Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jul 25, 2012 at 8:17 PM
    #1261
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    That explains why yours looks like mine!!! Lol it is!!! As soon as I saw the pic I was like DUHH!! He has spacers on top!!
  2. Jul 25, 2012 at 8:25 PM
    #1262
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    I absolutely didn't pay any attention to them when I was putting them on. I could have sworn I removed the spacers when I took the factory shocks of and stored them. Damn these spindles, they got me so excited that I managed to create more work for myself tomorrow.
    senor taco mentioned that the longer coil goes on the driver side. How do you know which one that is?
  3. Jul 25, 2012 at 8:33 PM
    #1263
    YotaMatt
    West Point VA
    Not sure about that?!?!? I had mine all done yesterday and ended up pulling struts back out today to remove 3/4" top spacer...not that hard
  4. Jul 25, 2012 at 8:45 PM
    #1264
    sfcadams
    Dan
    Elizabeth, Indiana
    Yea, I know it's not hard to swap shocks/springs. I would just like to know how to tell which goes on the driver side and which goes on the passenger side so I won't have to redo it again....
  5. Jul 25, 2012 at 8:47 PM
    #1265
    YotaMatt
    West Point VA
    Maybe there's a number on the spring???
  6. Jul 25, 2012 at 8:53 PM
    #1266
    sfcadams
    Dan
    Elizabeth, Indiana
    maybe. waiting on those that know to chime in, lol....
  7. Jul 25, 2012 at 8:55 PM
    #1267
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I'm not sure How to tell, I would just measure it before hand on a flat surface. If your passenger side is higher then put that asssembly on your driver side.
  8. Jul 25, 2012 at 9:02 PM
    #1268
    sfcadams
    Dan
    Elizabeth, Indiana
    What about that brown sleeve on the top of my coils? I don't remember that showing when I first bought my truck. Are those supposed to be facing out or in or does it even matter?
  9. Jul 26, 2012 at 6:11 AM
    #1269
    sfcadams
    Dan
    Elizabeth, Indiana
    Not looking forward to swapping shocks/springs again after work, but that's what I get for not paying attention, lol
    If anyone could tell me before I do this tonight, should that brown sleeve thing on my coils in the picture above be showing or should I have it on the inside, or does it even matter? Finally one of the members above mentioned that one of the factory shocks/coils is specifically for the driver side as it is supposed to be a little taller I guess to maybe account for the taco lean. Does anyone happen to know which one it is and how to tell if you have the correct one? Different part # than the other one maybe???
  10. Jul 26, 2012 at 7:29 AM
    #1270
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Looking at the Brown sleeve I see in your pics. I've never seen those on the outside. You most likely have them backwards.
  11. Jul 26, 2012 at 7:31 AM
    #1271
    sfcadams
    Dan
    Elizabeth, Indiana
    Sounds good. I will make sure I put them on the inside when I take the spacer off this afternoon.
    Thanks!
  12. Jul 26, 2012 at 8:37 AM
    #1272
    maxtracbob
    maxtracbob Well-Known Member
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Geeezzzz... No one listen's to me.... lol... Since you haven't had it aligned yet and the toe is off... Toe in and that's when the tires are pointing towards each other will push the suspension UP and that's what is happening here... No worries it will be just fine when you get it aligned...
    Also while i'm here... If the front end is higher than the back this will effect caster... If you have not enough caster the truck will be darty and the truck will not hold a straight line... If you have too much caster the truck will feel slugish turning and it will take more effort to turn and it will track very straight.... I hope this helps.....Thanks
  13. Jul 26, 2012 at 11:18 AM
    #1273
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    Stock for now
    I love the look of this truck. What are you running for suspension in the rear.
  14. Jul 26, 2012 at 11:19 AM
    #1274
    sfcadams
    Dan
    Elizabeth, Indiana
    maxtracbob,
    Trust me, I listen to you, lol. In reference to the post of mine you quoted, I was asking why my front was so high. I failed to realize I still had my 2.5 inch spacers on the shocks/springs when I installed them (too jazed about getting the spindles on I guess). I only intended to run just the spindles and stock shocks/springs. If you continue reading from that post forward, you will see that someone showed me the error in my ways....
  15. Jul 26, 2012 at 11:25 AM
    #1275
    Davtopgun
    David
    Central Alabama
    Looks like he has blocks in the rear.
  16. Jul 26, 2012 at 1:20 PM
    #1276
    maxtracbob
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    SEE... lol........... I thought you were using that magnafying measuring stick.... Everything looks like it's 12"... I use it all of the time.....Hey bud... just trying to help........Thx
  17. Jul 26, 2012 at 1:20 PM
    #1277
    maxtracbob
    Bob
    Anaheim,Ca
    04 LJ (sorry)
    EVERYTHING
    Makes me want to buy a Tacoma.......
  18. Jul 26, 2012 at 1:35 PM
    #1278
    sfcadams
    Dan
    Elizabeth, Indiana
    DO IT!!!!
  19. Jul 26, 2012 at 5:24 PM
    #1279
    sfcadams
    Dan
    Elizabeth, Indiana
    Ok, spacers are off now. Now my truck doesn't look like a snob with it's nose in the air. Off to get it aligned tomorrow!
  20. Jul 26, 2012 at 5:34 PM
    #1280
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    Kind of makes me want to get spidertrax spacers for the back...
