Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. May 13, 2013 at 3:05 PM
    #2241
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    I haven't had any traction control issues at all.....no light or anything
  2. May 14, 2013 at 3:48 AM
    #2242
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    I'm starting to have a problem, does any ones away bar end link come I'm contact with the brake line it self on the driver side? My has been hit or pushed a few times and has kinda tore the cler coating on the brake line. Should I modify the bracket or just do away with the away bar? Thanks
  3. May 14, 2013 at 4:32 AM
    #2243
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Steel braided brake lines might help.
  4. May 14, 2013 at 5:55 AM
    #2244
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The bracket should be cut off but I'm not sure that would stop the issue. Take s picture of the routing of the line?
  5. May 14, 2013 at 7:08 AM
    #2245
    TRDtexasTaco
    JP
    06 TRD PreRunner
    I'm using the ones that came with the spindles
  6. May 14, 2013 at 7:09 AM
    #2246
    TRDtexasTaco
    JP
    06 TRD PreRunner
    After work I will mess with it and put up some pics of what's going on
  7. May 14, 2013 at 7:42 AM
    #2247
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Joo sellin already?
  8. May 14, 2013 at 8:51 AM
    #2248
    nfs257
    DFW
    She gone
    The brake line bracket mounts to the spindle but the part that sticks out should be bent or trimmed according to maxtrac so it doesn't hit the sway bar but not sure why the line would rub...
  9. May 14, 2013 at 9:15 AM
    #2249
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Ditch the sway bar
  10. May 14, 2013 at 9:17 AM
    #2250
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Haha I did! I'm loving it! Can't quite speed racer around turns anymore, but meh, shouldn't do it anyways :)
  11. May 14, 2013 at 10:25 AM
    #2251
    VolcomTacoma
    Jeff
    NorCal
    Who are you talking to?
  12. May 15, 2013 at 7:44 AM
    #2252
    maxtracbob
    maxtracbob Well-Known Member
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Please please please read the instructions... The brake line bracket gets trimmed and bent out of the way per the instructions.... any questions please call JJ at Maxtrac... 714-630-0363.... He will go over it with you...... Thanks guy's
    BOB out
  13. May 17, 2013 at 2:21 PM
    #2253
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    definitely settled on spindles, is this complete kit any good?
    Not sure about the block in the rear, dont want to give up a lot in terms of ride quality...should I piece this thing out or grab this kit? do not want bro lean...want the front to sit just lower than the rear
    just found this kit available as well (4th kit down last one on the page):
    http://www.headstrongoffroad.com/complete-lift-kits-tacoma-05-6-lug.html
    Also I am going to be running my stock TRD sport 17' rims...tire wise, either going with 265/70/17 - 285/75/17...
    will i need spacers because of using factory wheels?
    which tires would work the best?
    I do not go off-road, this is purely for looking good with a nice lift and putting some nice tires underneath.
  14. May 17, 2013 at 2:33 PM
    #2254
    YotaMatt
    West Point VA
    Thats insane. ..piece it together...get the spindles and a 2" aal for the rear
  15. May 17, 2013 at 2:40 PM
    #2255
    YotaMatt
    West Point VA
    Headstrong offroad
    Also toytec is offering that kit with 4 inch spindles and a 4 inch block which would make it sit high in the rear
    U will need spacers in the front to tun 285s on stock wheels
  16. May 17, 2013 at 3:21 PM
    #2256
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    I would avoid running a 4" block in the rear. Either replace the leaf pack with some expos or get the icon 3 leaf pack to add to your existing one and a small block 1.5 or 2" block.
  17. May 17, 2013 at 3:46 PM
    #2257
    TRDtexasTaco
    JP
    06 TRD PreRunner
    I bent the bracket like the instructions says. When I turn to the left at full lock the end of the sway bar meets my brake line. Not sure I I need to bend the bracket back wards towards the caliper or just remove the sway bar?
  18. May 17, 2013 at 3:54 PM
    #2258
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Ok and thanks to you both...a few more questions but this helps a lot...
    I saw that toytec kit but as bornwild mentioned I was leary about a 4" block in the back
    I think i might follow your advice matt and piece it together at headstrong
    maxtrac spindles $510
    2" aal $85
    1.5" block and u-bolt kit $84
    then either:
    OME 60091 Rear Shocks (pair) $190
    or
    Bilstein 5100 Rear Shocks (pair) $166
    comes to just about or under $1000 with tax and shipping
    which of the 2 shocks is better given the price?
    would I need extended brake lines for the rear as well?
    Additionally, yeah I do want to run the 285/70/17, but will be doing so on the stock TRD sport 17"rim, what spacers would I need in front and/or back with 285s? will I need to trim, because if so I might prefer to go with a tire size where no trim is needed...if that is the case with the lift what tire size would allow fit but not need a trim? would I get the spacers from headstrong also?
    is the kit, which for about $1250 shipped more complete...the 2 items at the bottom are not part of the kit I pieced together, but will i need them?
    http://www.headstrongoffroad.com/com...-05-6-lug.html (4th kit down last one on the page)
    This front and rear kit will include the following:
    - Maxtrac Spindles w/front brake lines (706840)
    - OME 2.75" Rear leaf packs (CS047R)
    - OME Nitrocharger shocks (60091)
    - OME Ubolt kit (OMEU53A)
    - OME Rear drive shaft spacer (FK29)
    - SS rear extended brake lines (23")
    thanks for your help and continued advice
  19. May 17, 2013 at 5:08 PM
    #2259
    YotaMatt
    West Point VA
    Brake line are only required if you go offroad or were to run those 4" block...go with the spidertraxx 1.25" spacers....I rand my sport wheels with those spacers and 285s with 3" lift and didnt rub so 4" would be fine
  20. May 17, 2013 at 9:29 PM
    #2260
    StreetTaco4Me
    Bryan
    2001 4runner SR5
    Awesome thanks for the response:
    just want to confirm does this sound like the right mix for me
    maxtrac spindles (including brake lines) $510
    2" aal $85
    then either:
    or
    1.25" spacers in front only, not needed on back, right? would I get the spacers from headstrongoffroad also?
    thanks for your help, i would be lost without it!:)
