Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Nov 9, 2017 at 8:39 AM
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    The Dakar's have been great for me. Absolutely no squeaking and ride great. I also like the All Pro standards however they did start to squeak on me.
    Boomerswany and ChadsPride like this.
  2. Nov 9, 2017 at 11:24 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    You are more than welcome and thank you again for your business!!
  3. Nov 9, 2017 at 3:32 PM
    TitoBrown
    TitoBrown Member
    2013 Tacoma Access Prerunner
    So I'm at the final stages of buying everything to get this lift going. Marie has been so patient with me and kind enough to quote me a few different options. Coming here for the final opinions.
    Option 1:
    4" Maxtrac lift + 2" blocks.
    No Questions here - understand what I am getting with this option.
    Option 2:
    4" Maxtrac lift with Dakars medium load
    What benefit is there to dakars if I'm mostly a daily driver + very occasional casual dirt roads? I am aiming to keep the truck level (don't want rake) - do Dakars in the rear maintain a level look?
    Option 3:
    4" Maxtrac lift with Dakars and Bilstein 5100s front and rear.
    Once again, looking to maintain level appearances. With bilsteins on lowest setting, is there any reason to get bilsteins? Ride quality?
    Thanks for your input!
    HeadStrong Off-Road likes this.
  4. Nov 9, 2017 at 3:55 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I like option 3, new Bilsteins will ride better than stock, if I'm not mistaken the Dakars will increase our load capacity & won't sag over time like the stock ones. If they lift 3" I believe you may have a slight rake with the Dakars but not as bad as factory, maube only an inch. Maybe someone with Dakars will chime in.
  5. Nov 9, 2017 at 8:58 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I vote option 3 for ride quality. Dakars are great and won't sag. I've had mine on for almost a year and have put several hundred lbs in the bed a few times and still ride great. Glad I went with full leaf packs and skipped the error trial with blocks or aal.
    SpruceTaco and ChadsPride like this.
  6. Nov 25, 2017 at 3:42 PM
    toolmandoo
    toolmandoo "Crescent Fresh"
    Jeremy
    Orlando
    2015 TRD Sport
    S.O.S bolt-on sliders, XB Morimoto fogs, bumper mounted 20" led bar, amber leds in grille("raptor" style) and Relentless fab hi-lift mount. Plastidip?
    Hey guys, after reading through every thread on the forum, I think I've finally made my decision on upgrading the current stock suspension. Looking for a completely level look that can fit 255/80/17 cooper St maxx. Let me know your thoughts and if I forgot anything. All advice is appreciated!
    1. Icon stage 1 suspension kit
    2. Maxtrac 4" spindles
    3. All-pro standard leaf pack
    4. Extended brake lines (front and rear)
    5. Longer u-bolt kit
    Thanks!
    99TacoDriver and ChadsPride like this.
  7. Nov 25, 2017 at 3:45 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Would get the All Pro Ubolt flip kit with wheelers super bumps ( or Timbrens if you got the coin)
    toolmandoo[QUOTED] likes this.
  8. Nov 25, 2017 at 8:40 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    You forgot 1 can of rostoleum black paint
  9. Nov 26, 2017 at 9:10 AM
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    Alright guys, I’m wanting to go higher with my truck.
    Current:
    Maxtrac spindles 4”
    Bilstein 5100s set @ 2.5”
    (total 6.5” roughly)
    I know I’m gonna need new UCAs to go higher, i was thinking about the built right or light racing. My plan is to lower my 5100s to 1.75” then throw on lift coils (don’t know which ones yet).
    My question is what UCA are you guys running if you have more than 6.5” of lift?
    ChadsPride likes this.
  10. Nov 26, 2017 at 10:00 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    UCAs Don’t care how much lift you have. They only care about how much travel your coilover has. If you don’t have a extended travel coil over shock a new UCA will just make it pertier wheel well.
  11. Nov 26, 2017 at 10:43 AM
    Taco gator
    J.D.
    Lakeland, FL
    2014 2wd Taco
    But if i lift my truck higher my uca won’t have enough travel so yes i want more travel, that’s what I’m asking. I’m just asking what everyone is running.
  12. Nov 26, 2017 at 11:33 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Lift does not give you travel. Your shocks are your limiting factor right now not your UCAs.
  13. Nov 26, 2017 at 12:44 PM
    ChadsPride
    887 coils and drop those 5100s down to zero
    UCA is much a personal preference (as for which one you go with)
    Taco gator[QUOTED] likes this.
  14. Nov 27, 2017 at 8:05 AM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    I was at about 8" on my old truck with maxtracs with stock UCA's and the UCA's hit the coils almost immediately on down travel. I would suggest JBA UCA's as the ball joints run at a higher angle then any other UCA's on the market as well as allowing much more room between the UCA and to coil
  15. Nov 27, 2017 at 2:48 PM
    Taco gator
    J.D.
    Lakeland, FL
    2014 2wd Taco
    Thanks man, i appreciate it
  16. Nov 27, 2017 at 2:49 PM
    Taco gator
    J.D.
    Lakeland, FL
    2014 2wd Taco
    Thank you sir
    ChadsPride[QUOTED] likes this.
  17. Dec 3, 2017 at 6:38 AM
    raventaco
    raventaco Be Prepared
    Lane
    Avondale
    06 Pre-runner Stormtrooper
    What’s the better looking/fitting tire for a 4” spindle kit. 285/70/17 or 255/85/17?
  18. Dec 3, 2017 at 7:08 AM
    ChadsPride
    raventaco[QUOTED] likes this.
  19. Dec 14, 2017 at 6:32 PM
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Anyone in here have any experience with the maxtracs rear shocks?
  20. Dec 15, 2017 at 3:22 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Terrible. They come where you have to press that hard ass bushing in the eye then it wouldn’t fit in the shock mount without bending the tabs out a lot to fit.
