Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Sep 20, 2012 at 2:46 AM
    #1461
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Maxtrac spindles, 1.6" eibachs, bilstein 5100 set at 1.75", 1.5" aal and 4" block!!! I'm at 29 1/2" front and 29" in rear from center of hub to fender...will add better pic once the sun comes up
  2. Sep 20, 2012 at 2:47 AM
    #1462
    YotaMatt
    West Point VA
    Btw...it rides and handles
    Like shit and will be coming down some today :)
  3. Sep 20, 2012 at 4:06 AM
    #1463
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    I was just thinking that as I was reading it. I have the 1.6 eibachs with 5100s at 0 and it rides pretty damn good.
  4. Sep 20, 2012 at 10:03 AM
    #1464
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Put the bilsteins at 0 and remove the block....mine rides so good up front
  5. Sep 20, 2012 at 11:20 AM
    #1465
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    This... Do this.
  6. Sep 20, 2012 at 4:30 PM
    #1466
    YotaMatt
    West Point VA
    So I went with .85" setting with eibachs and replaced 4" block with 2"...also removed sway bar
    Bird33 likes this.
  7. Sep 23, 2012 at 6:03 PM
    #1467
    socal_av
    socal_av Well-Known Member
    Rudy
    Palmdale <CA
    2012 TACOMA DC LB Sport Mag Gray
    alot soon. hopefully
    So finally did the install today... Me and a buddy.. Took our time and we were so tired from lack of sleep.. Took us 4-5 hours... 5100 all around,stock coils, wheelers 2in add a leaf and spindles... 5100 make the truck ride so much smoother....
  8. Sep 23, 2012 at 6:55 PM
    #1468
    socal_av
    Rudy
    Palmdale <CA
    Forgot to mention... Those are 265/70-17 General grabber at2.. Measured 25in for the front and 25in and about 1/5 of an inch in the rear.. I'm Sure the rear will settle a little bit.
  9. Sep 24, 2012 at 6:48 AM
    #1469
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    great job! what do you have the 5100 set at in the front?
  10. Sep 24, 2012 at 8:45 AM
    #1470
    socal_av
    Rudy
    Palmdale <CA
    I set them at 0. I wanted it to be leveled. Any higher and I would be nose high.. Nice is alot smoother compared to stock.
  11. Sep 27, 2012 at 2:08 PM
    #1471
    Hiatt1991
    Hiatt
    Ventura, CA
    Looks awesome dude!
  12. Sep 27, 2012 at 7:39 PM
    #1472
    blitton08
    blitton08 Well-Known Member
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Maxtrac Spindles, Bilstein 5100s set 0 in front with Eibach Springs, 2.5" block in rear with OME Dakar Leaf Springs
    Just ordered maxtrac spindles today and bilstein 5100s for the front. Ill be setting the 5100s at 0 and i already have a 2 1/4" block in the back... do yall think ill have bro lean, or be pretty close to level?
  13. Sep 27, 2012 at 8:32 PM
    #1473
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    You should be pretty level with that setup. I would suggest a 2" AAL instead of a block though. Blocks cause many problems down the road, and an AAL only costs slightly more then the blocks.
  14. Sep 27, 2012 at 8:50 PM
    #1474
    blitton08
    Brandon
    Georgia
    06 XSP White 4D 2WD
    Thanks man. I will most likely do that in a week or so after i see how how it sits once the spindles are on.
  15. Sep 28, 2012 at 9:01 AM
    #1475
    zimm52
    nothing yet!
    I have been waiting way to long. Although i dont have all the money for exactly what I want, I think Im going to do it in stages. Planning on ordering spindles, and 2 inch add a leaf for starters. Should be level right? Then in a year or so upgrading to 5100's and eibachs, plus all pro springs. I just want it lifted now!
  16. Sep 28, 2012 at 9:09 AM
    #1476
    Davtopgun
    David
    Central Alabama
    If you just want the 4" in front and 2" in back (that will be level) then there is no point in swapping springs and switching to 5100 in the future. The first setup you're talking about will ride great.
  17. Sep 28, 2012 at 9:11 AM
    #1477
    zimm52
    nothing yet!
    thank you. No problems then fitting in 285's with that set up right? I know you have 35's, but are set higher. ( forgive me if I am wrong)
  18. Sep 28, 2012 at 9:22 AM
    #1478
    anthony250f
    Anthony
    San Diego, CA
    I had to cut my cab mounts at 5" and beat the pinch welds ...it rubbed pretty Damn bad.....but the other side didn't at all
  19. Sep 28, 2012 at 9:37 AM
    #1479
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Anthony when are you getting 35 :spy:
  20. Sep 28, 2012 at 9:48 AM
    #1480
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    U can fit them but u will rub, how tall are u going, I had terra grapplers that were 285/60/18 that didnt rub to bad but then I got trail grappler mt that are 285/65/18 and rubed like a mofo
