Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Oct 5, 2016 at 5:27 PM
    #8541
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    He'll go from maxtrac Bob to FOX parts Bob :D
  2. Oct 6, 2016 at 9:18 AM
    #8542
    Boomerswany
    Boomerswany Well-Known Member
    Jerry "Swany" Swanson
    Lebanon, Oregon
    2012 Tacoma Prerunner
    Shifter, antenna, Truxedo LoPro
    Huge Maxtracs fan..!
    Wondering if anyone's had any experience or able to speak to a comparison of Maxtracs vs. Quality Suspension Advantage? I'd notice it pop at the bottom of the forum feed, so I decided to look.
    They seen to be a valid competitor. Also at a price point $95.00 less (which inherently doesn't make them better or worse), but, $400.00 including freight seems pretty interesting.
    ChadsPride likes this.
  3. Oct 6, 2016 at 9:33 AM
    #8543
    Alfuh
    2006 Prerunner
    I have a few mods
    personally, I wouldnt trust them, they are just a knock off of Maxtrac spindles. to me, that means they are made with lower quality materials and arent going to be as stout as Maxtracs are. TBH....its only a $95 difference, Maxtracs are $495 shipped...and that way, you KNOW you are getting a great product that holds up to what you expect them to. I really wouldnt trust those at the bottom
    White Horse and ChadsPride like this.
  4. Oct 7, 2016 at 3:16 PM
    #8544
    Jaredconat863
    Jaredconat863 Well-Known Member
    Jacksonville, Fl
    2008 pre runner 040
    Spindles , Bilstein 5100s set @ .85, eibach coils, rear 4 inch block. FJ steel wheels, 285/75/17 g2s
    I also somehow got 5 inches out of my new set up. Before spindles I had billies @.85 and the same springs that are on my set up now and I was sitting at 23 inches hub to fender and 22.5 in rear. So my measures were to simply add a 4 inch block to rear to make it 26.5 and spindles to front for a 27 inch front. The rear measurements are spot on and are currently at 26.5. However my front is at 28 inches. Trying to figure out how I have 5 inches of lift from a 4 inch spindle? Could it be bevause the new 5100s are so new??
  5. Oct 7, 2016 at 3:22 PM
    #8545
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    You kept the 5100's set at .85?
  6. Oct 7, 2016 at 6:40 PM
    #8546
    Jaredconat863
    Jacksonville, Fl
    2008 pre runner 040
    Yessir, same exact set up that I had on truck before lift. Just swapped out 5100s
  7. Oct 7, 2016 at 6:47 PM
    #8547
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    That's why you're getting 5" then. 4 from the spindles & almost an inch from the 5100's. Also keep in mind the struts will settle some. When originally lifted mine the front measured the same as the rear, after a while it settled about 3/4".
  8. Oct 7, 2016 at 7:09 PM
    #8548
    Tacomoto23
    Tacomoto23 Well-Known Member
    Carey
    Torrance,CA
    21’ TRD 4x4
    For everyone who has installed their spindles by themselves. How long of an install would you say it took?
    ChadsPride and Bot_Chu like this.
  9. Oct 7, 2016 at 7:12 PM
    #8549
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    Uhhhh i forgot how long i took but it shouldn't be to long :O if your stuff isnt seized up like how mine was haha
  10. Oct 7, 2016 at 7:16 PM
    #8550
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I think the last one we did took like 4 hrs but that included some BSing & the rear lift.
  11. Oct 7, 2016 at 7:21 PM
    #8551
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    Right on. Yeah, hopefully it won't be seized up when I get around to it!
    Sounds good. No rear lift for me and hopefully there will be no distractions haha.
  12. Oct 7, 2016 at 8:51 PM
    #8552
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Invest in the pb blaster now. Start spraying your stuff every couple weeks. Everybody complains about brake lines etc. I'm rolling 2007 never been touched I sprayed my stuff in advance about 3-4 times before getting to some of it. BUTTER
  13. Oct 7, 2016 at 9:18 PM
    #8553
    Tacomoto23
    Carey
    Torrance,CA
    21’ TRD 4x4
    Yup, already have a can of that waiting! My truck currently has 35K on it so hopefully the rust and corrison is down to a minimum!
  14. Oct 7, 2016 at 9:46 PM
    #8554
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Oh yeah that PB Blaster Will be a blessing 240k miles when i did mine with same day PB Blasting . . . . yeah no fun Hahaha granted im in CA
  15. Oct 8, 2016 at 5:49 AM
    #8555
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    The install took me 2 days taking my time to make sure I did it correctly. I did the spindles, coilovers, brake lines, Dakar leaf springs, and rear shocks. We also cleaned all parts thoroughly, greased and assembled. All torque values were checked during and after complete assembly. This also doesn't account for the time to clean spindles with alcohol, tape, and clear coat them.
    I would imagine if you were just doing the spindles the first time it would be less than a full day.
    Bot_Chu, scott96929 and ChadsPride like this.
  16. Oct 9, 2016 at 7:19 AM
    #8556
    Jaredconat863
    Jacksonville, Fl
    2008 pre runner 040
    So new 5100s get an inch lift out of the box? Before I lifted my truck I had coils and billies at .85. So for my calculations I figured I would just add 4 inches for the spindles. It has to be the new shocks
  17. Oct 9, 2016 at 7:33 AM
    #8557
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Did you set the new ones at .85? If so that's your extra inch. If you set them at 0 then it probably just needs time to settle because you took everything apart & it had a chance to somewhat stretch out.
    As I said before I just adjusted mine all the way up a couple weeks ago & by the numbers it should have been the same as the rear but it was like 1.25" higher, now it's settled down to measure the same as the rear.
  18. Oct 9, 2016 at 10:54 AM
    #8558
    Jaredconat863
    Jacksonville, Fl
    2008 pre runner 040
    Yeah I have always had billies set at .85. Just added spindles and new billies. Hopefully they settle. 28 in front and 26.5 is a little too bro for me
  19. Oct 9, 2016 at 11:04 AM
    #8559
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    So are the new ones set at .85 or 0?
  20. Oct 9, 2016 at 11:11 AM
    #8560
    Jaredconat863
    Jacksonville, Fl
    2008 pre runner 040
    Yeah new at .85 and eibach coils. Same before spindles
