Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jul 30, 2012 at 6:23 AM
    #1301
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Just curious,...
    What did you guys torque the two lower ball joint bolts/nuts to??
  2. Jul 30, 2012 at 7:12 AM
    #1302
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    :notsure: they don't move though...
  3. Jul 30, 2012 at 8:05 AM
    #1303
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Tight as possible lol
  4. Jul 30, 2012 at 8:12 AM
    #1304
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    Obviously less if you only have one ball...jk my one balled friends.
  5. Jul 31, 2012 at 8:53 AM
    #1305
    Manwithoutaplan
    ID
    how did everybody's install go??
  6. Jul 31, 2012 at 11:11 AM
    #1306
    sfcadams
    Dan
    Elizabeth, Indiana
    Too easy (unless you put your stock springs/spindles back in as well, forget to take off the spacer lift that you had on them, and then wonder why your nose is pointing at the sky)
    I wonder who that guy was that did that.............????
    :spy:
  7. Jul 31, 2012 at 11:21 AM
    #1307
    Manwithoutaplan
    ID
    well with tw007 we had to change the cup on the bilstein 5100. Le hiatt changed them on the truck he is the man :D.
  8. Jul 31, 2012 at 10:44 PM
    #1308
    twf007
    twf007 Active Member
    Alex
    San Clemente, CA
    Tacoma Rock Lizard Buggy
    Buggy on tons, 40s, 4 speed atlas, 2rz, and Amazon products everywhere
    Haitt had a really sweet method of getting them off safer then using a coil compresser in my opinion.
  9. Aug 11, 2012 at 7:18 PM
    #1309
    moelov
    moelov Well-Known Member
    USA
    09 PreRunner SR5 Lifted
    Removed the Mud Flaps, Rock Deflectors and Head Rest. Limo Tint, I had 3" Toytec Lift, Procomp Nitrogen ES6000 shocks and Struts. AllPro UCA, AFE Pro Dry drop in filter, WeatherTecs. Now I have LR UCA's, Maxtrac Spindles, Eibach's, 5100's up front, Expos, 5160 for the rear, U Bolt Flip Kit, and Extended Brake lines.
    Ok I have a question for those who have installed their own spindles.
    Im at the point that i have to install the tie rod but i can't get it to tighten. When I try to tighten the nut, the bolt on the ball joint just keeps turning.
    Any suggestions.
  10. Aug 11, 2012 at 8:04 PM
    #1310
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Hit on it with a hammer while you try and tighten it..an impact would work the best
  11. Aug 11, 2012 at 10:07 PM
    #1311
    anthony250f
    Anthony
    San Diego, CA
    ok im a pro at this! had to do it alot last night....wedge a bottle jack against the bottom of the uca and the top of the tie rod.....or if the stock spindle is still on....put a jack under it
  12. Aug 12, 2012 at 6:58 AM
    #1312
    moelov
    USA
    Na, what I was trying to explain is how to put it back. I have the new spindle installed just can't get the ball joint in the tie rod to tighten because it.keeps on spinning.
  13. Aug 12, 2012 at 9:12 AM
    #1313
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I used a large C clamp at a slight angle to press them together while i tightened the bolt with a air gun.
  14. Aug 12, 2012 at 9:21 AM
    #1314
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    Clean the nut and threads on the tie rod as well as you can. Lubricate both and it should go on. If not try holding as low as you can on the threads with a pair of needle nose pliers than try to tighten. Do not over tighten that is why you have a cotter key. Also you might need a new outer tie if you replace it count the turns when you remove it. Put the new one on with the same amount of turns. It will keep the vehicle drive able until you get an alignment. Broken tie rod is bad news. Hope this helps.
  15. Aug 12, 2012 at 10:46 AM
    #1315
    anthony250f
    Anthony
    San Diego, CA
    Yeah....you just put a bottle Jack against the top of the tie rod Nd the bottom of the uca
  16. Aug 12, 2012 at 2:02 PM
    #1316
    moelov
    USA
    Ok I got it done! It was quite simple. I just got a rubber mallet and gave it a few pounds till it wedge in. From there it was good to tighten.
    Thanks for the replies! Now bleed the brakes and to get an alignment, hope the guys at the dealership understand how to align with the LR UCA. Cross my fingers!
    I will post pics after the alignment and the Suspension settles.
  17. Aug 12, 2012 at 8:26 PM
    #1317
    moelov
    USA
    What I spent doing this weekend. An all new suspension.
  18. Aug 12, 2012 at 8:56 PM
    #1318
    sfcadams
    Dan
    Elizabeth, Indiana
    Spindles with 5100s/Eibachs for right around 6.5" to 7" of lift??
  19. Aug 12, 2012 at 9:43 PM
    #1319
    YotaMatt
    West Point VA
    looks like he had billies set at 0" :notsure:
  20. Aug 12, 2012 at 10:24 PM
    #1320
    sfcadams
    Dan
    Elizabeth, Indiana
    yea, I was thinking billys at 0" and maybe Eibachs for the 1.6 or so they provide or something along the lines of that...
    I change my original thought and bet he is at 5.6" or so of lift....
    Maybe he will chime in.
