Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Oct 21, 2017 at 8:07 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Bump if anyone's got some info would appreciate it. Thanks
    ChadsPride likes this.
  2. Oct 21, 2017 at 8:14 PM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    From what I understand eibach makes 1.5" and 2.5" lift coils. so you would end up at 5.5" or 6.5" in the front with the 5100's set at 0. Then you would need 4" or 5" in the rear. I can't comment on the icons because I do not know which ones you are looking at but I know the extended length 5100's (B110) are 16" collapsed and 27" extended and they work really well at 4 inches.
    ChadsPride and PapaBear[QUOTED] like this.
  3. Oct 21, 2017 at 8:49 PM
    PapaBear
    Austin
    SIN CITY
    These are Toytec branded Eibachs, 620lb, there made to do 3in, but are very stiff if you don't have weight out front, that's why mine are set at 0. Even at 0 they provide 1.6in~ over stock.
    They are extended length icons, there like 15.7 and 26.8 exactly, honestly trying to see if anyone runs them. Even if I have slight rake il be fine, just making sure these would fit.
  4. Oct 22, 2017 at 7:01 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Do they lift 3 or 1.6? Either way you'd be at 7 or 5.6 total over stock. You'd need like 4 or 6 in the rear to be close to level & shocks aren't going to lift the rear.
  5. Oct 22, 2017 at 12:59 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2023 TACOMA LIMITED DCLB LIFTED
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 5% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, LOCK WHEELS 17 X 9 -12 W 275/70R17 TOYO OPEN COUNTRY TIRES
    They make two different models on these coils
    112-620 1.5 lift
    521600 3" lift
    Both should be set at 0 when used.
    ChadsPride and PapaBear like this.
  6. Oct 22, 2017 at 1:46 PM
    PapaBear
    Austin
    SIN CITY
    They lift 1.6~ at 0" on billies, 620lbs for plate bumper, etc. I'm not going to run anything which means 1.6~ at 0" for me.
    7? 5.6 is highest, probably going to settle to 5.3 - 5.4 ~ over stock after a little while.
    As I said, I'm ok with a little rake, that's why I was asking if extended icons are good for 3.5. I understand shocks don't provide lift, I was asking if someone ran them with a similar setup or if I should stick with b110's or go down a different route, that's all.
  7. Oct 22, 2017 at 1:48 PM
    PapaBear
    Austin
    SIN CITY
    Key word there, should. Previous owner of these had it at .85 and stated it was too stiff, but he was trying to get lift and purchased the wrong springs.
    That's why I'm installing them at 0" on Maxtracs. Should be just stiff enough to pull the sway bar.
  8. Oct 22, 2017 at 3:14 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    I was just confused cause @PapaBear first said they were made to do 3" then he said 1.6. That's why I said 7" or 5.6", if they were 3" you'd be at 7".
    I know Eibach makes 2 different ones & most common is the 1.6".
    Can't help with the rear shocks, I have no experience with Icons & haven't looked at their specs. I'm running the Bilstein 5100's (b110).
  9. Oct 22, 2017 at 3:22 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    @PapaBear these say they're good up to 3.5" of lift so as long as you don't go over that you should be good. Wheelers says my b110's are good to 5" but I'm at 6" & have not topped out or bottomed out. Hope this helps.
  10. Oct 22, 2017 at 3:44 PM
    PapaBear
    Austin
    SIN CITY
    Even though every place says 3.5, that doesn't seem accurate. Collapsed and extended lengths between the two are not even .5" difference. Very weird. The real reason I want the icons is for rebuild ability.
  11. Oct 22, 2017 at 3:51 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Wheelers says the Icon are 15.9" x 26.8" they're really not that far off of the b110 at 16.34″ X 27.28″. I guess enough to make a difference.
  12. Oct 22, 2017 at 3:52 PM
    PapaBear
    Austin
    SIN CITY
    Still confusing non the less. I'll call Icon tomorrow when they're open and see if I can get an answer.
  13. Oct 22, 2017 at 3:56 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    One day I'd like better shocks front & rear with remote resi's but don't know if any rear that are long enough.
  14. Oct 22, 2017 at 3:57 PM
    PapaBear
    Austin
    SIN CITY
    That's my dilemma :anonymous:
  15. Oct 22, 2017 at 4:08 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    It's a little harder at 6". lol
  16. Oct 22, 2017 at 7:23 PM
    joallen001
    joallen001 Member
    Huntsville
    2015 SR5 DC prerunner
    I am fixing to install 4" maxtrac spindles and I got a new leaf pack i ordered for 4" of lift. It's an ome leaf pack and they sent an add a leaf. What should I set my bilstein 5100 at on the front to level out with the rear.
  17. Oct 22, 2017 at 8:18 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Do you want to retain the factory rake?
    + or - 1.5"
    (Mine was factory raked at 2")
  18. Oct 23, 2017 at 7:55 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I plan on about 7.5” in the rear on my new truck and will probably go with some king 12” travel RR’s. The B110’s on my old truck were toward the end of their travel at 7” but still rode fine. So that is always an option.
  19. Oct 23, 2017 at 7:58 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    @SpruceTaco and I, I think can both agree that the B110’s are a good length for your desired amount of lift and the extended and collaped numbers on the icons and the B110’s being so similar I’d say the icons should work just fine
    SpruceTaco and ChadsPride like this.
  20. Oct 23, 2017 at 8:20 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    The measurements are very close & I believe he said he was only going up 3" in the rear.
