Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Mar 1, 2012 at 5:40 PM
    #401
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    the maxtrack spindle and a pro comp aal in the rear, i want some new tires though these look like slicks i need some muds
  2. Mar 1, 2012 at 5:55 PM
    #402
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Yamaha,
    You still running the factory coils and shocks? Any way you could post what your measurement is from the center of the hub to the fender? How is your ride?
    Thanks!
  3. Mar 1, 2012 at 6:03 PM
    #403
    yamaha73
    Royce
    Madera ranchos
    from the center of my hub to the fender is about 23.5 inches if that sounds right, i believe i did it right haha, and yea I'm running stock everything besides spindle and an aal for the back.
    the ride is back to stock so much better, i always told myself my spacer wasn't that bad of a ride but now that i got the spindle WOW lol now i remember wat it rode like wen i first got her. only problem is i rub my front fender now at full lock so i gotta do a little trimming
  4. Mar 1, 2012 at 6:17 PM
    #404
    HRDTACO
    HRDTACO Well-Known Member
    Sean
    Long Beach
    '12 Prerunner DCLB
    to come!
    I'll be ordering some of these hopefully by the end of this month! But they won't be going on for a while, not until I get some wheels and tires.
    So I can run my stock suspension up front, and put some billies 5100 in the rear with a 2" tsb AAL?
  5. Mar 1, 2012 at 6:29 PM
    #405
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Looks great, just a bit of lean but not bad. Maybe another leaf for that extra " and you'd be there. I like that side exit :)
  6. Mar 1, 2012 at 6:38 PM
    #406
    yamaha73
    Royce
    Madera ranchos
    thanks man, and theres like a 3 leaf pack thats softer but gives u some extra height i believe that i might get, and i go back and forth witth the side exit, i like it but i also like the clean turn down look too
  7. Mar 1, 2012 at 7:51 PM
    #407
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I finally finished the lift install. Gonna get alignment tomorrow. But I have the ABS and Traction lights on!
    Tried resetting battery...still there! :( anyone else have their lights come on after install? I'm sure the sensors are connected, maybe at some point it tugged too hard on cable? I dunno...might have dealer look at it next week when I go in for oil change
  8. Mar 1, 2012 at 8:23 PM
    #408
    Manwithoutaplan
    ID
    Hey just for shit s and giggles check your fuses info the engine compartment.
  9. Mar 1, 2012 at 8:29 PM
    #409
    Relik
    Eddy
    Thousand Oaks, CA
    Gonna check on them in the morning. Also after some searching it's seems that the ABS wire that comes down might have been damaged. Seems possible, I remember it's would get taught removing parts and the stock brackets would pinch the wires. People have got if after lifts...Might have to see if I can pull a code or just check both for continuity and rebuild them
  10. Mar 1, 2012 at 11:16 PM
    #410
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
  11. Mar 1, 2012 at 11:31 PM
    #411
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    so my brother recieved his eibach's today. I was kinda jealous because I still have my stock coils and bilstein's at 1.75". It got me thinking..."What if I get some and go down to .85 on my 5100's.." On my 30 min drive to work today, I was thinking "What if I can have a better ride with that setup?" hah... I don't want to lose any height though....thoughts?
  12. Mar 1, 2012 at 11:32 PM
    #412
    Manwithoutaplan
    ID
    no you can blame hiatt he is the one that was messing with it :D
  13. Mar 1, 2012 at 11:43 PM
    #413
    TACWUT
    San Diego
    12 prerunner DC
    Why not set 5100 at zero n put the eibach on?
  14. Mar 1, 2012 at 11:46 PM
    #414
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    that'll lower my front even more...my ass is higher right now...no bueno for me...
    from what i've read, the eibach and 5100's at 0" will give a 1-1.3" lift at most for DC's...
  15. Mar 1, 2012 at 11:50 PM
    #415
    Manwithoutaplan
    ID
    looks good man :thumbsup: how much is their difference from the front and the back??
  16. Mar 1, 2012 at 11:51 PM
    #416
    TACWUT
    San Diego
    12 prerunner DC
    Oh ok i thought it was like 1.6 and. 15 would be unnoticed
  17. Mar 1, 2012 at 11:56 PM
    #417
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    exactly an inch...i guess the 1.6" is for an access cab. I could be wrong...i've read so many different threads and they all say different things...only thing is to waste money on eibach's and see for myself...i do not wish to go any lower than 26.5" in the front though...
  18. Mar 2, 2012 at 3:15 AM
    #418
    TACWUT
    San Diego
    12 prerunner DC
    Your shit must b high. Any higher for me n i wont fit in my garage.
  19. Mar 2, 2012 at 3:51 AM
    #419
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I believe that eibach's and 5100's at .85 will give you 2.5". I've talked to a few guys running this and they seem to love the setup, they said the ride is great. Keep in mind though, I was also told that eibach does not recommend pre-loading their springs.
  20. Mar 2, 2012 at 5:49 AM
    #420
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    I'm going to give it a try...next time i see some eibachs on here for a good price...i just bought some for my bro off here...
