Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Apr 3, 2012 at 3:11 PM
    #721
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    why didnt you get 285?.... i thought mine looked tiny at 5" of lift...
  2. Apr 3, 2012 at 3:58 PM
    #722
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Nice. I'm close to west Co. Ill look out for you and give you a wave! :)
  3. Apr 3, 2012 at 4:17 PM
    #723
    Socal00711
    Socal00711 Active Member
    Ralph
    So Cal
    07 prerunner SR5 TRD sport
    DIY and modified Relentless Two Piece kickout sliders,6000 hellas in custom grill. 4"MT spindle lift with 5100 bils set at 2.5. rear 3"angle blocks with 5100 bils long shocks 2" over stock, Home fab front bumper, modified Trail Gear rear tube bumper, Hidden license plate. Home fab speaker box and amp mount, D.O.T. approved blacked out head and tail lights. Weather tech front window vent shades,
    Well, if I sell my tires & wheels posted, I might be in the market for bigger tires....Do have alot of wheel well room now.....
    Always looking at other rides in the area....:cool:
  4. Apr 3, 2012 at 4:55 PM
    #724
    anthony250f
    Anthony
    San Diego, CA
    are you sure 26 ? mine is at 25.5 and im not even close to having 2.5" of preoad up front, can you measure from the ground to the bottom of the crossmember? thanks :D
  5. Apr 3, 2012 at 5:03 PM
    #725
    anthony250f
    Anthony
    San Diego, CA
    mine is at 14" from crossmember to ground, and about 40" from ground to fender. 265/70/16, maybe a pic of your lca angles?
  6. Apr 3, 2012 at 6:26 PM
    #726
    Hiatt1991
    Hiatt
    Ventura, CA
    I sit 21.5" from crossmember to ground.
  7. Apr 3, 2012 at 11:48 PM
    #727
    anthony250f
    Anthony
    San Diego, CA
    damn im going to re measuire mine tommaro, mine should be around 18
  8. Apr 4, 2012 at 7:50 AM
    #728
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Couple of questions??? First of all.. anyone have any regrets going with maxtrac vs camburg/tc/cst? Also, is anyone running them with Icons? Hows the ride? Any Pics? Thanks
  9. Apr 4, 2012 at 8:01 AM
    #729
    anthony250f
    Anthony
    San Diego, CA
    hell no!:D the ride for me is 100x better!!
  10. Apr 4, 2012 at 8:25 AM
    #730
    Hiatt1991
    Hiatt
    Ventura, CA
    If I planned on jumping my truck, ya I'd prolly regret it but for the type of offroading I do, they are exactly all I need. :)I hope that helps. Ill be upgrading to icons in may or June.
  11. Apr 4, 2012 at 9:36 AM
    #731
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I have jumped mine a little and no problems here...
    Xrs-fsho likes this.
  12. Apr 4, 2012 at 10:24 AM
    #732
    Hiatt1991
    Hiatt
    Ventura, CA
    Oh! Well there you go!
  13. Apr 4, 2012 at 10:26 AM
    #733
    Hiatt1991
    Hiatt
    Ventura, CA
    Have most of you guys removed your sway bar?
  14. Apr 4, 2012 at 11:00 AM
    #734
    Manwithoutaplan
    ID
    dude with uca you will be fine removing the sway bar.
  15. Apr 4, 2012 at 11:04 AM
    #735
    anthony250f
    Anthony
    San Diego, CA
    i removed mine when i didnt even have the wider stance from the spindles....it was fine
  16. Apr 4, 2012 at 11:08 AM
    #736
    Manwithoutaplan
    ID
    makes for better articulations even for the asphalt :D
  17. Apr 4, 2012 at 11:10 AM
    #737
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I kept mine off from when i installed the spindles. Noticed more roll, but once I put on the rear all pro leafs, and also new extended 5100s...drives GREAT with no sway, no lean on turns just nice, solid and smooth. I was debating putting it on between offroading, but once I replaced the shocks I was almost sure I don't need to...though I do wonder how much better it would handle now on the road with it... Hm...
    I've read that since Bilstein and Icon are Digressive, their added initial stiffness makes a sway somewhat redundant. I can definitely agree to that now...but I guess it still increases your chances of a roll? Technically? hehe....
  18. Apr 4, 2012 at 1:23 PM
    #738
    nfs257
    DFW
    She gone
    :D We already had this talk... REMOVE IT!!!!!! :p
  19. Apr 4, 2012 at 1:36 PM
    #739
    Hiatt1991
    Hiatt
    Ventura, CA
    I did! :)
  20. Apr 4, 2012 at 1:38 PM
    #740
    nfs257
    DFW
    She gone
    If I remember correctly you were scared of the turns in the neighborhood... so how do those treat you now?
