Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Feb 16, 2016 at 6:10 PM
    #7541
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    2016 Black TRD Sport 2WD (black)
    If i'm doing minimal off roading will I be alright with just the blocks in back? Is there a world of difference in the 4 inch block as opposed to the 6.5 inch block when it comes to the ride of the truck?
  2. Feb 16, 2016 at 6:19 PM
    #7542
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    I would honestly only do the 4" kit...blocks are not ideal for wheeling. BUT for minimal offroading, a smaller block is ok, if you plan on doing more, id recommend getting an entire new leafpack. But as for the ride, it's still a block, it wont ride a nice as an AAL or a new leafpack, but I guess it's works lol
  3. Feb 17, 2016 at 3:13 AM
    #7543
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    It's about 1/2 inch of rake. The Dakars are the way to go!
    JoseyWells[QUOTED] likes this.
  4. Feb 18, 2016 at 10:13 AM
    #7544
    xTACOMAx
    xTACOMAx Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    Does anyone know the bolt pattern and what size bolt for a drive shaft spacer from 4crawler off-road?
  5. Feb 18, 2016 at 3:04 PM
    #7545
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    I just ordered from low range off-road. It is cheaper part and it's triple drilled to fit all the possible drivelines on the vehicle. I stopped looking at the 4 crawler option when I couldn't find the right size like you.
    Mine is in my mailbox and I ordered it monday
  6. Feb 18, 2016 at 4:31 PM
    #7546
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    Alright, I think I'll go with just the 4 inch block in the back. Although for piece of mind, I'm kind of thinking of doing the bundle which includes all this stuff. Any feedback on that is appreciated.
    Maxtrac 4” lift spindles w/ front brake lines
    Bilstein 5100 adjustable front struts
    OME Dakar full leaf pack replacement
    OME nitrocharger sport rear shocks
    extended length u-bolts
    OME carrier bearing drop bracket
    Bushings and sleeves for shackle side of leaf pack
    23”SS kevlar reinforced rear brake lines
    Shipping to lower 48 States
    Total = $1469.99
    Wheels and tires are the next decision. Obviously money factors in with this as well. I'm thinking of taking a cautious approach and getting 33's on my stock 17 inch rims so if I don't like the lift I can get out of it without too much of a financial blow. If I like it I could just do wheels when go through my first set of tires with the lift.
    So on the low end, do the Maxtracs with the four inch block, stock rims, 33 inch tires. On the high end the whole bundle and new rims. Thanks for the help!!
  7. Feb 18, 2016 at 4:36 PM
    #7547
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    If you do the Dakars leaf pack you likely won't need a block in the back. 4" up front from maxtrac and 2.75 in back from Dakars and you will be close to level.
    ChadsPride likes this.
  8. Feb 19, 2016 at 4:23 AM
    #7548
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    So I could pick up the spindles and the leaf springs and be set or will I need to change out anything else in the rear? Will everything else stock match up with the leaf pack?
    http://www.headstrongoffroad.com/maxtrac-spindles-for-05-tacoma.html
    OME leafs: http://www.headstrongoffroad.com/store/p123/Old_Man_Emu_Dakar_Leaf_Pack_(PAIR)_-_CS047R.html
  9. Feb 19, 2016 at 4:30 AM
    #7549
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
  10. Feb 19, 2016 at 4:32 AM
    #7550
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Take care in measuring as the 65mm x 65mm x 10mm pattern is very close in size to the 66mm x 66mm x 11mm pattern, the big difference will be the flange bolts. The 10mm and 11mm bolts often have "11" stamped on the heads and the wrenching size is the same 14mm head/nut on the 10mm and 11mm factory hardware. Also, these flanges are often in the 4.5" - 5" outer diameter size. Aside from careful measuring of the bolt pattern spacing, you can usually get a pair of calipers on the exposed end of the bolt sticking out past the nut. The end of the bolt is slightly tapered, but the 11mm bolt will measure about 10.6mm in dia. while the 10mm bolt will measure something like 9.6mm in dia. If you actually remove a bolt and check, the unthreaded shank will measure out quite close to the 10mm or 11mm measurement.
    [*]If you are sure you have 11mm bolts, order the larger 66mm x 66mm x 11mm spacer.
    [*]If you are not sure of your measurements, (it can be difficult to get accurate measurements in the confined space of the installed drive shaft), you can use the 65mm x 65mm x 10mm spacer with the 66mm x 66mm x 11mm flange. How can this be? Well, the holes in the spacer are drilled about 0.5mm oversized as are the holes in the factory flanges. The difference between the 65mm and 66mm bolt patterns are 0.5mm wider on each half, so with the bolt hole sizes, there is enough overlap to fit a 10mm bolt through all the holes. The reverse is not true, however. That is if you actually have a flange with 10mm bolts, the 11mm bolts will not fit in the 10mm hole."
    Alfuh likes this.
  11. Feb 19, 2016 at 5:35 AM
    #7551
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    Total = $1469.99
    Is there anything in this bundle I don't need?
  12. Feb 19, 2016 at 5:47 AM
    #7552
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Looks good to me, and that will look damn good installed! Cant wait to see it :D
  13. Feb 19, 2016 at 5:48 AM
    #7553
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Technically you can do without the 5100's unless you're looking for more than 4", the Maxtracs are designed to work with the factory suspension.
  14. Feb 19, 2016 at 7:57 AM
    #7554
    JoseyWells
    JoseyWells Well-Known Member
    Joe
    Corona, CA
    12 prerunner
    Demello sliders, Icon ext coilovers, icon rear shocks, icons UCAs, 17" Konig Countersteer Type X, 285/70/17 Nitto Trail Grapplers
    Correct me if im wrong but icon rear shocks should be fine with the dakars?
  15. Feb 19, 2016 at 8:14 AM
    #7555
    2nd screen name
    Bob
    LV/SD
    You need to ask foir a shock designed for dakars which i dont know the p/n for atm. Call Chas he knows and can get them cheap.
  16. Feb 19, 2016 at 9:20 AM
    #7556
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    No but you can special order them for dakars. I have a set of never installed icon rear resi's built for a dakar leaf pack thats for sale. Pm me if your interested.
  17. Feb 19, 2016 at 4:53 PM
    #7557
    SergeStorms
    SergeStorms Member
    Will
    Vero Beach, FL
    So I could take the Bilstein 5100's off this list? Its a bundle price so would it make a huge difference in the bottom line? Thanks for the help Spruce Taco and Iamraiderpower. It's appreciated!!
    Total = $1469.99
  18. Feb 19, 2016 at 5:24 PM
    #7558
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Didn't know it was a bundle deal, don't know if you can remove them. Like I said earlier technically you don't need them if all you want is 4". On the other hand they will ride better than stock & if you want more lift in the future you'd have that option but adjusting them. Oh & they cost under $200.
  19. Feb 19, 2016 at 5:33 PM
    #7559
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Here is the part number for the Icons rear RR for dakars. I got mine from SDHQ and this is what was on the box when they arrived.
  20. Feb 19, 2016 at 7:23 PM
    #7560
    Pushincaskets
    High Point, NC
    07 PreRunner DCSB
    Shocks if your looking to do anything there, need wheel spacers or proper BS wheels. Since the front gets pushed out 3/4" by the spindles you might at least want rear spacers to match up better.
