Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Feb 21, 2017 at 8:00 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Man, I'm not really the one to give advice on tires and weight ratios and 4bangers vs the v6 man.
    I personally think you will be fine. It will for sure be more sluggish, but 'should' be ok
    White Horse likes this.
  2. Feb 21, 2017 at 8:11 AM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    Not really sure about the 4 banger but if it helps, I re-geared to 4.56 gears when I went up to 315/70/R17. It felt sluggish before and was shifty on hills and now it is much better.
    ChadsPride likes this.
  3. Feb 21, 2017 at 8:27 AM
    HuntTaco
    HuntTaco Well-Known Member
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    Maxtrac 4" kit Bilstein 5100's Mastercraft 305/70/16
    Gotcha. Well this is my daily driver, I don't do any wheeling, just to and from work. 99% highway for mine. Do you think that will negate the need for a regear?
    Stats on the tires i just ordered:
    Mastercraft Courser MXT Radial Tire
    305/70R/16
    Speed Rating: Q
    Weight: 57 LBS
    Load Range: E
    Ply: 10
  4. Feb 21, 2017 at 8:30 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    In theory that's a 32.8" tire, in reality it's probably an even 32. Obviously the weight comes into play as well but I think you'll be OK. You won't be winning any rolling-start freeway drag races and cruise control will hate you but oh well!
  5. Feb 21, 2017 at 8:34 AM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    Phew, ok. that makes me feel a little better. How much was your re-gear? if it ever comes down to that
  6. Feb 21, 2017 at 8:41 AM
    dumontrider
    La Habra, CA
    14 GX460
    I'm on 32" Toyo AT's and haven't regeared....thinking you quoted the wrong person :cheers:
    :boink:
    Regearing around me (Southern Cali) is nucking futs expensive, the techs use all diamond coated gears & gear oil laced with AB- unicorn blood. I kid I kid, I think it's around $600 on the low end for me but labor is very market-specific and you're a few villages away from me. I say run it as is and see if you can live with it. If you don't haul/tow much then that's in your favor. You can regear at any time....when (not if) you install a locker is a perfect time!
    Edit to add: King group buy discount/pricing is announced:goingcrazy: Now I need to swallow that huge pill!
  7. Feb 21, 2017 at 8:44 AM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    @dumontrider ah damn, my bad! Yeah, i don't tow anything, don't wheel, don't have a shell/bumpers/armor,i don't haul anything but the dog, groceries, and my fishing or hunting shit haha
  8. Feb 21, 2017 at 9:03 AM
    TacoMaxxxx
    TacoMaxxxx Well-Known Member
    Orange County, CA
    2016 Limited
    Just throwing my opinion out there... I would not go with that large of a tire with your setup. I really think it's going to cause a lot of problems that you'd rather not deal with.
  9. Feb 21, 2017 at 9:05 AM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    By all means, let me know what you think or what problems you're referring to. I'm all ears.
  10. Feb 21, 2017 at 9:09 AM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Ok, but first what kind of lift are you running to accommodate that size tire? I think the obvious first issues will be the sluggishness and the possible need to re-gear. I guess if you are OK with that and you can clear without rubbing then why not?
  11. Feb 21, 2017 at 9:12 AM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    I'm going to get (was going to order today but Headstrong is closed this week) the Maxtrac 4" spindle lift, Bilstein 5100 adjustable front shocks, Bilstein extended length rear shocks, and Headstrong 3 leaf AAL along with the necessary hardware (CB drop, extended rear brake lines, top plate spacers for both sides).
  12. Feb 21, 2017 at 9:15 AM
    TacoMaxxxx
    Orange County, CA
    2016 Limited
    Dude, I'm sorry. I thought you were going with 35's and now see you'll match right up around 33's. You should be fine with a little trimming on the front. You'll be a little sluggish but nothing major.
    HuntTaco[QUOTED] and ChadsPride like this.
  13. Feb 21, 2017 at 9:18 AM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    @TacoMaxxxx oh hell no haha, def not 35's. ~33's are what i ordered this morning. I'm fine with trimming and i expected some slight power loss just due to the increased weight of the 305's going from 245/75r/16
    TacoMaxxxx and ChadsPride like this.
  14. Feb 21, 2017 at 2:50 PM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    You should be fine. I ran 285's on stock gears with the 2.7 for a year and a half and mine total weight for wheel and tire was right at 100 pounds a peice
  15. Feb 22, 2017 at 4:53 AM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    Awesome! Thanks bud. I just calculated mine too, wheel and tire will be 88LBS. Tires will be here tomorrow, wheels by Friday, then placing my order with Headstrong next week!
    White Horse and rainyben45 like this.
  16. Feb 22, 2017 at 8:30 AM
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    My god I am so tempted to make this drive for this deal thanks for the tag @desertrunner24
    MCM fab UCA'S,
    ADS 2.5 extended travel coilovers
    ADS 2.5 piggyback shocks
    Deaver expo leaf packs
    Method standard 16in wheels
    Ko2 285's like new
    $3600
    Should I make a vegas trip out of it?
  17. Feb 22, 2017 at 8:31 AM
    ChadsPride
    Thats a fuck load of money for used stuff brah
    TommyG and TacoMaxxxx like this.
  18. Feb 22, 2017 at 8:31 AM
    ChadsPride
    Maxtracs and Dakars.
    Add to it as you go. Done.
    HuntTaco likes this.
  19. Feb 22, 2017 at 8:33 AM
    Prodigy0325
    Prodigy0325 Well-Known Member
    So Cal
    2011 Toyota Tacoma PreRunner
    Maxtrac Spindles, 5100 front and rear, Headstrong 3AAL, KMC XD 301 on Toyo Open Country AT2
    Would i need UCA's if i ran 5100's with OME885 coils along with the maxtrac spindles?
  20. Feb 22, 2017 at 8:37 AM
    dumontrider
    La Habra, CA
    14 GX460
    It's working fine for me w/o UCA's :thumbsup:
