Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Aug 6, 2015 at 6:15 PM
    #6741
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I got them set at 1.75 but also have Toytec 1/4" spacers on both sides. So that's about 2.25" plus 4" from the spindles & I still rub when I have people in the truck. Mainly on the cab mount at full lock. I want to adjust them up to 2.5 so I'll be 7" total & see if that helps with the rubbing.
  2. Aug 6, 2015 at 6:41 PM
    #6742
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    FWIW at 7" or a little over that on 285's and spidertrax rubbing is not even thought of. I did trim for 4" then went to 7" so that could help.
  3. Aug 6, 2015 at 6:59 PM
    #6743
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah when I had 285's they didn't rub & I just had the spindles & at at 1.75, so like 5.75"
  4. Aug 6, 2015 at 7:03 PM
    #6744
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I figure with the spacers they swing more like a 315 without spacers :notsure: it rubbed pretty hard at 4" before trimming and after trimming at 4" only rubbed backing out of my driveway at full lock.
  5. Aug 6, 2015 at 7:12 PM
    #6745
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    That's how mine is right now. Every once in awhile it will rub backing out at full lock when it's just me but if I have the truck full of peeps then it will do it more times than not. The extra weight compresses the suspension just enough so they rub so I figured max the 5100's out which is another 3/4" & than should help.
  6. Aug 6, 2015 at 7:12 PM
    #6746
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    My current setup is 5100's all around without the top plate spacer, LR UCA's, a 1.5" AAL, and wheels aith a 4.5" bs. I have a cab mount chop and did some very minor trimming on the bumper and fender liners and my 285's don't rub at all. I plan on slowly redoing my suspension. First up are the spindles, then all pro 3" leaf pack, and then some fox or icon 2.5" coilovers.
  7. Aug 6, 2015 at 7:17 PM
    #6747
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    You already have the cmc done & that's mainly where mine rubs. There & occasionally on the plastic liner in the front on the bottom.
  8. Aug 7, 2015 at 7:06 PM
    #6748
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    I've done a cms already but need to take more off I catch my lugs when I turn sharp
  9. Aug 8, 2015 at 8:21 AM
    #6749
    xTACOMAx
    xTACOMAx Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    Hey guys if I was to run Maxtrac spindles could I run 33/12.5 without hitting the spindle? The rims would be 20x10 with a -24 offset with a 4.5" back spacing.
  10. Aug 8, 2015 at 2:42 PM
    #6750
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Guys having some difficulty with the front brake lines. I tried the top connection first with a 10mm flare nut and it started to strip so I stopped. Does the clip need to be removed at the bracket first? Its the u-shaped clip silver color. Does the hard side turn or flex side of the line? I noticed on the new lines its the flex side that is tightened on.....Thanks!
    Also what are you guys doing to slow the brake fluid from coming out while you switch it out?
  11. Aug 8, 2015 at 3:32 PM
    #6751
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I didn't have any trouble getting mine loose. It's that flex side that loosens & I just switched it as fast as I could, no way to really stop it cause you can't crimp the hard lines or anything like that.
    Just switch them as fast as you can & refill the reservoir.
  12. Aug 8, 2015 at 5:58 PM
    #6752
    sgtnewundies
    Eric
    14 trd sport red
    Thanks Spruce! I owe you one! I will attempt again tomorrow.
  13. Aug 8, 2015 at 6:04 PM
    #6753
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No problem, another little tip is to connect the top or reservoir side first & then the caliper side. That way gravity will kinda fill the new line & it won't have so much air in it when you bleed them, if that makes sense.
    And you don't owe me anything, haha glad to help. :cool:
  14. Aug 8, 2015 at 6:12 PM
    #6754
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    things are gonna hopefully change next week :D, im excited, part 1 of 3 :spy:
  15. Aug 8, 2015 at 6:24 PM
    #6755
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    :popcorn::spy:
  16. Aug 8, 2015 at 6:34 PM
    #6756
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    Has anybody experienced Taco-lean with the spindle lift? From what I've read it's pretty common with lifts and it happens on the driver side?
  17. Aug 8, 2015 at 6:38 PM
    #6757
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    Not with spindles. Taco lean comes when you start putting on aftermarket struts and springs. If you plan on using the stock shocks, you'll be fine. I'll be running coilovers with mine therefore I'll have to adjust for the lean
  18. Aug 8, 2015 at 6:39 PM
    #6758
    Taco gator
    J.D.
    Lakeland, FL
    2014 2wd Taco
    Ah I see, thank you
  19. Aug 8, 2015 at 7:35 PM
    #6759
    Taco gator
    J.D.
    Lakeland, FL
    2014 2wd Taco
    Yea that's what I thought when I first heard about it
  20. Aug 8, 2015 at 7:40 PM
    #6760
    Alfuh
    2006 Prerunner
    I have a few mods
    :D
