Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Apr 10, 2017 at 10:03 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Damn your way up there. very nice. how it ride?
    ChadsPride likes this.
  2. Apr 10, 2017 at 10:50 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Damn! 29"? I'm lifted 7" just from the lift & only measure 27.5 - 27.75" in the front hub to fender. 28" in the rear hub to fender.
    I was at 28" after the new coils but the settled.
  3. Apr 10, 2017 at 12:42 PM
    HuntTaco
    HuntTaco Well-Known Member
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    Maxtrac 4" kit Bilstein 5100's Mastercraft 305/70/16
    It rides smooth at times and rough at times. The alignment has the steering wheel slighted turned but it's good! Only slight vibrations every now and then
  4. Apr 10, 2017 at 12:43 PM
    HuntTaco
    Derek
    Chesapeake, VA
    2013 MGM Prerunner
    Yeah i think the added height is because the shop put the front 5100's at the 2.0 notch instead of the 1.75 that i wanted. It prob still needs to settle just a bit
  5. Apr 10, 2017 at 1:57 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    With what springs?
  6. Apr 10, 2017 at 2:00 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Maxtracs and 887's = ~7" lift (front) 2nd Gen SR5 V6 PreRunner right?
  7. Apr 10, 2017 at 2:53 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I believe so but 887's are pretty stiff. They're designed to support the weight of a plate bumper. I have the 885's with my 5100's set at 0, I got 3" out of them & it's a softer spring rate.
    7" total with the Maxtracs.
    ChadsPride[QUOTED] likes this.
  8. Apr 10, 2017 at 3:12 PM
    ChadsPride
    Thats what I thought, just making sure. Literally asking for a friend haha.
    He's got a bumper already and just put on 887's and wants Maxtracs
    @AtxLakeTaco
  9. Apr 10, 2017 at 3:25 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    It will be whatever he has now + 4".
    If I'm not mistaken it will be less with the bumper, something like 2.5".
    Am I correct Marie? @HeadStrong Off-Road
  10. Apr 10, 2017 at 4:06 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Actually the 886's are the ones that are stiffer . The others all have the same spring rate.
    • OME 883: 375mm in height, 590 pound spring rate
    • OME 884: 390mm in height 590 pound spring rate
    • OME 885: 395mm in height 590 pound spring rate
    • OME 886: 402mm in height 660 pound spring rate
    • OME 887: 400mm in height 590 pound spring rate
    • OME 888: 405 mm in height 590 pound spring rate
  11. Apr 10, 2017 at 4:13 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Oh okay, I wasn't positive. So the 887 are 5 mm longer than the 885 which isn't even a quarter inch. I wonder what the advantages are of one over the other
  12. Apr 10, 2017 at 4:16 PM
    BORNWILDGUY
    Rich
    Florida
    I believe with the 887's you are supposed to get a full 3" on 2nd gens and the 888's are mainly used on the 3rd gens
  13. Apr 10, 2017 at 4:20 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I got a full 3" with 885's
  14. Apr 10, 2017 at 4:23 PM
    BORNWILDGUY
    Rich
    Florida
    They will probably settle to 2.5 over time but I could be wrong.:notsure:
  15. Apr 10, 2017 at 4:25 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    They've been on since January & have only settled maybe .5"
    My hub to fender is the same as when my billies were at 2.5 with the .25 top spacer.
  16. Apr 10, 2017 at 5:52 PM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    @ChadsPride
    285/75/16
    Fn five star 3.5bs -25 offset
    6112 3rd notch about 2.5 inches of lift. Could not turn out of my driveway rears are fine.
    Next day ordered spindles, got to like 5.5-6 inches cause i lowered the 6112 then it all fit with cmc and trimming plastic.
    Hit the desert and didnt blow a fender off but had way to much rubbing to go as fast as i wanted so then i got the new fivestars with 4.5 bs 0 offwet i think and this works best
    Bot_Chu and ChadsPride[QUOTED] like this.
  17. Apr 10, 2017 at 5:55 PM
    ChadsPride
    Thank you for the information! I know that pushing the wheel out will create more rubbing issues.
    I really like that look of some wheel out of the fender and wanted to be like the cool kids haha.
    Running 5" lift up front and did the CMC and some prep trimming Saturday.
    Hope I can exit my driveway when I get these tires mounted lol
    Bot_Chu likes this.
  18. Apr 10, 2017 at 6:21 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Correct. The spindles will provide you with 4" of lift over stock. If there is a bumper added to the stock suspension then that will alter how much lift you see since the factory coilovers are actually providing a negative amount of support.
    Basically the lift height. The spring rates are the same so if someone wants to gain a little bit more lift they can use the 887's over the 885's or if they want to add in a small amount of front weight the 887's will then provide settle in lower which could make them provide around the same amount of lift as the 885s (totally dependent on how much weight is added though).
    887's will provide around 3" of lift on a stock weight 05-15 double cab 4x4. The 885's will provide around 2.5" of lift on a stock weight 05-15 4dr 4wd.
    The lift will be more from either coil if they are used on an access cab or 2wd. Usually around 1/4"-1/2" more lift so that is why the 885's will provide around 3" on the 2nd gen 2wd's.
  19. Apr 10, 2017 at 6:37 PM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    You should be fine boss Haha!~
  20. Apr 10, 2017 at 6:38 PM
    ChadsPride
    :fingerscrossed::fingerscrossed::fingerscrossed::fingerscrossed:
    Need to decide on tires!!!!​
