Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jun 26, 2015 at 10:59 AM
    #6401
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    35's and stick with 4" of lift all around...and lots of alcohol instead of anything else
  2. Jun 26, 2015 at 12:10 PM
    #6402
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Well I already own the springs so I'm atleast going to 6.5" and I'm 16 and don't drink so no need to save for beer
  3. Jun 26, 2015 at 12:12 PM
    #6403
    VolcomTacoma
    Jeff
    NorCal
    Ahhhhhhhhhhhhhhhhhhhh I see, now.
  4. Jun 26, 2015 at 12:16 PM
    #6404
    VolcomTacoma
    Jeff
    NorCal
  5. Jun 26, 2015 at 12:25 PM
    #6405
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    It's only an inch and a half difference. Id go up more I the rear if I wouldn't have to buy new shocks when mine only have 500 miles on them
  6. Jun 26, 2015 at 12:29 PM
    #6406
    VolcomTacoma
    Jeff
    NorCal
    7" up front and 4" in the rear....
  7. Jun 26, 2015 at 12:33 PM
    #6407
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    Volcom, that picture you just posted, do you have any specs on that lift? It appears to be a 5 lug, and I was under the impression there wasn't much available with regard to lifts for those.
    dtalley18 likes this.
  8. Jun 26, 2015 at 12:34 PM
    #6408
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    But then calculate in the current rake and the front will end up 1.5" taller than the rear
  9. Jun 26, 2015 at 12:46 PM
    #6409
    VolcomTacoma
    Jeff
    NorCal
  10. Jun 26, 2015 at 1:10 PM
    #6410
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Who else stacks lifts other than people in this thread? And the people with a 6" DB and 3" body lift...
  11. Jun 26, 2015 at 1:17 PM
    #6411
    VolcomTacoma
    Jeff
    NorCal
  12. Jun 26, 2015 at 1:20 PM
    #6412
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    But it's America and you are intitled to you opinion. And to marry someone of the same sex.
  13. Jun 26, 2015 at 1:26 PM
    #6413
    mromeo
    mromeo Well-Known Member
    Atlanta GA
    2016 DCSB TRD OR
    None yet
  14. Jun 26, 2015 at 1:26 PM
    #6414
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    No point in adding a BL. You'll have more than enough room to clear 33's with 7" of lift. 35's will clear as well with minimum trimming.
  15. Jun 26, 2015 at 1:29 PM
    #6415
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Mine totals 6.25 in front & I'm running 35's. They rub the cab mounts every now & then.
  16. Jun 26, 2015 at 1:40 PM
    #6416
    VolcomTacoma
    Jeff
    NorCal
  17. Jun 26, 2015 at 2:55 PM
    #6417
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    Plus the 35's will look so much better. I just went up to 315/70R17 because the 285's looked too small for the lift
  18. Jun 26, 2015 at 5:48 PM
    #6418
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    No. Not mad. Just agreeing to disagree. And vocalizing my disapproval of same sex marriage.
  19. Jun 26, 2015 at 5:50 PM
    #6419
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I only said BL because it appears the cab mount relocation kit is designed to use a BL. Either way I would like to do the relocate rather than just chopping it.
  20. Jun 26, 2015 at 5:51 PM
    #6420
    VolcomTacoma
    Jeff
    NorCal
    Hey I'm fine with it, now the gays have nothing to complain about anymore. I'm just tired of seeing it in the news.
