Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jul 20, 2015 at 10:39 AM
    #6601
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Ok you have the non-tsb springs. Seems like everything I've seen says an add a leaf gives 2" on non-tsb springs.
  2. Jul 20, 2015 at 1:29 PM
    #6602
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Stop suggesting AALs to non tsb leafs.
  3. Jul 20, 2015 at 2:11 PM
    #6603
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Well I know the best suggestion is new leaf packs but some people don't have a budget for that so I would say an aal is better than a block.
  4. Jul 20, 2015 at 3:00 PM
    #6604
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    People don't have money these days. AAL if you one of them.
  5. Jul 20, 2015 at 3:50 PM
    #6605
    VolcomTacoma
    Jeff
    NorCal
    Yea but a year (tops) later they are back on here complaining about the dead leaf pack
  6. Jul 20, 2015 at 4:11 PM
    #6606
    Jocoma
    Jocoma Well-Known Member
    Jo-mama
    Olympia,WA
    08 Prerunner SR5 Rugged Trail
    Home made satochi trd grill BFG AT 265 75 16 Dipped badges TRD stub antenna More to follow : spindle lift,Halo lights, Kicker sound sytem ,Slotted rotors TRD Seat covers When the cash starts flowing
    I don't know what tsb stands for.
    So adding a leaf is not good why Volcom?
    (Dead leaf ) just seen you last post
  7. Jul 20, 2015 at 4:30 PM
    #6607
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    TSB = Technical Service Bulletin
  8. Jul 20, 2015 at 4:44 PM
    #6608
    VolcomTacoma
    Jeff
    NorCal
    TSB is basically an unannounced minor recall. A recall is issued when there is a safety issue. A TSB is opened when there are enough reports that a change must be made. Bpth are covered under warranty, TSBs are just not announced and most deslers wont tell you about it if you dont already know
    Personally i consider AALs to be like a bandaid on a gunshot wound. TSB leafs or not, the stock packs suck and are usually flat pretty quickly if you use your bed at all. I realize not everyone has the budget for a new leaf pack, but i think people are wasting money on AALs when theyre just gonna replace it again down the road
  9. Jul 20, 2015 at 4:51 PM
    #6609
    Jocoma
    Jo-mama
    Olympia,WA
    I did get that recall notice and haven't taken it in yet.
    Just got the frame recall notice but I agree if your gonna spend the money might as well
    be worth it .
  10. Jul 20, 2015 at 6:06 PM
    #6610
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I would recommend replacing the leaf pack when you do the lift. If you can't afford it wait till you can then do it. Doing what you are going to do correctly is never a cheap proposition. If it is your doing it wrong. Can you tell I sell for a living? I deal with people cutting corners all the time. In the end they regret not making the right choice. Nevertheless, like they say in the movie Airplane, "You have to decide".
    Fox suspension arrived today! I will post some pictures as soon as I can. Didn't realize how huge these suspension products are. It is getting me anxious now to get this stuff installed. Remember, patience. I say that now when it comes time to put this together I will be sweating, cursing, angry.....Patience.
  11. Jul 20, 2015 at 6:22 PM
    #6611
    Jocoma
    Jo-mama
    Olympia,WA
    I hear that brother cutting corners and being complacent was 2 things I learned not to do in Afghanistan. As for your new Fox gear man like Christmas morning!
    Good luck on the install definitely post some pictures after.
    sgtnewundies likes this.
  12. Jul 20, 2015 at 6:28 PM
    #6612
    DelaneyJordan
    DelaneyJordan Well-Known Member
    Metro Atlanta
    07 Speedway Blue TRD PreRunner
    Coming soon
    I plan on lifting front with Eibachs and spindles so about 5-5.5 inches of lift.. What leaf pack do y'all recommend to level the truck w/o using blocks?
  13. Jul 21, 2015 at 4:11 AM
    #6613
    sgtnewundies
    Eric
    14 trd sport red
    Thanks for your service! Yes I am like a kid in a candy store!
  14. Jul 21, 2015 at 4:12 AM
    #6614
    sgtnewundies
    Eric
    14 trd sport red
    You can get them made. I think Alcan leafs? You are on the right track.
  15. Jul 21, 2015 at 4:13 AM
    #6615
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Depending on the difference from front to back All Pro standards will give you 3" & their expos will give you 4".
    Or you can go custom with Alcan like sgtnewundies suggested.
  16. Jul 22, 2015 at 2:34 PM
    #6616
    allenpark
    allenpark Active Member
    Allen
    Orange County, CA
    2007 Tacoma Indigo Ink Pearl Double Cab TRD Sport
    So I'm finally pulling the trigger and I'm planning on buying a set of Maxtrac spindles for the front and OME nitro with Dakars for the rear.
    I live in an apartment complex that does not allow me to work on my car plus I don't have any tools on me at the moment. If anyone can direct me or help me find someone or any kind of shop that will help with the install that would be awesome.
    I am also going to be in Southern California mid-August if anyone wants to help out
    Thanks!
  17. Jul 22, 2015 at 3:18 PM
    #6617
    VolcomTacoma
    Jeff
    NorCal
    If you were coming to NorCal you could buy mine with free install :)
  18. Jul 22, 2015 at 3:18 PM
    #6618
    VolcomTacoma
    Jeff
    NorCal
    *plus a small convenience fee of $50
  19. Jul 22, 2015 at 9:06 PM
    #6619
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Post in your regional thread and find some local guys willing to help out.
  20. Jul 23, 2015 at 4:56 PM
    #6620
    TRDrunner
    TRDrunner Well-Known Member
    Victor
    Vacaville
    2014 Tacoma TRD Offroad
    Did anyone ever end up buying your rear springs?
