Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jul 13, 2013 at 8:38 PM
    #2461
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
  2. Jul 13, 2013 at 9:12 PM
    #2462
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  3. Jul 13, 2013 at 9:24 PM
    #2463
    dlooney
    Dennis
    Wilmington NC
    Yeah as much as Id like to go mid travel im 80% on road driving. And I'm on a pretty tight budget, been working my ass off all summer for this haha
  4. Jul 13, 2013 at 9:36 PM
    #2464
    nfs257
    DFW
    She gone
    You just want the look and lift that is level?
    if so look into just the spindles and brake lines up front and just an add a leaf in the rear.
  5. Jul 13, 2013 at 9:38 PM
    #2465
    dlooney
    Dennis
    Wilmington NC
    Well I want to do it right. And an AAL isn't an option, my leaf packs are completely flat in the back so new leaf packs are a must
  6. Jul 13, 2013 at 9:47 PM
    #2466
    nfs257
    DFW
    She gone
    Are yo ugoing new springs and shock up front and new shocks in the rear?
  7. Jul 14, 2013 at 7:27 AM
    #2467
    dlooney
    Dennis
    Wilmington NC
    I was planning on new shocks front and rear (i would need extended shocks anyway in rear) and no coils.
  8. Jul 14, 2013 at 8:30 AM
    #2468
    nfs257
    DFW
    She gone
    Then go with the setup from Headstrong and buy the extended length bilstiens for the rear and call it good.
  9. Jul 15, 2013 at 10:25 AM
    #2469
    maxtracbob
    maxtracbob Well-Known Member
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Didn't see you... did you come by.....
  10. Jul 15, 2013 at 7:47 PM
    #2470
    littlejouf22
    littlejouf22 Member
    Jordan
    Gainesville, FL
    05 Prerunner 4.0L Access Cab TRD OR
    6000k HID Hi/Low, 6000K Fogs, 2 Sundown Audio 12's 4 Cubic Foot Box Tuned at 32 Hz, LED license plate lights, UWS Low Profile Black Toolbox, Bilstein 5100s all fours, Maxtrac Spindles, 1.5" AAL and 3" Block, 5% Tint all Around
    Got her lifted up Maxtrac Spindles with Bilstein 5100's all fours. Nitto 35x12.50 Trail Graps :) Props to Toyota Tech for the install!
  11. Jul 15, 2013 at 8:06 PM
    #2471
    dlooney
    Dennis
    Wilmington NC
    Yew dawgy what are the billies set at and what you got in the rear? Any rub? Any regearing?
  12. Jul 15, 2013 at 8:22 PM
    #2472
    littlejouf22
    littlejouf22 Member
    Jordan
    Gainesville, FL
    Billies set at 2.5", 3" Block with 1.5" AAL for Rear, slight rub in reverse and sharp turns. Stock gears as of now..big loss in power but I think I'll deal for now. Anyone considering this lift its totally worth it. Makes a huge difference in ride height. The ride is surprisingly not as stiff as I would've thought by adding the blocks.
  13. Jul 28, 2013 at 2:14 AM
    #2473
    socal_av
    socal_av Well-Known Member
    Rudy
    Palmdale <CA
    2012 TACOMA DC LB Sport Mag Gray
    alot soon. hopefully
    does anyone modify or buy different bumpstops for the shocks after the lift?
  14. Jul 28, 2013 at 3:58 AM
    #2474
    nfs257
    DFW
    She gone
    No ur travel is still the same.
  15. Jul 28, 2013 at 4:28 AM
    #2475
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I put in wheeler superbumps and what a huge improvement. Totally worth it if you offroad. With my icons and superbumps it feels like a Cadillac offroad.
  16. Jul 30, 2013 at 1:49 PM
    #2476
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Hey guys, need some advice. I have had the Maxtrac Spindles for quite a while and been loving it.
    I'm going to get some new tires soon, but I believe I also have a bad shock due to cupping tire wear/tire becoming unbalanced. So I want to get new shocks put in before my new tires.
    Right now I have the spindles with Bilstein 5100s @ 0 with Eibach Springs ("1.6" lift") and in the rear I have All Pro 3" Leafs plus 1/2" block (to shift my axle forward).
    The truck has had a slight bro lean, but it looks good/level when you look at the bed line. I'm debating putting the stock springs back on instead of the Eibachs when I switch the shocks to new ones.
    So the queation: Go back to stock springs for a softer ride on road? (Drops front 1-1.6", slight rake?) Or keep the eibachs and current lift? Either way I will set @ 0 I believe.
    Opinions apreciated. Thanks!
    910CBE30-61C4-4350-8D0E-42BAC3BB531C-141_e2b2d185eda301ca66d7bd2df43f0e3fb77f7032.jpg
    Bird33 likes this.
  17. Jul 30, 2013 at 1:54 PM
    #2477
    TacoReefer
    TacoReefer Active Member
    Jacksonville, FL
    11' TRD DCSB
    How stiff is the ride? I am planning on installing spindles and eibachs in the next month. I was planing on 2" AAL and 2" block for the rear. The height looks perfect in the front, but if the ride is suffering, then lose the eibachs.
  18. Jul 30, 2013 at 2:04 PM
    #2478
    Relik
    Eddy
    Thousand Oaks, CA
    Honestly rides been good except for this last year got me thinking.....just can't remember the stock difference since its been quite a while and I also preloaded the stocks before so can't remember the no lift feel of the stock springs. Just helped a friend do 5100s at 1.75 and he says he noticed the stiffness increase.
    I also removed my sway bar, could help with on road driving to have on again. Think the eibachs allow you to do so without a lot of body roll due to stiffer springs. I might put the sway bar back on after. Also this bad shock/unbalanced tires could be what I've been not liking lately....
    So I guess the main argument is stock softer spring and lower front vs stiffer spring and the level it is at now.
  19. Jul 30, 2013 at 2:12 PM
    #2479
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    You think thats stiff...ive got my 5100s at 1.75 and the eibachs :eek:
  20. Jul 30, 2013 at 3:09 PM
    #2480
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    One thing you might want to consider is switching out the ebiachs for ome 883's which will be a lil softer spring but you will still keep your lift. You can still keep your 5100's set at 0 so there won't be any preload
