Daddy
    Brian
    Costa Mesa, CA
    '11 Sport
    OMD (4WD) always says that going above 4" in the rear may cause driveline vibrations and will require carrier bearing shims. With the spindles, pull your Bilsteins out and drop your springs to the stock level for a smoother ride.
  6. Mar 11, 2013 at 8:41 PM
    #2006
    blitton08
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Wheres the pics of them installed??
  7. Mar 13, 2013 at 6:10 AM
    #2007
    kankaloo
    kankaloo Active Member
    Norwalk, CA
    07 DCLB TRD sport
    hi guys, would a 4.75 BS wheel and 33x12.50x17 tire clear the Maxtrac spindle and stock uca?
  8. Mar 13, 2013 at 8:50 AM
    #2008
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Easily
  9. Mar 15, 2013 at 2:25 AM
    #2009
    87twentytwor
    87twentytwor Well-Known Member
    Jake
    Hawaii
    Sport
    none
    whats a good wheel size to run with maxtrac spidles without having to use spacers? i wanna be able to run 16's or 17's. i read 4.5" backspacing was the ideal # some where in the forums concerning spindle lifts. does backspacing play a huge part in this?
  10. Mar 15, 2013 at 11:50 AM
    #2010
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Yes if you don't have the right offset and backspacing the wheels won't clear the spindles.......you cannot use stock wheels for this reason! You should be able to find just about any of the more common wheels in the correct offset and backspacing.....mine are 4.5/-12mm
  11. Mar 15, 2013 at 3:08 PM
    #2011
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Been searching through here but either it isn't really listed or I just kept searching the wrong pages, but what size 16's are needed to run spindles without spacers if possible? I know the OP posted his setup with 16's with 3.75bs but no spacers. So, is that the only backspacing I can use on 16's to run spindles? I've tried time and time again but I just can't grasp wheel dimensions on back spacing and offset. That and wiring diagrams, I don't think I'll ever understand them.
  12. Mar 15, 2013 at 3:33 PM
    #2012
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    I can't help you on the 16s man maybe you could Pm him
  13. Mar 15, 2013 at 3:46 PM
    #2013
    Fiend13
    Chad
    Yeah. Just got tires 3 months ago and don't wanna buy new tires again to fit 17's so instead of wait till next year maybe just wanted to know if I could get 16's with a certain back spacing to run spindles. Thanks anyway though!
  14. Mar 15, 2013 at 4:12 PM
    #2014
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    The greater the measurement the further the spacing from the hub to the inside lip of the wheel. So basically if your back spacing is 3.75 and the wheels you want to buy has a back spacing of 4.75, the 4.75 BS wheel will now be 1" closer to the spindle arm. So in essence the smaller the BS the further you are from the spindle arm.
    Offset comes into play with brake caliper clearance so this is a whole other thing to take into consideration.
    4.5 BS should be fine to clear with a 16" wheel. With a 17" you are likely good with 4.75 BS as the larger diameter wheel gets more clearance due to the taper of the spindle arm.
    Hope this helps and hope I didn't screw something up causing more confusion.
    Best of luck
  15. Mar 15, 2013 at 4:33 PM
    #2015
    Fiend13
    Chad
    Ok thanks! I understand what you are saying. Less back spacing on 16" wheels is what I want with these spindles. When you get spindles or something that can affect wheel spacing how do you know what wheels to get? Just measure the clearances you'll need yourself before you order them?
  16. Mar 15, 2013 at 9:07 PM
    #2016
    87twentytwor
    Jake
    Hawaii
    Sport
    none
    so if backspacing is 4.5 max, what would max offset be? i read 4.5 backspacing and 0 offset is ideal, standard 16x8 rims
  17. Mar 16, 2013 at 1:06 AM
    #2017
    Luckstrizzo89
    Luckstrizzo89 Well-Known Member
    San Diego
    2013 TRD SPORT
    Does anyone know of a 2 or 3 inch spindle lift for 2013 DCSB? Love the idea of maintaining stock geometry just don't want the 3.5 or 4 inch lift
  18. Mar 16, 2013 at 1:28 AM
    #2018
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    no
  19. Mar 16, 2013 at 3:08 PM
    #2019
    TRDtexasTaco
    JP
    06 TRD PreRunner
    Who should I order these from?
  20. Mar 16, 2013 at 3:08 PM
    #2020
    TRDtexasTaco
    JP
    06 TRD PreRunner
    Maxtrac or headstrong?
