Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Aug 20, 2013 at 6:33 PM
    #2561
    BuckeyeTacoFL
    BuckeyeTacoFL Well-Known Member
    Derrick
    Lakeland Florida
    2013 Double Cab Prerunner
    http://www.headstrongoffroad.com/complete-lift-kits-tacoma-05-6-lug.html
    That's the lift I just did. My truck sits pretty level right now. Stock truck is higher in the front from factory by about and inch
  2. Aug 21, 2013 at 1:48 AM
    #2562
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    allpro 4" leaf pack
  3. Aug 21, 2013 at 9:44 AM
    #2563
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm running Maxtracs up front and All Pro Expo pack in the rear. I hear the standard pack doesn't quite bring you level. Even with 400 lbs of weight in the bed, I'm about level with the front, and the truck rides sm
  4. Aug 21, 2013 at 10:54 AM
    #2564
    Bruceleeroy30
    Bruceleeroy30 Well-Known Member
    Ed
    SF Bay Area
    2010 mgm Dbl Cab TRD OR PreRunner Short Bed
    Satoshi Grille, Yellow Lamin-x Fogs, Maxtrac 4" Spindle, All Pro Expo Leaf Pack, 5100s, inverted Daystar bumps
    I have Maxtrac up front with 5100s set at 0 and stock coils. AP Expos in the rear with extended 5100s. Truck rides just a little stiffer than stock with less body roll in turns. To me, the ride is really good. I still have the same amount of rake as stock, which is what I wanted and it hugs turns nicely
    3* shims and cb drop took care of the vibes, but i still need about a 1" drive shaft spacer.
  5. Aug 21, 2013 at 1:47 PM
    #2565
    VolcomTacoma
    Jeff
    NorCal
    A little stiffer? Have you gone over any bumps yet lol? Those expos are SUPER stiff without any weight on them. 'Bout gave my wife whiplash because i wasn't paying attention and went over a speed bump a little fast.
    I literally have a box of rocks and dirt back there to soften them up, till I can get proper weight on them (IE shell, recover gear, spares)
  6. Aug 21, 2013 at 1:55 PM
    #2566
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    That right there just swayed me away from the Expos. Problem is while I dont normallu have anything in the back other than a toolbox, I tow a 21' wake boat and a motorcycle or two on occasion and I need something that won't sag.
  7. Aug 21, 2013 at 2:05 PM
    #2567
    VolcomTacoma
    Jeff
    NorCal
    ^That's fine. All-pro specifically states that "On unloaded Tacomas, they will result in a 1" taller stance than the stated lift height of 3". The stated lift height is maintained with loads of 400-500 lbs of cargo."
    Which, is kinda BS, even fully loaded I'm level with my front end (Maxtrac Spindles) and unloaded I'm pulling easily 4 1/2" if not 5". That being said, about 300-400 lbs is a good sweet spot for me. haven't really tried specifically throwing in anything else. The other day at a concert I was super overloaded, but we're talking 3 passengers, 2 fully loaded big coolers, assorted tailgating equipment; so easily 1000 lbs and I had to set my compression on my shocks to 8 to keep from bottoming out on every bump. After that the ride was pretty smooth.
  8. Aug 21, 2013 at 2:40 PM
    #2568
    slaphappy
    slaphappy Mama didn't raise no fool
    Travis
    River Valley
    Silver Fresco 2010 FJ Cruiser 4WD
    So this might sound dumb, and no offense, but did most/all of you guys buy the Maxtrac's because you live in the desert? Or for 4" of lift? Or both? I too drive a PreRunner DCSB, but I have no sand :(
  9. Aug 21, 2013 at 3:15 PM
    #2569
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Lol...mine was just for the lift...I wanted my truck tall..but didnt want to buy a db lift for a 2wd..so bilstein 5100s and maxtracs got me where I needed to be...no sand here either
  10. Aug 21, 2013 at 3:58 PM
    #2570
    YotaMatt
    West Point VA
    I have 35s on stock gears with no issues..I do have the 4.0 v6 tho
  11. Aug 21, 2013 at 5:14 PM
    #2571
    Biscuits
    That's great feedback, thanks. The two leaf packs I have been considering are the Dakars and Expos, so we'll see.
  12. Aug 21, 2013 at 5:44 PM
    #2572
    YotaMatt
    West Point VA
    Man im not the one to ask...ive got so many pieces put together on mine...and im alot taller than most of these guys runnin spindles
  13. Aug 21, 2013 at 7:03 PM
    #2573
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    spindles and glass doesnt look right ;p
  14. Aug 21, 2013 at 7:11 PM
    #2574
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    I've ran both our springs, first our standards on my '05 and now our EX springs on my '08. In the front I'm running our LT kit at about 4" of lift. With the EX springs I'm sitting level with our Pack Rack, a PowerTank, Small Tool Bag, and 35" Spare, all adding about 300-lbs or so total.
    I also tow a 25' boat occasionally and haul my 2 boys' dirt bikes. The EX springs do handle it better, however, our standard springs have just under a 200 lb/in spring rate, so they will handle a few hundred lbs as well, just sitting lower until the weight is removed. The key is to not let any spring go into a negative arch which can permanently damage them. A properly set-up bumpstop will prevent this, and one like Timbren can actually act as a helper spring and handle added weight.
    One last thing... our EX springs, though firmer than our standards, will ride better than the OME Dakars due to not having a flat overload leaf to bottom out on. I too was skeptical at first since it is my daily driver, but I was pleasantly surprised that the engineers at our spring manufacturer were able to retain the ride quality while providing a higher spring rate. Of course, a properly valved, application specific shock doesn't hurt either.
    ...I hope that helps, but please let us know if you have any more questions or concerns about any of our products.
    Thanks!
    Sarah
  15. Aug 22, 2013 at 12:34 AM
    #2575
    Bruceleeroy30
    Ed
    SF Bay Area
    uhhh... yeah, i've gone over speed bumps. Going over a speed bump at just the right speed in ANY car/truck can be harsh. Shoot, I can give myself whiplash if I were to hit a speed bump just right in my Corolla! lol
    Unloaded, the AP Expos really aren't that bad to me when cruising at highway speeds or "around-town" driving. Obviously, when the truck is loaded with weight is when the leaf pack shines. With a bunch of camping gear and a tow hitch bike rack with two MT bikes, the ride does soften up, but my truck still maintains a slight rake. As my daily driver though, it's typically unloaded except for some bed racks and a cargo box. My wife's only complaint is having to climb into the truck when she's wearing a dress :D
    Sarah,
    Was wondering, how tall are those Timbrens?
  16. Aug 22, 2013 at 8:55 AM
    #2576
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Overloads come into play when the bed of the truck is simply that, loaded with a bunch of weight. Aside from this the overload on the OME packs don't really influence the ride at all and I'm sure there are many on here that would agree.
    Dakars are a two stage designed leaf pack, they flex real nice through the use of the first five leafs (not too layered so still plenty of flex) and than support a loaded bed with the use of the overloads, a good option for those planning to tow on occasion.
    Saying one leaf rides better then another is really a matter of opinion. All three packs are a great choice, but I think for the purpose of versatility one stands apart. It will be real interesting to see what SDHQ's pack end up being like. Looks as if they went with a design similar to that of the Dakars.
  17. Aug 22, 2013 at 5:09 PM
    #2577
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    So I'm sure this has been answered but I don't wanna read 130 pages. I am going full MT very soon. Plan is ICON 2.5 front resi and 2.0 rear resi and icon uppers. I want 0 preload on my coils so my plan was to go with a Maxtrac spindle up front. That will provide 4" up front which means I'll need at least 2" in the rear to be level. DO NOT want a bro lean! So the rear leafs I was gonna go with OME Dakars. My question is that those supply 2.75" in the rear according to ARB. If I remove the overload, what will the lift be in rear?? I'm afraid that removing the overload in the Dakars will bring it closet to 2" and then my front end will be too high with the spindles. Suggestions?? Thanks!
    Jmbradleymd likes this.
  18. Aug 22, 2013 at 5:16 PM
    #2578
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The expo's give almost an even lift and those are 4" lift leaf packs ...
  19. Aug 22, 2013 at 7:11 PM
    #2579
    ProForce
    Anthony
    Alaska
    But the front is almost 2" lower when stock. So a maxtrac is 4" in front right. So then wouldn't a 4" leaf pack still have you a rake?
  20. Aug 22, 2013 at 7:15 PM
    #2580
    nfs257
    DFW
    She gone
    In theory. Lol not sure how its actually working except most in here will tell you they had bro lean with anything other than the expo's or blocks... :notsure:
