Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Sep 4, 2019 at 5:31 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    :drool::drool::drool:
    No spacers front and rear?
  2. Sep 4, 2019 at 5:46 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    uhhhh no, i got 2" spacers front and rear lol, I need them haha
    ChadsPride[QUOTED] likes this.
  3. Sep 4, 2019 at 5:46 PM
    ChadsPride
    I bet! Love the look
    Alfuh[QUOTED] likes this.
  4. Sep 4, 2019 at 5:49 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    thanks lol, just waiting on long travel now, then I can get rid of the spacers haha
  5. Sep 4, 2019 at 6:16 PM
    ChadsPride
    What kit do you have in mind? I have an end goal being LT front and a simple tube bed cage with some long shocks.
  6. Sep 4, 2019 at 9:16 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    im gonna go full front/rear Camburg kits. 3.5" front and SUA kit in the rear, spindles as well; gonna do a bed cage too haha
    pilau and ChadsPride[QUOTED] like this.
  7. Sep 5, 2019 at 4:01 AM
    ChadsPride
    :taco: :militarypress:
  8. Sep 15, 2019 at 2:08 PM
    c808nner
    c808nner Well-Known Member
    Oahu
    1995 Tacoma 3.4 MT Extracab
    Okay I'm impatient and tired of having so many parts just sitting so I think Im just going to order everything else I need suspension wise and slap everything on and run 265s and stock sport wheels with a spacer until I can afford new wheels with the correct backspacing and 33s.
    I'm planning on running
    Front:
    5100s @1.75 with stock coils (maybe upgrade to 884s in the future if Im not happy with ride quality)
    Maxtrac Spindles w/ extended brake lines
    Rear:
    All pro expos
    1ish" block depending on how she sits post lift
    B110s
    Now I know I need to order extended brake lines for the rear, do I need to order anything else? I plan on buying a driveshaft spacer post lift so I can measure the exact length needed.
    ChadsPride likes this.
  9. Sep 15, 2019 at 2:13 PM
    ChadsPride
    I would just do the 5100s up front maybe on the first clip and no block in the back with the all pro expo leaf packs.
    Maybe do a ubolt flip kit and aftermarket bump stop front and rear while you're doing the stage 1
  10. Sep 15, 2019 at 3:10 PM
    c808nner
    Oahu
    I considered it after seeing you recommend it a couple times to other people (just finished reading all 656 pages), but don't really do any off roading so didn't think they were necessary. Have seen cb drop and longer ubolts discussed was wondering if those were necessary?
  11. Sep 15, 2019 at 3:30 PM
    ChadsPride
    You'll certainly need longer ubolts with the aftermarket leaf packs, they'll probably come with them.
    Flip or no flip I think super bump bump stops are a good idea
    c808nner[QUOTED] likes this.
  12. Sep 15, 2019 at 3:40 PM
    i30nes
    i30nes Well-Known Member
    Tampa, FL
    21 MGM Sport
    The CB drop probably wouldnt hurt since you would be adding the drive shaft spacer. It's not always needed from what I recall but it's a quick item to take care of since you will be down there.
    c808nner and ChadsPride like this.
  13. Sep 15, 2019 at 5:51 PM
    c808nner
    Oahu
    Thank you guys for input. Also I know with 16” wheels the backspacing is supposed to be 4.5 or lower. However finding/purchasing wheels in hawaii is quite hard due to shipping so choices are quite limited. I found FJ trail team ones that have a backspacing of 4.84 and saw that two people in this thread run them without spacers. One guy said 285s we’re fine but when he went up to 35s that’s when he ruined his tires, so if I don’t go any larger than 33s would i be fine with them?
  14. Sep 16, 2019 at 1:15 PM
    dblase
    dblase Well-Known Member
    2017 Tacoma
    Thinking about the 6.5 lift with fox coilovers, my truck is a pavement princess so would i notice a difference in ride quality with coilovers vs the spacers?
  15. Sep 16, 2019 at 2:16 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    no matter what, coilovers will always ride better than spacers, but a severely cranked coilover will ride exactly like spacers. it all depends how its setup
  16. Sep 18, 2019 at 12:32 PM
    c808nner
    Oahu
    A great deal locally popped up on some wheels and tires and I’m hesitant to buy it because of the tire size. Fuel Beast 18x9 4.5BS wrapped in procomp 305/60s. Will it rub with 5.75” in the front and 5” in the back?
  17. Sep 18, 2019 at 12:52 PM
    ChadsPride
    It might but a box cutter and fresh blade on the bottom inside corner of the front plastic fender flares and all is well.
    If you want to stuff that at full lock, you'll need a cab mount shop.
  18. Sep 18, 2019 at 1:46 PM
    c808nner
    Oahu
    Thanks for the quick reply, guess I'll be going with these before I can order my spindles
  19. Sep 18, 2019 at 2:36 PM
    ChadsPride
    No problem, if they are extreme offset the rubbing will be worse.
  20. Sep 18, 2019 at 2:47 PM
    c808nner
    Oahu
    -12 offset. Curious as to how far they'll stick out past the fender but I don't think many people ran 305/60 in here with 4.5 backspacing
    Edit: just found this website https://www.customwheeloffset.com/w...t_from=305&sort=date&make=Toyota&model=Tacoma and I think 305s will stick out too far, might have to pass on the deal even though I like the wheels.
