Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Mar 25, 2013 at 1:01 AM
    #2061
    87twentytwor
    87twentytwor Well-Known Member
    Jake
    Hawaii
    Sport
    none
    Sic!
  2. Mar 25, 2013 at 8:00 AM
    #2062
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    Theyre 285/70
  3. Mar 25, 2013 at 8:16 AM
    #2063
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Any rub?
  4. Mar 27, 2013 at 11:52 PM
    #2064
    87twentytwor
    Jake
    Hawaii
    Sport
    none
    HAHA!! CLASSIC!!
  5. Mar 28, 2013 at 12:50 AM
    #2065
    87twentytwor
    Jake
    Hawaii
    Sport
    none
    So much combinations with these spindles!! SO HARD TO CHOOSE!!
    my measurements are:
    20 3/4 front
    22 1/4 back
    any suggestions?
    I'm thinking about going with:
    front-
    Maxtrac Spindles +4
    Bilstein 5100 adjustable shocks (set at 0)
    eibachs +1.6
    rear
    Bilstein 5100(extended)
    All Pro standard leaf pack +3
    outcome:
    front 25.35 w/total lift of 5.6"
    back 25.25 w/total lift of 3"
    my question is will this lift ride smooth?
    how much will the springs(coils/leafs) settle?
    I want the truck either completely level or with a slight rake.. I don't really dig the bro lean. I read through this whole thread and i still don't know what to do..
  6. Mar 28, 2013 at 1:35 AM
    #2066
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I had the Eibach springs and spindles with the EXPO Pack not the standard and had a slight rake, the Eibachs never really settled any lower for me since they were used.
    It did ride really nice but i went with remote resi coilovers because I had heated the 5100's to where I couldnt touch them.
  7. Mar 28, 2013 at 8:20 AM
    #2067
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    Thanks for bringing it back...maybe she'll give it a second thought. Hah
  8. Mar 28, 2013 at 9:15 AM
    #2068
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    My opinion is it would ride pretty stiff. The coils are 620 rate and noticeably stiffer then your stock coils. If you want to maintain the ride you have now, leave the coils alone and just settle with the 3.75 – 4” lift you get from the spindles.
    As for the back, I still say a bit stiff. Keep in mind the stock packs are really soft even with the shorty overload. The AP packs are thinner leaf, but they are 10 + 1 stacked. So you get some softness at some up travel, but then things start to firm up pretty quick the more you compress the rear. Now the truck I've rode in the AP packs (3” not the Expos) were pretty new, so after a few months they may soften up a bit more but this is just my experience with them.
    It kind of blows my mind what some people consider is soft. I myself like my suspension to work as intended and flex when needed, not bounce you around even on the smallest bumps making you feel like you’re going to break something.
  9. Mar 28, 2013 at 9:19 AM
    #2069
    Mr Salty
    Hermmy
    Lots of chrome
    Love the truck. The perfect height with the perfect sized tires. Great job on your selections.
  10. Mar 28, 2013 at 4:30 PM
    #2070
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I found it quite easy to use C-clamps while the leafs are still installed. Clamp them down, unbolt the u bolt and perch and use the C-clamp to expand the leafs enough to slide in the AAL and then use the C-clamps again to tight them down.
    Xrs-fsho likes this.
  11. Mar 28, 2013 at 8:26 PM
    #2071
    87twentytwor
    Jake
    Hawaii
    Sport
    none
    Well you run your truck hard :D.. i was planning on mall crawlin :cool:... did you think the eibachs were too stiff like mr.salty said?
    so would you prefer stock coils, and bumping the adjustables up..
  12. Mar 29, 2013 at 8:06 AM
    #2072
    Mr Salty
    Hermmy
    Lots of chrome
    Preloading to the first setting couldn't be that bad, but what I was saying is just settle with the lift from the spindles and leave everything else stock or with the 5100s set to 0. This will give you the best possible ride in the front maybe even a little better with the bilstiens.
    With the back if I were looking for a good ride I'd probably couple the Icon 3 leaf aal with a 1" lift block. I know everyone says bad things about blocks, but a 1" block is perfectly fine. If you don't want to compromise load capability I'd do a 1" block and a longer fitting 1.5” AAL so your over load is maintained. Between the block and lift from your aal selection you should be about level.
    With all the trucks I've lifted and from what I have learned over the years, if you want and appreciate a good ride in terms of commuting on the road and your satisfied with the performance when off-roading, keep things simple and change very little; the beauty of spindles and owning a 2wd is achieving lift without compromising ride quality. If your focus is more on Off-Road capability with lift, expect a stiffer ride on the road unless you’re looking to pay big dollar for COs and having the coils selected based on weight of truck and desired height, and shocks valved specifically for your truck and the feel/performance you’re looking for.
    Alright, thats enough of me running my mouth on a Friday morning :D
  13. Mar 30, 2013 at 4:47 PM
    #2073
    87twentytwor
    Jake
    Hawaii
    Sport
    none
    Wow! Thanks a lot!! Very informative..
  14. Mar 30, 2013 at 4:48 PM
    #2074
    patrick2236
    patrick2236 Well-Known Member
    patrick
    new Orleans
    2019 TRD Sport 4x4
    I just order maxtrac spindles 5100s and a 3inch block for my 2013 tacoma tss and im using stock coils and leafs and i was thinking about putting the 5100s to 1.75 will it be close to level and also i want to the new stock wheels they put on the tss with a 1 1/4 spacer will they work. Thanks for the help.
  15. Mar 30, 2013 at 5:18 PM
    #2075
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Painted and ready for install on Monday!!
  16. Mar 30, 2013 at 10:11 PM
    #2076
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    Good looking setup
  17. Mar 31, 2013 at 2:02 PM
    #2077
    87twentytwor
    Jake
    Hawaii
    Sport
    none
    Sic!!
  18. Apr 1, 2013 at 10:23 PM
    #2078
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Installed my spindles today. Put in some OME Dakars Leafs also.
    Bird33 likes this.
  19. Apr 2, 2013 at 2:04 AM
    #2079
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    ^^ looks good man! what painting process did you use to paint the maxtrac emblem? tape off or small paint brush...?
  20. Apr 2, 2013 at 5:35 AM
    #2080
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    I used one of those paint touch up brushes that are like nail polish...worked great and very easy
    Bird33 likes this.
