Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jun 27, 2013 at 8:14 AM
    #2421
    maxtracbob
    maxtracbob Well-Known Member
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    If you haven't re-tightened the u-bolts since you had installed them that would be the problem... U-bolts will stretch over time and they should be checked every once and a while...
  2. Jun 29, 2013 at 9:26 AM
    #2422
    JohnnieFive
    JohnnieFive Well-Known Member
    Johnny
    Anaheim, Ca
    07' Tacoma PreRunner TRD Sport
    I checked the u bolts, they were all still tight. Gonna see about picking up some 1/4 washers and try the carrier bearing drop and see how that works out
  3. Jul 1, 2013 at 8:20 AM
    #2423
    maxtracbob
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Hey bud
    Just stop by our shop and I will give you a pair of our spacers... You know since you are so close... Ok....
  4. Jul 1, 2013 at 5:40 PM
    #2424
    619ivanru
    619ivanru Well-Known Member
    San Diego
    08 prerunner offroad package
    Just got the truck back from the shop
    Lift got installed Spindles, Billis, OME 885
    Is it normal to have steering wheel vibration? It only happens after 50 mph
  5. Jul 1, 2013 at 5:42 PM
    #2425
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    Good looking out Bob!
  6. Jul 1, 2013 at 5:42 PM
    #2426
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Did you get an alignment? First things first...change wheels/tires?
  7. Jul 1, 2013 at 7:09 PM
    #2427
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Who did you have install it? Also new wheels? What else did you change?
  8. Jul 1, 2013 at 7:37 PM
    #2428
    619ivanru
    San Diego
    Wheels and tires are same as before
    Could it be because I used spacers for the wheels?
    Alignment was done by the shop
  9. Jul 1, 2013 at 7:54 PM
    #2429
    nfs257
    DFW
    She gone
    Which shop? Im local to you which is why I ask.
    And which wheel spacers?
  10. Jul 1, 2013 at 8:32 PM
    #2430
    619ivanru
    San Diego
    Install was done at Beyer Supreme Tires
    This morning on my way to work steering wheel shake was so bad at freeway speeds. I have no rattles, no sings of the problem being the spindles. Feels more like the problem could be the cheap lug centric spacers from Ebay.
  11. Jul 2, 2013 at 9:07 AM
    #2431
    maxtracbob
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    You know all of you guy's are my friends.... Whatever you need I will take care of you guy's.... Beyer is a great shop.... I had a customer that had tire shake and the SHOP blamed the spindles... HAHA.... The customer brought the truck to me and I replaced the cheap ass wheel spacers with the """ SPIDERTRAX """ wheel spacers and it was PERFECT... Please don't use cheap ass wheel spacers... Friends don't let friends use JUNK...... See Ya
  12. Jul 2, 2013 at 9:10 AM
    #2432
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Hey Bob! Can you PM me your shop addy? I'm cruising up to the OC tomorrow...got a weird 'clunk' sound when I go in reverse...not exactly sure what it is
  13. Jul 2, 2013 at 12:55 PM
    #2433
    TacoReefer
    TacoReefer Active Member
    Jacksonville, FL
    11' TRD DCSB
    Alright guys, I have been away on vacation for the last few weeks and didn't receive my spindles until I got back. Hope to be able to start the install after my trip to Texas next week. I want to make sure that I have everything ordered before I leave. So far, I have at the house maxtrac spindles (with extended brake lines) and Eibach coils.
    Since I will have approximately 5.6" of lift in the front. I am going to go with a 2" AAL and 2" block in the rear. Picking up a set of Deaver 2" AAL from a member today. Besides the blocks, what else do I need?
    Extended brake lines?, U-blot flip kit (dont do any wheeling). I want to make sure that I have everything that I need before I get started.
    Anything else that I am not thinking of?
  14. Jul 2, 2013 at 1:23 PM
    #2434
    nfs257
    DFW
    She gone
    LONGER U-BOLTS TO FIT THE LEAFS AND BLOCK!!!!!!!!!
    Also possibly ext brake lines for the rear.
    Also do you have a spring compressor or are you using the installed break down method?
  15. Jul 2, 2013 at 2:54 PM
    #2435
    TacoReefer
    Jacksonville, FL
    11' TRD DCSB
    I am having a shop put the coils on the shocks and attempting the rest by myself.
    Are extended brake lines needed with a 2" AAL and a 2" block? Will order them if needed, but want to make sure I need them.
    Also, will I need extended rear shocks?
  16. Jul 2, 2013 at 4:32 PM
    #2436
    JohnnieFive
    Johnny
    Anaheim, Ca
    Sweet deal! Thanks, can you pm me the shop address?
  17. Jul 2, 2013 at 8:37 PM
    #2437
    CBoy808
    CBoy808 The Original Sticker Dude
    Tacoma Mall Crawler
    I just read thru this whole 125page thread....I LOVE the stance these spindles give. Def on my list to do!
  18. Jul 3, 2013 at 8:45 AM
    #2438
    maxtracbob
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    No worries I can put it on here....
    Maxtrac
    4030 Leaverton ct
    Anaheim, Ca 92807
    We are here from 8 to 5 Monday through Friday... We will be closed tomorrow and Friday of this week though..... thanks bud
  19. Jul 3, 2013 at 9:20 AM
    #2439
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I know this has been asked before but not near a computer to search through here. I don't know much about backspacing and wheel dimensions but will 4" BS work with these? Thanks.
  20. Jul 3, 2013 at 9:41 AM
    #2440
    nfs257
    DFW
    She gone
    yes
