Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Nov 5, 2013 at 8:58 PM
    #2861
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    If you plan on doing any sort of offroading I would suggest a coilover lift 100% over a spacer
  2. Nov 6, 2013 at 6:13 PM
    #2862
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Ok I've lurked around this topic enough. I want to go ahead and do the maxtracs. I have seen some members do a full 6" lift with there and that is what I am going for. Right now I have a 3" spacer lift kit. Basically 1.75" spacer in the front, and 1.5" in the back. Truck sits level. I know there are better ways to doing the 6" with the maxtrac than a spacer (i.e) bill's or CO.) and an all pro in the back. I will do it the right way but to just start it off I planned on using my spacer.
    I know I need extended break lines and I can order the spindles with them for around 530.00 shipped or may even better. What else am I going to need to finish.
    right now I am on stock wheels with 265/75/16. I know I will need bigger wheels and tires and those should be here Christmas. And then at tax time get the upgraded rear expo and bill's
    Just wanting to get this ball rolling and the truck sit level. I do 1% off roading and that is usually a dirt road. Pavement pounder mainly.
  3. Nov 7, 2013 at 7:01 AM
    #2863
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Did you see this?
    http://www.tacomaworld.com/forum/gr...-spindles-group-deal-headstrong-off-road.html
  4. Nov 17, 2013 at 7:26 PM
    #2864
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    anyone wanna sell your spindles?
  5. Nov 18, 2013 at 6:57 AM
    #2865
    Rusteenutz
    Rusteenutz Active Member
    Georgia
    08 TRD OFF ROAD
    Maxtrac spindles, rear extended bilsteins, color match grill, touchscreen radio,moto metal 951 16s,
    Tackling spindles n brake lines this weekend. Any tips for this going smooth?
  6. Nov 18, 2013 at 9:28 AM
    #2866
    anthony250f
    Anthony
    San Diego, CA
    Spay pb on the brake lines and use a 10mm flare nut wrench
  7. Nov 18, 2013 at 9:29 AM
    #2867
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Paint the spindles
  8. Nov 18, 2013 at 9:31 AM
    #2868
    Manwithoutaplan
    ID
    Make sure you have good Flare wrench or you will strip the brake line nuts. Get like Craftsman or higher. Dont get like auto zone or Oreilly's wrench.
  9. Nov 18, 2013 at 5:31 PM
    #2869
    Rusteenutz
    Georgia
    08 TRD OFF ROAD
    Damn just ran to autozone and bought one for this weekend. I'll swing by Sears tomorrow. Do you have to remove the bearing? I also read in directions about abs sensor any problems out of those?
  10. Nov 18, 2013 at 7:34 PM
    #2870
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    You do have to remove the bearing. But if you move the hub so the 4 bolts that hold the bearing in are backed out into the studs evenly it falls right out.
  11. Nov 18, 2013 at 9:03 PM
    #2871
    Rusteenutz
    Georgia
    08 TRD OFF ROAD
    Thanks for the quick replies... Any other advice would be greatly appreciated!! Just wanting to make it as easy as possible on myself
  12. Nov 18, 2013 at 9:10 PM
    #2872
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Make sure you route the ABS lines inbetween the 2 lower bolts on the ball joint BEFORE you tighten them up. Its really easy to forget about them when you are assembling the spindle to the control arms.
  13. Nov 19, 2013 at 6:04 AM
    #2873
    Astroman23
    Astroman23 Active Member
    Palm Coast, FL
    11 PreRunner DC TRD OR
    Fog Lights Anytime Mod Avid Off-Road Side Steps Avid Off-Road Light Bar Color-matched Satoshii Grill by River Rat 69 10g Skid Plate OEM Tool Box Maxtrac Spindles Bilstein 5100 Adjustable Front Shocks Bilstein 5100 Extended Rear Shocks for 3" Blocks
    X2
  14. Nov 23, 2013 at 7:45 AM
    #2874
    xTACOMAx
    xTACOMAx Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    What kind or brand of rear shocks are y'all using if you just have the spindles up front and how big of a block if you use a block instead of adding leafs?
  15. Nov 23, 2013 at 7:38 PM
    #2875
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Most use bilstein 5100 with no add a leaf or no block
    For add a leaf and block 5100 extended shock (which I believe is the 5150)
  16. Nov 23, 2013 at 7:45 PM
    #2876
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If lifting the rear over 3" you can use the bilstein BE5-B110-T5
  17. Nov 23, 2013 at 7:46 PM
    #2877
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    Arent 5150's piggyback? I believe its just extended 5100s...
  18. Nov 24, 2013 at 9:23 AM
    #2878
    xTACOMAx
    07 prerunner TSS
    Would you not be nose high if you just use the 5100 shocks? Cause I thought they were the same length as the stock ones?
  19. Nov 24, 2013 at 9:26 AM
    #2879
    nfs257
    DFW
    She gone
    Rear shocks dont affect lift at all.
  20. Nov 24, 2013 at 9:28 AM
    #2880
    xTACOMAx
    07 prerunner TSS
    I have seen the 5100 rear shocks but I haven't seen the 5100 extended ones does the extended ones proved lift in the rear?
