Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Apr 12, 2012 at 1:12 PM
    #821
    Marcmfm007
    Marcmfm007 Well-Known Member
    Socal
    08 PreRunner
    Alpine Touchscreen NAV Head Unit, JBL MS-8 Processor, JL Audio XD400/4 amp w/ JL Audio C2 6.5" Components/ 5.25" Components, 4" Coax Center Channel w/ LCD Controller, Elemental Designs nINE.1 1200w amp w/ (2) JL Audio 12W6's in Blow Thru Box w/ Custom Fiberglass back wall housing amps/ processor/ cap, BLK Headlights/ Morimoto Projector Retro/ Stubby Ant/ [Dash LED's by Jerez]/ [Maxtrac's/ Billy's/ All Pro Expos w Flip Kit/ Wheeler's Superbumps/ Black Rock Intruder 18"x 8.5"/ 295.70 r18 Nitto's/ Installed by ManWithoutAPlan & Hiatt]/ [Cab Mount Chop & Pinch Weld Beat Down by SickNickFab]
    Naw, there was a 1/4" of uca that still needed to be inserted into the top of the spindle. We even picked up some taps and a big drill bit, still didn't wanna go. Figured it was safer for everything to walk away. Truck is daily driver. Lol.
  2. Apr 12, 2012 at 1:15 PM
    #822
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    What are the benefits of these?
  3. Apr 12, 2012 at 1:16 PM
    #823
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    all pros fault or maxtracs?
  4. Apr 12, 2012 at 1:17 PM
    #824
    Manwithoutaplan
    ID
    their just aftermarket ball joints little bettter than the stock ones.
  5. Apr 12, 2012 at 1:18 PM
    #825
    Manwithoutaplan
    ID
    kinda hard to tell.
  6. Apr 12, 2012 at 1:33 PM
    #826
    Marcmfm007
    Socal
    08 PreRunner
    They're an upgraded OEM replacement ball joint. Their design is pretty nice. We destroyed the dust boot to the balljoint from separating so many times and the Moogs will also add some adjustment capability to the alignment.
  7. Apr 12, 2012 at 1:38 PM
    #827
    Marcmfm007
    Socal
    08 PreRunner
    Neither really. Each manufacturer would have to agree on a standard for all parts to be interchangeable without modification. Then they would all have to be test fit. Logistical hardship. If we were master craftsmen I'm sure we could've gotten it done but alas, we don't run a metal shop or nothin. Lol. My question is if Camburg fits, TC fits and stock fits...... And All Pro fits stock.....and all the rest fit stock AND Maxtrac...... How come All Pro doesn't fit Maxtrac? Odd to me. :confused:
  8. Apr 12, 2012 at 1:40 PM
    #828
    nfs257
    DFW
    She gone
    I dont think its across the board that they wont fit... Did your spindle fit the stock UCA's?
  9. Apr 12, 2012 at 1:53 PM
    #829
    Marcmfm007
    Socal
    08 PreRunner
    Yep, stock UCAs and Maxtrac spindle are good fit. Still on and riding fine.
    That's a good point..... Hopefully someone else has All Pro UCAs with Maxtrac spindles or at least tried and will chime in. :cool:
  10. Apr 12, 2012 at 1:57 PM
    #830
    nfs257
    DFW
    She gone
    I dont feel like reading thru this whole thread and the other one but there was 1 or 2 other cases where that would not fit... Dont think they were all pro though...
  11. Apr 12, 2012 at 2:05 PM
    #831
    anthony250f
    Anthony
    San Diego, CA
    pretty sure one was light racing and the other was maybe a camburg? and one guy had stock uca
  12. Apr 12, 2012 at 2:23 PM
    #832
    Marcmfm007
    Socal
    08 PreRunner
    Same here, not digging thru 1800+ posts in 2 threads but I know for sure at least 1 other person ran into this and tapped the top of the spindle. Guess the manufacturing tolerances are a little larger sometimes. Wonder if it's from casting process or milling of misalignment spacers? I sent the Maxtrac engineer a PM. Maybe they've heard of this and have a reasoning or solution.
  13. Apr 14, 2012 at 6:41 PM
    #833
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Anyone got any updates on when there will be more Maxtrac spindles available for purchase??
  14. Apr 14, 2012 at 6:44 PM
    #834
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    As of now, June.
  15. Apr 16, 2012 at 9:28 AM
    #835
    maxtracbob
    maxtracbob Well-Known Member
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Hey Guy's.... I'm the only one on here and haven't seen anything on this.... We make our spindles to work with the stock ball joint... If the taper and bore is in the stock configuration there should be no problem. The tolerances have to be exact to work and I just don't now what All Pro uses for thier ball joints... The fit needs to be exact to work correctly...
  16. Apr 16, 2012 at 9:31 AM
    #836
    maxtracbob
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Hey Guy's....
    It might be a little bit sooner but I don't want to jinx it... I'll let you know as soon as I know.... Thanks
  17. Apr 16, 2012 at 9:53 AM
    #837
    Manwithoutaplan
    ID
    great beefy product btw way bob keep up the good work :thumbsup:, but you intructions could use little beefing up.
  18. Apr 16, 2012 at 1:59 PM
    #838
    moelov
    moelov Well-Known Member
    USA
    09 PreRunner SR5 Lifted
    Removed the Mud Flaps, Rock Deflectors and Head Rest. Limo Tint, I had 3" Toytec Lift, Procomp Nitrogen ES6000 shocks and Struts. AllPro UCA, AFE Pro Dry drop in filter, WeatherTecs. Now I have LR UCA's, Maxtrac Spindles, Eibach's, 5100's up front, Expos, 5160 for the rear, U Bolt Flip Kit, and Extended Brake lines.
    Oh Ohhh this can be a problem for me. Maxtrac Bob is there anything you can do or is it too late because of casting?
  19. Apr 16, 2012 at 9:20 PM
    #839
    Marcmfm007
    Socal
    08 PreRunner
    Thanks for the response and clarification. Def made no sense to me that your spindles would fit stock ball joints and not All Pros since All Pro makes their UCAs for stock spindles which one would normally infer that their arms would fit your spindles. Alas, guess not. Weird. Maybe it's because their arms are uniball? Anyway, thanks again for making an awesome spindle at an awesome price! Keep up the great work!:D
  20. Apr 17, 2012 at 5:28 AM
    #840
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    bring on the new batch!
