Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Dec 17, 2015 at 10:16 AM
    #7301
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    I gotta get my 5100s installed
  2. Dec 17, 2015 at 10:17 AM
    #7302
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    @Timbo89 is about halfway between Tampa & Orlando. :D
    Timbo's Customs likes this.
  3. Dec 17, 2015 at 10:46 AM
    #7303
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Yes I am. I'm right in the middle.
  4. Dec 17, 2015 at 11:02 AM
    #7304
    surfer311
    surfer311 Well-Known Member
    Orlando, Florida
    2015 DC PR SR5
    Maxtrac spindles, OME 887s, Bilstein 5100s, Fabtech uniballs, AllPro Expos, 1.5" tapered blocks, BFG KO2 285/70r17, 17x9 XD Addicts, Nfab step bars, Avid light bar, BPF recovery hook, Undercover classic
    I'm in Orlando and can drive anywhere :burnrubber:
    The bad news is all-pro is currently out of expos so will have to wait to install the maxtracs.
  5. Dec 18, 2015 at 8:07 AM
    #7305
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    Did any of ya'll running the 35's have to do the CMC?
  6. Dec 18, 2015 at 8:11 AM
    #7306
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    Lots of other factors to consider other than just tire size. Do you plan on just the 4" spindles or stacking more lift on top of the spindles? I will just say with 285's and a 1.25" wheel spacer I didn't come close to the cab mount with only 4" of lift.
  7. Dec 18, 2015 at 8:37 AM
    #7307
    Timbo's Customs
    Timothy
    Lakeland FL
    35s yes you may want to do the chop
  8. Dec 18, 2015 at 8:41 AM
    #7308
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Haven't done the chop but it wouldn't hurt, I'm rubbing in reverse. I have a little adjustment left & would like to go up a little more to see if that helps before I think about doing the cmc.
  9. Dec 18, 2015 at 9:03 AM
    #7309
    Timbo's Customs
    Timothy
    Lakeland FL
    Just do it
  10. Dec 18, 2015 at 9:25 AM
    #7310
    Team Flatline
    Eric
    Up a creek, Fla
    PreRunner
    Thanks guys,
    Guess I should have mentioned that I'm at 6.5" or so on MaxTracs and Icons (factory setting) that have additional room to grow ;-)
  11. Dec 18, 2015 at 12:42 PM
    #7311
    TXAggieTRD
    TXAggieTRD Well-Known Member
    Andrew
    TX
    '11 Pre-Runner V6 TX TRD Package
    for sure
  12. Dec 18, 2015 at 12:48 PM
    #7312
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No welding skills. :(
  13. Dec 18, 2015 at 1:06 PM
    #7313
    Timbo's Customs
    Timothy
    Lakeland FL
    Mine is open. Haven't welded mine at all:welder:
    I'm too busy and lazy to get mine welded in
  14. Dec 18, 2015 at 2:32 PM
    #7314
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah I wouldn't want to leave mine open.
  15. Dec 18, 2015 at 4:34 PM
    #7315
    Timbo's Customs
    Timothy
    Lakeland FL
    All the cool people do it. Haha one day your this way I can do it for you if you want or get with Todd
    SpruceTaco[QUOTED] likes this.
  16. Dec 21, 2015 at 1:53 PM
    #7316
    Southern_Taco9
    Southern_Taco9 Member
    Spencer
    Orlando, FL
    2015 grey Tacoma XSP-X
    43" light bar on roof attached to roof rack
    Hey not sure if this has already been said or not but do you need rear blocks for this lift as well as the added rear leaf springs or are they not necessary
  17. Dec 21, 2015 at 2:16 PM
    #7317
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    To be level you'll need either the 2" blocks or the add a leaf but not both.
    BTW welcome to TW from over here on Clearwater
  18. Dec 21, 2015 at 7:12 PM
    #7318
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    So i started to install my Walker evens 2.5 coilovers today. Got the passenger side done, only 3/4" of thread showing on the coilovers. Went ahead and set it down to see where it sat. Well is about .25-.5 taller then before. So that's got me sitting on nearly 8" of lift. I'm not sure if I wanna stay this tall or if I'm going to swap spins on the coilovers and lower it to 5" like I planned. Either way I need bigger tires. This is a real bummer
  19. Dec 21, 2015 at 7:42 PM
    #7319
    Timbo's Customs
    Timothy
    Lakeland FL
  20. Dec 22, 2015 at 8:25 PM
    #7320
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I'll put the fenders on tomorrow and measure. I haven't touched the truck today.
