Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Apr 14, 2018 at 9:36 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Not anymore over kill than king or fox :devil:
  2. Apr 14, 2018 at 9:39 PM
    i30nes
    i30nes Well-Known Member
    Tampa, FL
    21 MGM Sport
    True... Not helping in the decision. What's your setup?
  3. Apr 14, 2018 at 9:43 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    ADS extended travel w/resi with camburg uca and dakars with fox 2.0 w/ resi
  4. Apr 14, 2018 at 10:04 PM
    i30nes
    Tampa, FL
    21 MGM Sport
    Particular reason for the fox in the rear?
  5. Apr 14, 2018 at 10:14 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Cheaper, had a budget and it was all I could afford at the time.
  6. Apr 15, 2018 at 10:14 AM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    Hey guys new to tacomaworld and just found this thread. I was going to get the Maxtrac lift installed at a local shop but when I finally got the money they said they were booked until the summer. If anyone on here installed themselves at home. How hard was it? Thanks in advance. Any and all info is appreciated.
    ChadsPride likes this.
  7. Apr 15, 2018 at 10:26 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    It's a pretty straight forward install. Just remove and replace. Can be done in your driveway with a basic set of hand tools. Suggest doing the brake lines ahead of time to save time on install as they are the hardest part of install.
  8. Apr 15, 2018 at 10:34 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    So switching out the lines for the extended ones would be recommended to do first. How difficult is it? I've seen install videos but I know there is a huge difference between seeing something and actually doing it?
  9. Apr 15, 2018 at 10:43 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    For me I had to make a shim to hold the clip tight to the bracket where the upper hard line and the steel braided line meet. I used a washer that had to be reemed out to a bigger i.d. I think it was a 5/8 I.d washer and the brake line was 11/16. I had to do it for the back as well. Not sure if others had this problem though. But that was the hardest part. Just make sure when you bleed the system the key is in the on position with engine off.
    Pushincaskets and ChadsPride like this.
  10. Apr 15, 2018 at 10:47 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    Okay thanks for the info man.
  11. Apr 15, 2018 at 10:50 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    If you have to loosen the lower control arms make sure you mark the alignment cams so you can keep it close to alignment
    Edit: also check with your local thread. Pretty of people will help for some chow and cold beverages.
  12. Apr 15, 2018 at 10:57 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    Do i just mark them with a Sharpie?
    And will do thanks man.
    One more thing time wise about how long did it take you?
  13. Apr 15, 2018 at 11:00 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Sharpie, whiteout, or a paint pen will do. I did more than just spindals. I replace everything suspension wise from front to back in about 6 hours
  14. Apr 15, 2018 at 11:02 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Another tip don't worry about the front brake dust shield. Just remove it. it won't fit back on the maxtracs
    nach73 and ChadsPride like this.
  15. Apr 15, 2018 at 11:20 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    Gotcha. I'm a little mechanically inclined so hopefully it won't be too difficult. I might just get the shocks installed a day before doing the install to shave some time off. And gotcha no dust shield. Thanks for all the info. Much appreciated man.
  16. Apr 15, 2018 at 2:35 PM
    i30nes
    Tampa, FL
    21 MGM Sport
    Gotcha. Maybe once I get some other items paid off or a sale pops up I may pull the trigger.
  17. Apr 15, 2018 at 3:18 PM
    Prodigy0325
    Prodigy0325 Well-Known Member
    So Cal
    2011 Toyota Tacoma PreRunner
    Maxtrac Spindles, 5100 front and rear, Headstrong 3AAL, KMC XD 301 on Toyo Open Country AT2
    https://www.youtube.com/watch?v=6vlaPRKqv00
    this is what i used to install my lift...
  18. Apr 15, 2018 at 4:56 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Like the others have said it's a straight forward install. If you know what direction to turn a socket & how to bleed brakes then you'll do fine. Just be sure to torque everything to spec. There's a sticky in the 2nd Gen forum that has every torque spec.
    desertrunner24 and ChadsPride like this.
  19. Apr 15, 2018 at 5:01 PM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    Thanks man. I'll check it out.
  20. Apr 17, 2018 at 3:47 PM
    Lefkos
    Lefkos Well-Known Member
    Winston
    Las Vegas
    PreRunner
    Need a suggestion on a spring that’ll put me up 2 inches!
