Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Oct 9, 2015 at 4:33 PM
    #7081
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Yes
  2. Oct 9, 2015 at 4:34 PM
    #7082
    xTACOMAx
    xTACOMAx Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    Ok thanks!
  3. Oct 10, 2015 at 5:00 AM
    #7083
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    No axle shim. If you haven't checked yet I would check and make sure all bolts are torqued properly.
  4. Oct 10, 2015 at 11:56 AM
    #7084
    jaddels
    jaddels Well-Known Member
    Jeff
    Phoenix, AZ
    '12 Prerunner
    Maxtrac Spindles, SCS SR8 wheels, All-Pro Sliders, Kings front and rear w Dakar pack
    Thanks. Checked all torque specs just the other day. I'll think I'm going to add in the D29XL AAL to the pack to lift the rear up a bit more. I'll have to keep dignossing vibes but better to make this add on now then correct it just to start all over again.
  5. Oct 10, 2015 at 3:06 PM
    #7085
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Sounds smart. You could just get some mt's and do like I do and blame the vibes on the tires.
  6. Oct 10, 2015 at 3:13 PM
    #7086
    jaddels
    Jeff
    Phoenix, AZ
    '12 Prerunner
    Ha ha right!? Actually I already got em, been sitting in the garage mounted up and waiting to replace the stock tires. Figured it was just easier to try and chase down vibes before making the switch.
  7. Oct 10, 2015 at 3:36 PM
    #7087
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    How far is your drive shaft pulled out from the transmission? Should be flush. Just wondering if a driveshaft spacer might help. Also I found that the bigger the CB drop spacer the more vibs I had(I bought the 1.5" Beefed Taco drop and it made it much worse). I wound up finding a sweet spot using the OME spacer plus I made another one from some stock I had, for a total of about 9/16" thick.
  8. Oct 10, 2015 at 3:43 PM
    #7088
    jaddels
    Jeff
    Phoenix, AZ
    '12 Prerunner
    It's slightly pulled out but almost not worth a spacer. I looked before the lift to confirm it was flush and post lift its not even 1/4" out. I researched some driveline spacers and it seem most start in the 3/4" realm. Currently my CB spacer consists of the OME spacer plus two washers so probably just over where you're at. It's just one of those things. I've tried almost everything others have found success with but not working for my particular rig.
  9. Oct 10, 2015 at 4:32 PM
    #7089
    Justinlhc
    Justinlhc Not looking for a relationship
    I was going to say the same. Not only rare, but badass looking. :thumbsup:
    SpruceTaco likes this.
  10. Oct 11, 2015 at 6:04 AM
    #7090
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Thanks!!
  11. Oct 15, 2015 at 6:11 PM
    #7091
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
  12. Oct 15, 2015 at 6:16 PM
    #7092
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So I really want 40's 33's are way too small
  13. Oct 15, 2015 at 6:17 PM
    #7093
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    :wave: How's the tundra treating you?
  14. Oct 16, 2015 at 8:36 AM
    #7094
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    40's well be to big unless you go more lift relocate cab mount and tub the firewall
  15. Oct 16, 2015 at 8:40 AM
    #7095
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    35s are a nice size, I eventually want 37s or 40s. even with 37s. you still have to tub the firewall and relocate the body mounts.....40s are gonna be A LOT of work to fit lol
    Dr. Jekyll likes this.
  16. Oct 16, 2015 at 7:39 PM
    #7096
    Kwright04
    Kwright04 Well-Known Member
    Corpus Christi TX
    2013 PreRunner SR5
    So I'm gonna put on 4" spindles and 5100's on Monday. I have a 2" AAL in the rear. If I set the 5100's to the second setting would the front be too high?
  17. Oct 16, 2015 at 8:13 PM
    #7097
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Probably, it would be about an inch higher. The 4" Maxtrac lift/level kit comes with 2" blocks. 2" difference is about the norm, but then again mine seems like it was an inch. Mine measures the same front & rear, it looks level & the front is lifted right at 6.5" & the rear is 5.5". Best thing to do is measure hub to fender front & rear while it's stock & that will tell you how much more the front needs to be lifted than the rear. Of course this only matters if toy want it level.
  18. Oct 16, 2015 at 8:24 PM
    #7098
    Kwright04
    Corpus Christi TX
    2013 PreRunner SR5
    Oh okay well I only have the spindles no blocks. I was thinking if I put the shocks in the second setting it would drop about an inch if I put a plate bumper on it. Does that sound right?
  19. Oct 16, 2015 at 8:30 PM
    #7099
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Block are for the rear & spindles only with nothing in the rear will definitely put it nose high by about 2".
    Blocks or aal either way it's like 2".
    I don't have a bumper so I'm not positive how much it will drop but it will drop.
  20. Oct 16, 2015 at 8:31 PM
    #7100
    Kwright04
    Corpus Christi TX
    2013 PreRunner SR5
    Okay bad ass thanks bud
