Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jun 19, 2012 at 12:59 PM
    #1101
    moelov
    moelov Well-Known Member
    USA
    09 PreRunner SR5 Lifted
    Removed the Mud Flaps, Rock Deflectors and Head Rest. Limo Tint, I had 3" Toytec Lift, Procomp Nitrogen ES6000 shocks and Struts. AllPro UCA, AFE Pro Dry drop in filter, WeatherTecs. Now I have LR UCA's, Maxtrac Spindles, Eibach's, 5100's up front, Expos, 5160 for the rear, U Bolt Flip Kit, and Extended Brake lines.
    Does anyone else see that also. Should I get a 1.5" spacer match the front?
  2. Jun 19, 2012 at 1:07 PM
    #1102
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i had 1.25 spacers in the rear.....th rear stuck out a tad more
  3. Jun 19, 2012 at 1:08 PM
    #1103
    anthony250f
    Anthony
    San Diego, CA
    i agree on the double shear.....it looks like the uniuball adapter is alot thinner than the stock one....im going to have to get some measurements
  4. Jun 19, 2012 at 4:02 PM
    #1104
    JeremyGrey
    JeremyGrey Well-Known Member
    Ahwatukee, AZ
    2012 DCSB TX Pro Prerunner
    Can you do coillovers with spindles and not do UCA's?
  5. Jun 19, 2012 at 4:07 PM
    #1105
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    You don't usually need uca's until you lift using the coils 3" or more... spindles just move the hub down and don't change the suspension geometry.
  6. Jun 19, 2012 at 4:14 PM
    #1106
    JeremyGrey
    Ahwatukee, AZ
    thanks for the info. i was looking at fox's non-resi c/o. their non-resi c/o are only made in "extended travel". their website said that these need aftermrket UCA's. Im only looking at their non-resi because they are about $200 cheaper. is this correct that "extened travel c/o" have to have aftermarket UCA's?
  7. Jun 19, 2012 at 4:19 PM
    #1107
    nfs257
    DFW
    She gone
    You didn't explain that!!!!!!!! They may have to be aftermarket to fit around it... :notsure:
  8. Jun 19, 2012 at 4:26 PM
    #1108
    JeremyGrey
    Ahwatukee, AZ
    damn, this is gonna get expensive...
  9. Jun 19, 2012 at 4:41 PM
    #1109
    JeremyGrey
    Ahwatukee, AZ
    ok, another question. is the ride bad with OEM springs and billies set at .85?
  10. Jun 19, 2012 at 4:43 PM
    #1110
    nfs257
    DFW
    She gone
    Not real bad from what I have heard. Search the site there are reviews...
  11. Jun 19, 2012 at 4:48 PM
    #1111
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Not at all. I have mine at 1.75 which is worse and it rides like butter
  12. Jun 20, 2012 at 1:13 PM
    #1112
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    What are you guys running in the rear besides Bilsteins? I'm going with the AllPro Exp leafs (4" unloaded) and I want to run nicer rear shocks than billies. But Icons show as 0-2 lift on DSM, I'm looking at the Fox shocks on all-pro's website but they don't show any specifics.
  13. Jun 20, 2012 at 1:24 PM
    #1113
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    if your going to go with the expos youll need a 10" shock in the rear, im running the expos on my truck with 10" 5150's, here are the dimensions for the 10" shock
    Shock Travel/Body 10.02"
    Extended length 25.91"
    Collapsed Length 15.89"
    hope this helps
  14. Jun 20, 2012 at 1:25 PM
    #1114
    Dromlace
    Michael
    Montgomery, AL
    Is this going to be the same for a 2nd gen?
  15. Jun 20, 2012 at 1:36 PM
    #1115
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    it should since the expos stated 3" lift but really gave me 4-5". just give all pro a quick call and ask them what size shock you need to run with the expos if they say 10" shock then those are the dimensions for the billy 5150's, and if your looking for a different manf. then i would look for a shock with those dimensions or close to it.
  16. Jun 20, 2012 at 3:22 PM
    #1116
    Hiatt1991
    Hiatt
    Ventura, CA
    Im running swayaways in the rear. They are pretty great
  17. Jun 20, 2012 at 3:29 PM
    #1117
    Manwithoutaplan
    ID
    yea they are pretty beefy.
  18. Jun 20, 2012 at 5:55 PM
    #1118
    Dromlace
    Michael
    Montgomery, AL
    Okay cool guys. I emailed AllPro and Kurtis said 9.5 travel.. So can you use a shock w/ 10" of travel?
  19. Jun 20, 2012 at 6:04 PM
    #1119
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I just ordered some maxtrac spindles. I'm thinking of replacing my stock coils w/OME 883's w/5100's set at 0. Do you guys think I'll have major BRO lean with just my 2' aal? ________________
  20. Jun 20, 2012 at 6:16 PM
    #1120
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    that setup will grant u 5.5" of lift in the front vs your 2" in the rear, now obviously factory rake will put u at maybe a grand total of 3.5" of rear lift but it really all depends on the condition of your leaf springs. either way you should be nose high with that setup.
