Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Mar 5, 2012 at 8:12 PM
    #461
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Brake lines!!!! Definetly the hardest. And not having a big enough jack... lol the brake lines took almost 2 hours. Probably 8 hours total because of that.
  2. Mar 5, 2012 at 8:40 PM
    #462
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Alright. Ya I helped derrick do his and that was the hardest part.
    How much farther do the wheels stick out vs stock?
  3. Mar 5, 2012 at 8:53 PM
    #463
    nfs257
    DFW
    She gone
    Not quite sure. I have spidertrax and the spindles.
  4. Mar 5, 2012 at 9:41 PM
    #464
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    So what kind of issue are guys having when it comes to swapping out the brake lines?
  5. Mar 5, 2012 at 9:45 PM
    #465
    Hiatt1991
    Hiatt
    Ventura, CA
    Just the process of bleeding the brakes and unscrewing the lines since they are torqued on so tight.
  6. Mar 5, 2012 at 10:58 PM
    #466
    Hiatt1991
    Hiatt
    Ventura, CA
    Have any of you guys had problems with these?
  7. Mar 5, 2012 at 11:00 PM
    #467
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    The spindles? If so, no.
  8. Mar 6, 2012 at 1:06 AM
    #468
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    No problems with them, I love em but need to take it out to the desert to run it
    How much better are u guys likening the 5100s? I want new shocks just debating if I should be cheap and go with 5100s or do some kings the kings would be a little while though
  9. Mar 6, 2012 at 1:29 AM
    #469
    Hiatt1991
    Hiatt
    Ventura, CA
    I got mine set at 2.5 and I still think it rides nicer than stock.
  10. Mar 6, 2012 at 6:23 AM
    #470
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    I think the biggest problem for us was yes bleeding of the lines and those dam nuts on the brake lines being on so freaking tight. Also, there is no room on the back of the spindle where the nut goes onto the UCA. It was tight in there. But then again I did it on the truck cause my LR UCA's were already in there. So not much room there I still don't think we got that nut tight enough there is a like 1" gap between the spindle and UCA?? I guess we will try to tighten later on.
  11. Mar 6, 2012 at 6:48 AM
    #471
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    Use a swivel attachment on an impact gun and reconnect it first when putting on your new spindle. With nothing connected to the spindle but the UCA you can turn it substantially more and makes getting at that bolt a lot easier. The swivel on the impact gun is the key, all shops will have one.
    As for the brake lines, flare end wrenches are the key, plain and simple. Having done brake lines on my Tacoma twice now, I can say that now I know the easy way to get the clips off by using the "shaft" of a screwdriver and prying them off using the metal head of the brake line as a fulcrum, and I have these wrenches, the brakes are easy.
  12. Mar 6, 2012 at 7:36 AM
    #472
    Hiatt1991
    Hiatt
    Ventura, CA
    Damn an inch!? Be careful. That sounds really dangerous.
  13. Mar 6, 2012 at 8:26 AM
    #473
    Hiatt1991
    Hiatt
    Ventura, CA
    So what did you guys set your bilstiens at?
  14. Mar 6, 2012 at 8:38 AM
    #474
    nfs257
    DFW
    She gone
    I have the Eibach springs so I left the 5100's at 0. The drivers side is maybe 1/2" higher because of the "taco lean"
  15. Mar 6, 2012 at 8:52 AM
    #475
    Hiatt1991
    Hiatt
    Ventura, CA
    OK so with eibachs that's like 1.6 inches (preload lift) right?
  16. Mar 6, 2012 at 8:54 AM
    #476
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    Mine are at 1.75...i convinced my bro to sell me his eibachs and that i would.give him $100 for spindles when they became available..he agreed...so now.im just waiting for the top plate spacer to get here...i hope that setup gives me a bit more lift than the bils at 1.75....and a softer ride...its npt bad now, but im hoping its better with the eibachs and .85
  17. Mar 6, 2012 at 8:54 AM
    #477
    nfs257
    DFW
    She gone
    The springs alone are supposed to give you 1.6".
  18. Mar 6, 2012 at 9:42 AM
    #478
    Hiatt1991
    Hiatt
    Ventura, CA
    I see. What is the measurement for the rear on yours? Center hub to the edge of the funder.
  19. Mar 6, 2012 at 1:45 PM
    #479
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    How do you remove the unit bearing as described in the instructions?
  20. Mar 6, 2012 at 1:51 PM
    #480
    nfs257
    DFW
    She gone
    On the hub you have the studs... Back the 4 bolts out till the each push on the studs and it should just come out in your hand.
