Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Mar 5, 2019 at 9:00 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    You can use a 16" wheel but it needs to have at max of a 3.75" backspacing in order to fit. Wheel spacer are cheaper than new wheels. 17" wheel need to be 4.75" back spacing. Anything over that the rim hits the spindle
  2. Mar 5, 2019 at 9:28 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    I have 16" rims with 4.5" backspacing and 285/75/16 tires without problems. Its close but it does clear.
  3. Mar 5, 2019 at 9:31 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Sorry i was mistaken on the backspacing. My bad. I know my stock wheel wouldnt fit without 1.25 spacers. So a 16 with 4.5 should just fit.
  4. Mar 6, 2019 at 3:22 AM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    Check the torque on the steer stop bolts. Once I retorqued them to 112 ft lbs mine is quiet. Since then I’ve seen that it’s recommended 118 ft lbs. It’s worth a shot!
    05prerun82 likes this.
  5. Mar 6, 2019 at 7:34 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
  6. Mar 7, 2019 at 12:12 PM
    501taco
    501taco Active Member
    New to site! Love my 08’ tacoma. I know blocks are frowned upon but, is anybody running the 6.5 Maxtrac spindles with the 4 inch block in the rear on stock leafs. Wondering if this set up leaves you nose high. Hate the bro lean.
    ChadsPride likes this.
  7. Mar 7, 2019 at 12:18 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    Get the heavy duty dakars
  8. Mar 7, 2019 at 4:22 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    The 6.5 kit comes with a spacer for the front to get the extra 2.5"
    You're going to want to talk to Marie @HeadStrong Off-Road and swap those out for HS 2" lift coils and 5100s
    Running the 4" block out back may introduce axle wrap and to be honest the stock leafs on these trucks are crap (this is my humble opinion)
    Just replace your leaf packs with Dakars. You don't have to get the heavy duty ones. Those coupled with a much smaller block would be a better choice (buy once cry once)
    Also, what are you currently running as far as suspension front and rear?
    My humble opinion again...through time I've come to say these trucks are 2" positive take from the factory (front is ~2 inches lower than rear)
    So in theory, a 6.5" front and 4" rear will leave your rear end .5" lower (negative rake/bro lean)
  9. Mar 7, 2019 at 4:30 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Go chad
    ChadsPride[QUOTED] likes this.
  10. Mar 7, 2019 at 4:31 PM
    ChadsPride
    :fistbump:
    There's so many options it really comes down to how much you're willing to spend.
    I would rather see an enthusiast spend a little extra and be happier. But then again it just depends how much that person can afford.
  11. Mar 7, 2019 at 4:41 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Back to this mysterious clunking thing. Besides the lower bolts on the steering stops or whatever, anything else to check out. As luck would have it, mine started to clunk (most noticeable from drivers). Also have a heinous clunk from the rear. Though I'm fairly certain it's actually my spare tire mechanism as there is no spare in its place at the moment
  12. Mar 7, 2019 at 4:46 PM
    501taco
    I’ve got Bilstein 5100’s all around. Front set on 2.5. 1 inch block in rear right now. Thought about getting 4” Maxtrac, set my Bilsteins at 1.75 in front. Wasn’t sure about rear....aal? Don’t really do any off road. Love the look of a lifted Tacoma! Trying to stay married and not spend too much money
  13. Mar 7, 2019 at 4:46 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Maybe you're just not turning the radio up loud enough lol
  14. Mar 7, 2019 at 4:47 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Should have went with the rough country 4 inch lift for a grand
    ChadsPride and 501taco[QUOTED] like this.
  15. Mar 7, 2019 at 4:48 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    In my opinion if you're never going to leave the road don't spend three grand on suspension
  16. Mar 7, 2019 at 4:55 PM
    501taco
    I’m not gonna spend 3 grand,but I am gonna achieve the look I want off road or not.
  17. Mar 7, 2019 at 4:59 PM
    ChadsPride
    Haha!! I totally understand that.
    You could just do the spindles up front and drop your 5100s down a notch or two like you said.
    For the rear, I still vote new leaf packs. We are here to help you!
    501taco[QUOTED] and 05prerun82 like this.
  18. Mar 7, 2019 at 5:09 PM
    501taco
    I’ve already spent quit a bit just lurking around here. U can’t be on tacomaworld looking at all these nice trucks and not spend some money
  19. Mar 7, 2019 at 5:19 PM
    ChadsPride
  20. Mar 7, 2019 at 5:34 PM
    K-DubTaco
    Ken
    VB
    ‘25 TRD Off Road
    Mine was more noticeable on the driver’s side, but apparently both sides needed to be torqued. The only other things it could be is ball joints are bad or the sway bar links are worn out or possibly wheel bearings. Mine were fine and still did the clunking with the sway bar off, so I reinstalled it and knew the sway bar links were good. Check your ball joints and bearings. Start with the torque of the steer stops first. Let us know what you find!
