Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Aug 14, 2018 at 2:06 AM
    sblspawn
    sblspawn Well-Known Member
    Could maxtrac generate driveshaft vibration?
  2. Aug 14, 2018 at 5:16 AM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    It shouldnt, but u could try dropping your carrier bearing about 1/2 to 3/4 of an inch, may fix it
    sblspawn likes this.
  3. Aug 14, 2018 at 6:23 AM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    It shouldn't since it's only replacing the steering knuckles up front, what will give you vibes most likely are bad angles on the drive shaft.
    sblspawn[QUOTED] likes this.
  4. Aug 14, 2018 at 6:39 AM
    sblspawn
    maxtrac recommends 4" 2", so, it should be fine with that lift, right?
  5. Aug 14, 2018 at 6:44 AM
    christian06
    Cali
    U have to adjust the drive line angle,
  6. Aug 14, 2018 at 6:55 AM
    sblspawn
    So, even with the 4" front and 2" rear I will need the carrier bearing spacer?
  7. Aug 14, 2018 at 7:51 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    You should be fine, you may need to drop the CB to keep better angles and I believe the block is tapered so that will help as well. I have a 4 inch block in the rear and get minimal vibes at take off between 5 to 8 mph I don't really notice them unless I'm looking for them.
    ChadsPride likes this.
  8. Aug 14, 2018 at 8:06 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    You can do it with washers and the stock bolts just add a few and if it goes away your good if it gets better but not quite there add 1 or 2 until you find your sweet spot and then measure the thickness to find what size CB Drop you'll need or you can always leave it like that. Using one of those angle readers probably works best.
  9. Aug 14, 2018 at 8:09 AM
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
  10. Aug 14, 2018 at 12:27 PM
    sblspawn
    Thanks a lot, buddy! I really appreciate all the info! :)
    Jimmy92870[QUOTED] likes this.
  11. Aug 16, 2018 at 11:59 PM
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Hey @ChadsPride how many miles do you have on your Dakar’s? How’s the ride quaility and how much have they settled?
    For anyone running the standard all pro leafs with the maxtrac spindles. Do you have a bro lean? How do the all pros stand up over time (any sagging without weight)? Any squeaks like the Dakar’s?
    ChadsPride and nach73 like this.
  12. Aug 17, 2018 at 5:05 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Sup man. Had my Dakars about 2.5yrs now and love them. They give the ability to load up the truck without riding on bumps the whole time. AND, they flex VERY well out on the trails.
    I want to say they've settled close to an inch over the years.
    Ride quality is excellent IMO (I've got the light duty packs)
    My Dakars are a little squeaky even with the polyurethane bushings.
    BUT, my stock springs were way noisier in all honesty.
    Biscuits likes this.
  13. Aug 17, 2018 at 5:51 AM
    sblspawn
    Why I see so many people complaining so much about these noisy rear suspensions? Some guys even recommend greasing them very well before the installation.
    ChadsPride[QUOTED] likes this.
  14. Aug 17, 2018 at 5:55 AM
    ChadsPride
    Oh yeah. You're going to want to grease those bushings nicely before install.
    Like I said, and I genuinely mean it...my stock leafs were noisier.
  15. Aug 17, 2018 at 5:59 AM
    sblspawn
    I've seen some guys having hard time with some aal and squeaking noises. So, they have to grease the whole leaf before too?
  16. Aug 17, 2018 at 6:14 AM
    ChadsPride
    Not too sure about that :oops:
  17. Aug 17, 2018 at 8:29 AM
    Kel2427
    Kel2427 Well-Known Member
    Kellan
    2014 White Tacoma Offroad
    The mods have probably changed since last update.
    Has anyone had any issues with a popping noise when they turn a certain direction? For some reason, when I turn fully to the left side while driving, I'll hear a slight pop. It sounds and feels like its right around where the UCA's connect to the spindles, but nothing looks off and it still drives fine. I don't know if having stock UCA's may contribute to the issue, but its hard to diagnose exactly whats happening without totally taking off the wheel and messing with the spindle...
  18. Aug 17, 2018 at 9:25 AM
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    Need input on bumpers and fender flares to run for this LT kit.
    1. Who makes good fender flares and what size should I get?
    2. what are my options for my bumper when running LT?
  19. Aug 17, 2018 at 9:31 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    These are spindles
    Not a long travel kit.
    Advanced fiberglass is my favorite, though you don’t need glass for spindles
  20. Aug 17, 2018 at 11:11 AM
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    OKay. So you’re telling me since we have spindles, we won’t need glass for a long travel kit?
