Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Mar 11, 2014 at 10:05 PM
    #3501
    bigtex2884
    bigtex2884 Well-Known Member
    Austin, Texas
    08 prerunner
    Retro Projectors, tinted tails, nfab nerf bars, avhp4000dvd, kicker 700.5, 2 8" comps, full components front and back, scangague 2, HID Fogs, Muth Mirrors, 5100s front, 90000s rear. Maxtrac spindles, all pro expo pack, level 8 tracker 16" x 8 1/2
    How are your suspension angles with the 5100s and 885s. I'm about to throw on the expo pack and was wondering what id need to do in addition to the max's to level the front out.
    I assume the expo makes it ass high?
  2. Mar 11, 2014 at 10:27 PM
    #3502
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    I actually have a very slight bro-lean going on. I have my camper shell, full size spare, tools, hi-lift, etc in the bed, so the expos are actually giving me about 3-3.5" of lift. I also have a yakima rack I throw on top of the shell for my spare and other gear when I go camping. I definately am pushing the weight on the expos. The 5100's at 0 + the 885's gave me 2.5" on the 4" maxtracs, so, i am sitting high up front. That's why I'm gonna get new fox's up front and not crank any lift on them. Hopefully that will level me out. The bro-lean is not too exagerated, so, it's not too bad, though.
    So, you have the 5100/885's too?
  3. Mar 11, 2014 at 10:38 PM
    #3503
    bigtex2884
    Austin, Texas
    08 prerunner
    Yeah I have 5100s and 885s. I put back the stock TRD coils when I installed the maxtracs. I picked up a pair of used expos and was reading with no weight they yield about 4" in the rear. Only thing I have in the rear is an undercover tonneau. I plan on throwing some sandbags to smooth out the ride if it's that bad. I'm debating trading my 885s for 884s or eibachs but then got to thinking I might need to put the 885s back on to level the front with the rear. I was hoping someone could chime in who had expos in the rear and maxs up front on what they did to level out.
    08 dcsb v6
  4. Mar 11, 2014 at 10:47 PM
    #3504
    darkgreentaco
    NorCaL
    Timberland Rocket
    I know I'll level out when i take off the 885's, because they are stacking another 2.5-3" on the maxtracs.
    I bet you will be level with your stock stuff and the expos. Just in case, keep the 885's. Your double cab weight might keep you from having the bro lean if you do throw the 885's back on.
    Are your 5100's at the 0 setting, too?
  5. Mar 11, 2014 at 10:53 PM
    #3505
    bigtex2884
    Austin, Texas
    08 prerunner
    Yeah currently 5100s at 0 with the TRD coils in the front
    AAL + 1"block in the rear now and the back is slightly higher
    I have someone local that will swap his 884s for my 5s if I need to raise the front a bit
  6. Mar 12, 2014 at 4:52 PM
    #3506
    Codybobby
    Codybobby Well-Known Member
    South Carolina
    09 prerunner
    Billet grille, tinted taillights, Injen cai, antennax 13" antenna, Cool white LEDs in interior lights, aero turbine 2525xl muffler
    Any pics of a side view of your truck?
  7. Mar 12, 2014 at 5:05 PM
    #3507
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    My MaxTrac package came today!! Got them painted and will be ready to go Saturday morning! Im going to be running the 4" MaxTracs, 5100's set at 1.75 up front and 2" tapered blocks with 1.5" toytec aal, and MT ext shocks.
  8. Mar 12, 2014 at 5:45 PM
    #3508
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Nice, you need to get an Orlando mod day going like we did last Saturday.
  9. Mar 12, 2014 at 6:24 PM
    #3509
    bigtex2884
    Austin, Texas
    08 prerunner
    Here's the only one I have right now
  10. Mar 12, 2014 at 11:37 PM
    #3510
    captwilks67
    captwilks67 The PreMudder
    Connor
    Chattanooga, TN
    2012 PreRunner
    WeatherTech rubber mats,
    Question. Will a spindle lift cause my steering wheel to shake at higher speeds. Reason why I ask is I met a guy who had spindles on his pre runner and it looked great but he said it shakes when he goes 55mph or higher. I am not sure if that is because a mistake in installing or it happens to all trucks.
    Second question: is there a 3" spindle lift currently being made??
  11. Mar 12, 2014 at 11:43 PM
    #3511
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    1: the reason the person most likely had steering wheel shakes are either from a bad alignment/balance, or the fact that his rims are missing the "hub centric ring" to not have the shakes.
    2: from what we know maxtrac makes the smallest spindle lift.
  12. Mar 12, 2014 at 11:53 PM
    #3512
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Total Chaos spindles only give a 3.5 inch lift....for $1399.00
  13. Mar 12, 2014 at 11:57 PM
    #3513
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    :eek:
  14. Mar 13, 2014 at 12:46 AM
    #3514
    captwilks67
    Connor
    Chattanooga, TN
    2012 PreRunner
  15. Mar 13, 2014 at 1:24 AM
    #3515
    Biscuits
    CST makes a high quality product; I ran their lift on my Silverado for years with no issue. However, you're looking at spending $1100+ on a 3.5" spindle when you can buy a 4" Maxtrac spindle for ~$500. Right now, Headstrong Off-road is having a pretty awesome sale, so I'd talk to those folks. Outstanding customer service as well. :)
    Worried about the quality of a spindle that you've perhaps never heard of before? That's fine, so was I at first. There is a thread dedicated to the Maxtrac spindles that basically answers every question and every permutation of every question you can think of. One guy even wrecked his Tacoma at 70mph I think, doing some hefty damage to it, and his Maxtracs spindles remained unscathed. That convinced me they're a damn good product.
    So if you decide to go with CST, that's up to you. You're going to spend a lot of money paying quality AND a name. But equal if not better quality can be found by going with Maxtracs and you save a hell of a lot of money in the process.
    If all you want is a lifted Tacoma using the stock shocks and whatnot, again, check out Headstrong. They have bare-bone Maxtrac 4" spindles +blocks and u-bolts for cheap as fuuu and other Maxtrac spindle lift bundles that include new great quality shocks and rear leaf springs for about the same price you'd pay for just the CST spindles alone. In fact, you can see Airdog's Tacoma on their website when he had the same setup. His build is pretty phenomenal if you care to check it out.
    I'm no shill for Headstrong, but they're the go-to vendor it seems for Maxtracs and like I said their customer service is outstanding.
    Hope this helps.
  16. Mar 13, 2014 at 6:01 AM
    #3516
    jo35
    jo35 Well-Known Member
    Joe
    Orlando, FL
    2011 SR5 PreRunner
    Maxtrac Spindles Bilstein 5100 shocks @.85 Eibach springs Dakar leaf pack 1" block 3 degree shims Bilstein extended 5100 shocks CB spacer Method double standard wheels 285/75/17 Terra Grapplers BHLM w/ HID's and custom LED fogs 2011 color matched sport grille
    Sounds awesome it's gonna look sick! I noticed you have the pro comp 7036. What's the backspacing on those? They may not fit.... for 16 inch wheels it needs to be at least 5.0 and for 17 at least 4.75
  17. Mar 13, 2014 at 6:06 AM
    #3517
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Negative 4.5 on 16" wheel and 4.75 on 17" wheel
  18. Mar 13, 2014 at 6:10 AM
    #3518
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    I'm sure you're referring to my truck which if I have met you awesome. If not my shakes are not from my spindles it is from some demon from the 10 gate of hell that no one can figure out. However I did finally find some loose bolts up top on the uca that may or may not be causing my issue. Last night after the drive I was so pissed that I don't know if my brain is wanting me to think it's fixed so I will stop stressing or if it really did fix it. Either way only time will tell and I won't know that until later today
  19. Mar 13, 2014 at 11:12 AM
    #3519
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    So will 5.0 b.s. work on 18"?
  20. Mar 13, 2014 at 11:36 AM
    #3520
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    You would be the first! lol
    There is one guy in here with 18's I think... hopefully he will chime in.
