Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Feb 13, 2016 at 9:16 PM
    #7521
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Its possible if the angle isn't right. How much drop do you have on the carrier bearing? Maybe it's not enough, I have 1.5"& feel like it could use a little more. Beefed taco makes 1.5" & 2", 1.5 is for 4" & lower 2 is for 5" & higher.
    OME makes a little thin one but don't know if it does much, maybe for a 3" lift it would work.
    I'm pretty sure both halves of the DS have to be in a straight line.
  2. Feb 13, 2016 at 9:24 PM
    #7522
    xTACOMAx
    xTACOMAx Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    Honestly I'm not sure, whatever came with the lift kit is what I put on but I don't think it was a 1.5" drop
  3. Feb 14, 2016 at 9:53 AM
    #7523
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If you don't have a driveshaft spacer installed that is probably where you are getting your vibes. On prerunners the more you lift the rear it will start to pull the driveshaft out off the tailshaft of the transmission. Pic attached of where a driveshaft spacer will be installed to move the driveshaft back to where it should be.
    SpruceTaco likes this.
  4. Feb 14, 2016 at 10:12 AM
    #7524
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Gonna be doing my lift soon, spindles up front with 5100s and Dakars in back with the extra leaf as well, my RTT stays on truck rack nearly all the time. Is there anyway to tell if I will need or how much DS spacer I will need in advance? I have the OME CB drop that they recommend but I think that is only 0.75". I figured I could shim with washers initially if I need more there.
    Any suggestions out there anybody? Anybody else making or using a DS spacer?
  5. Feb 14, 2016 at 10:24 AM
    #7525
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Don't know if this helps but I'm lifted 5.5" in the rear with no added weight & have a 1.5" DS spacer. Seems like every 2" it pulls the DS out about .5". When I had 2" block it was out about .5" but no noticeable vibes.
  6. Feb 14, 2016 at 10:27 AM
    #7526
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    the only sure fire way to find out is to look once the truck is lifted. then you can measure and order accordingly
  7. Feb 14, 2016 at 10:31 AM
    #7527
    Pushincaskets
    High Point, NC
    07 PreRunner DCSB
    I have 3* shims as well so I'm hoping I'll be relatively lined up with those and the cb drop. Some people say angle is the biggest issue. I think with the Dakars and extra leaf, I'll be sitting +2.75 loaded.
  8. Feb 14, 2016 at 10:35 AM
    #7528
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Like @Alfuh said the best way to tell is measure after everything is done & had a chance to settle. Just a guess but I'd say at around 3" of lift it would probably pull the DS out about .75"
  9. Feb 14, 2016 at 11:07 AM
    #7529
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    I thought this thread had been dumped going to keep an eye on it again. Good info.
  10. Feb 15, 2016 at 3:13 AM
    #7530
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I have the 4" Maxtrac with the OME Dakar leaf springs. I didn't need to shim anything and the drive shaft came out about 3/8 inch. Runs smooth no vibes. The truck is smoother now than stock. Try to keep it simple and clean.
    ChadsPride and JoseyWells like this.
  11. Feb 15, 2016 at 1:50 PM
    #7531
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    Looked like a tow truck today !!!
    Is that a side business ? LOL !!!
    Alfuh[QUOTED] likes this.
  12. Feb 15, 2016 at 3:56 PM
    #7532
    Alfuh
    2006 Prerunner
    I have a few mods
    hahaha yeah totally :p I knew your truck kinda looked familiar lol. I saw yours and another one later on with retros that waved to me lol.
    Nah that was a coworker of mine haha, his pathfinder decided to just shut off on him out on the ranges lol. turns over...but doesnt fire, just sits there and spins. and again.....another person impressed at what my prerunner can do lol, had to drag his pathfinder out of the trails and through a bunch of sand back to base, then had to drive him back up to crestview. She did good gettin that nissan out of there lol, threw it into 1st and got through the sand parts, then of course driving on the highway back was the easy part haha
  13. Feb 15, 2016 at 4:03 PM
    #7533
    Alfuh
    2006 Prerunner
    I have a few mods
    Of course.....had to snap some photos :cool:
  14. Feb 15, 2016 at 6:57 PM
    #7534
    TheGrayRider
    NW Florida
    2017 BBP DC 4X4 OR
    Saw you there on 123 and I was laughing because I thought you had bought a pathfinder but then I remembered you already bought the reg cab old school truck... LOL
    Good on you for dragging him out of the weeds !!! I hope it didn't hurt the pathfinder too much. LOL
  15. Feb 15, 2016 at 10:09 PM
    #7535
    JoseyWells
    JoseyWells Well-Known Member
    Joe
    Corona, CA
    12 prerunner
    Demello sliders, Icon ext coilovers, icon rear shocks, icons UCAs, 17" Konig Countersteer Type X, 285/70/17 Nitto Trail Grapplers
    That's the set up I plan to do? How is the rake with the dakars?
  16. Feb 16, 2016 at 6:05 AM
    #7536
    Alfuh
    2006 Prerunner
    I have a few mods
    Haha lol, id never buy a nissan. The pathfinder was just dead weight towing it back to base lol, damn thing doesn't want to fire, just turns over. Didn't have any tools on me, so we couldn't mess with anything lol
    TheGrayRider[QUOTED] likes this.
  17. Feb 16, 2016 at 5:36 PM
    #7537
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    2016 Black TRD Sport 2WD (black)
    I'm looking to add the Maxtrac spindles to my 3rd gen. Am I going to be alright just buying those and throwing them on or am I not going to be satisfied and want to immediatly buy a bunch more stuff to compliment the lift? Going to do wheels and tires when i do the lift as well.
  18. Feb 16, 2016 at 5:54 PM
    #7538
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    You will be happy. If you go offroading you will still want better shocks. You also need something for the rear to level it out
  19. Feb 16, 2016 at 5:56 PM
    #7539
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    I won't be doing much off roading. Don't they come with blocks for the back?
  20. Feb 16, 2016 at 6:00 PM
    #7540
    Alfuh
    2006 Prerunner
    I have a few mods
    not just the spindles, but Headstrong Offroad does offer lift kits with front and rear parts, go check em out!
