Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jul 28, 2017 at 4:31 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Not a problem, just finished the lawn & was sitting here drinking a beer & staring at her. Lol
    ChadsPride likes this.
  2. Jul 28, 2017 at 4:34 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    ChadsPride and PapaBear[QUOTED] like this.
  3. Jul 28, 2017 at 4:38 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
  4. Jul 28, 2017 at 4:58 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
  5. Jul 28, 2017 at 5:02 PM
    PapaBear
    Austin
    SIN CITY
    Got it. What about the rust? Any suggestion on a brush?
  6. Jul 28, 2017 at 5:13 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Brush for paint or cleaning? Any scrub brush for cleaning & I'd spray paint them.
    If you clean & paint them in the same day rust shouldn't be an issue.
  7. Jul 28, 2017 at 5:14 PM
    PapaBear
    Austin
    SIN CITY
    cleaning, they already have some surface rust. Looking for the best way to get rid of it before I paint
  8. Jul 28, 2017 at 5:29 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
  9. Jul 28, 2017 at 5:36 PM
    PapaBear
    Austin
    SIN CITY
  10. Jul 28, 2017 at 5:48 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No problem, yeah on those spots you can use some steel wool or fine sandpaper.
  11. Jul 28, 2017 at 6:48 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Pulled up alongside a pretty lifted Taco today. Was all set to give props until I saw the 5100's, stock coils & what looked like a 3" tall spacer on the front shock tower. My limo-tinted window went back up 'sofa king' quick!
    I can only hope the glare from my gloss white "MT" logo caused some discomfort for her.
  12. Jul 30, 2017 at 8:16 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I used Naval Jelly a few months ago to take some rust off the end of the bed where the tailgate latches. It worked well. I had to do a few applications because I had some heavier rust spots, but for light surface rust, it should clean it up in 1-2 applications.
  13. Jul 30, 2017 at 12:58 PM
    GrayMetalic 2015
    GrayMetalic 2015 Well-Known Member
    2015 Tacoma TRD Sport
    Bilstein 6112 4th notch Bilstein 5100 rears 1.25" rear block Light Racing UCA BFG KO2 265/70/17 on Fuel 17x9
    Need your opinions:
    Looking for a nice smooth ride 95% highway, current setup too stiff for my liking so I'm hoping this will accomplish the ride I want and truck being level.
    Currently:
    6112 4th notch
    Light Racing UCA
    1.25" Block
    5100
    BFG 265/70/17 Ko2
    Looking at:
    MaxTrac 4" spindle lift
    6112 1st notch (stock height)
    Light Racing UCA
    2" AAL
    5100 keep existing or Fox 2.0 (local shop has kit with Fox shocks)
    BFG 265/70/17 Ko2
    Feedback would be greatly appreciated.
  14. Jul 30, 2017 at 1:06 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    You're on the right track with Maxtrac's & your 6112's on 0 (stock), being on the 4th notch now is whats making it stiff but I think the aal will make the rear stiffer. Marie @HeadStrong Off-Road can answer the question on the rear. Maybe a 3 leaf progressive aal for a smoother ride?
  15. Jul 30, 2017 at 1:18 PM
    GrayMetalic 2015
    SpruceTaco- appreciate your feedback I was hoping for a positive response to my thinking. I will definitely give Marie @HeadStrong Off-Road an email. She answered questions for me in the past and she is awesome.
  16. Jul 30, 2017 at 1:59 PM
    ChadsPride
    Sponsored by TacomaWorld.com
  17. Jul 30, 2017 at 2:16 PM
    GrayMetalic 2015
    Appreciate the positive feedback ChadsPride.
    As I'm continuing to do some research I'm seeing different info. If I put the circlip to the 1st notch will it be the same as stock height? or as I've seen the 1st notch will give .95" lift? I'm a little gun shy as I'm on the 4th notch and the same chart that shows .95" 1st notch is the same chart that showed 4th notch 2.5" lift but I'm at 3.5" albeit with 1/4" spacer driver's side. So potentially the 1st notch could yield possibly 2"? Then all of a sudden I have a 6" lift- 26" center hub to bottom of fender?
  18. Jul 30, 2017 at 2:26 PM
    ChadsPride
    Im not very sure about all the notches on the 6112s but Marie should be able to get you straightened out.
  19. Jul 30, 2017 at 2:28 PM
    GrayMetalic 2015
    I will contact her
  20. Jul 30, 2017 at 2:30 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I'm not familiar with 6112's but on 5100's the bottom (0) is srock then it's .85, 1.75 & 2.5
    Your 1/4" spacer actually provides 1/2" of lift so that would put you around 3" or so.
    What I'm seeing on the 6112's is 5 notches.
    Bottom is stock then .5, 1.25, 2 & 2.5.
