Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Nov 5, 2018 at 6:43 AM
    sblspawn
    sblspawn Well-Known Member
    jejeje OK! How bad is the alignment?
    ChadsPride[QUOTED] likes this.
  2. Nov 5, 2018 at 6:43 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    It's really not bad at all! Very pleased about that. Going to try and drop it off this afternoon for proper alignment
    sblspawn[QUOTED] likes this.
  3. Nov 5, 2018 at 6:49 AM
    sblspawn
    Cool! The trick is to loosen the camber bolts just enough to remove the strut but never too much. How is the tranny acting with the new angle?
  4. Nov 5, 2018 at 7:22 AM
    ChadsPride
    Seems fine, no notable difference
  5. Nov 5, 2018 at 8:10 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Or you can Mark the cams to the frame and completely remove them and grease em so they don't seize.
  6. Nov 5, 2018 at 1:54 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Didn’t Moog come out with zerk cam bolts?
  7. Nov 5, 2018 at 2:44 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    They're not great, at least from the feedback I've gotten on em.
    Kolunatic[QUOTED] likes this.
  8. Nov 5, 2018 at 5:12 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    That’s what I heard
    Thanks
  9. Nov 6, 2018 at 2:54 PM
    sblspawn
    @Texoma I have a question for you, when you disconnected the UCAs from the Maxtrac spindles on Chad's truck, did you smack the spindle with a hammer or it wasn't necessary? I'm asking because I want to upgrade my struts. :)
    ChadsPride likes this.
  10. Nov 6, 2018 at 3:55 PM
    nach73
    nach73 Well-Known Member
    Nacho
    Pueblo, CO
    06' Pre-Runner TRD- Off Road
    5100's set @0 with 887 springs and 1.5 AAL. Satoshi Raptor grill, Halo Projector led Spyder headlights and syder taillights, Projector led Halo fog lights by Zack/Taco Nation, LED's everywhere else, Raceline 16x8 Assualt wrapped with Goodyear DuraTracs 285/75/16. Wet Okole seat covers, Paracord headrest handles by Cole/Dessert Dunes, Weather tech floor mats, JVC Arsenal KW-V200BT, 2 10" Kicker shallow mount, Alpine components, Alpine 1000 watt amp, interior is completely Dyna matted
    Was the ride that bad on the 3rd gen set-up?
    I picked up a set for whenever I get off my ass and install my maxtrac. I currently am running 5100s with 887s on the bottom setting and was gonna do a 3/4" spacer and 3rd gens shock/coils for somewhere around 5-6". I dont want the full 7" the 887s would give but more than the 4" utilizing some of the sht I've accrued. But if the 3rd gens stuck, new plan.
  11. Nov 6, 2018 at 3:58 PM
    ChadsPride
    They were stiff as shit in my humble opinion. Also, I did my have any weight on the front end at that time and they're meant for a 4x4
    These HS 2" coils feel way way better. Especially with upper control arms meant for that little extra travel. Very happy
    They were tight but I'll let him explain
  12. Nov 6, 2018 at 4:02 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    If you're removing and reinstalling shocks, there's no need to remove the UCA from spindle. Remove the LCA from spindle instead. Mark the alignment cams to the frame with a paint pen so that you can pull em, grease em, and reinstall em without throwing your alignment out. If you are changing out your UCA's for aftermarket, I would advise against beating on the maxtrac spindle too hard, it is cast. I used a pickle fork to separate them, sometimes the pickle fork tears in to the ball joint boot, so keep that in mind.
    ChadsPride and sblspawn[QUOTED] like this.
  13. Nov 6, 2018 at 4:04 PM
    sblspawn
    I had 3rd gen struts before and they did the job! They are a little stiff because the springs are rated for almost 720 lbs, more or less, but for the price that you can find them online, they aren't a bad choice. After all they are Bilsteins! :)
    nach73[QUOTED] and ChadsPride like this.
  14. Nov 6, 2018 at 4:07 PM
    sblspawn
    Got it! Thanks a lot, boss! :thumbsup: I thought that It could be better disconnect the UCA, the sway bar link and loosen the LCA just enough to remove the shocks.
  15. Nov 11, 2018 at 12:02 PM
    sblspawn
    Guys, if I go up tu 6" or 6.5" of lift on my Prerunner I will need aftermarket UCAs? I have 4" of the Maxtrac spindles already.
  16. Nov 11, 2018 at 2:37 PM
    ChadsPride
    Not necessarily but it will definitely improve the travel and therefore ride better in my opinion
  17. Nov 11, 2018 at 2:53 PM
    sblspawn
    Chad the man! :thumbsup: I have a question for you brother. Why did you say that the 3rd gen TRD struts were too stiff? I saw in an old thread that you were happy with them after removing your stock shocks. Are you comparing them to your new setup? I'm just curious! :)
  18. Nov 11, 2018 at 2:55 PM
    ChadsPride
    They felt better at speed than my stock SR5 assemblies but when going slower they were stiffer in my opinion.
  19. Nov 11, 2018 at 3:01 PM
    sblspawn
    What did you end up doing with the bro lean? Blocks?
  20. Nov 11, 2018 at 3:02 PM
    ChadsPride
    Just a half inch block on each side. I've got full Dakar leafs packs already.
    Didn't want to go too high on front and back because I still need to fit in low overhead places
