Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Oct 8, 2012 at 9:57 AM
    #1561
    YotaCrazy
    YotaCrazy Member
    Travis
    Dothan, AL
    08 PreRunner SR5 TRD off road
    I have a few questions because Im a little confused on spindles , okay, well i have toytec coil spacers in the front and i think a 1 inch block in the back and im running 285/75R16 MT's and i didnt have to do any trimming so why would you have to do any trimming with a spindle lift ? and also im looking in to a spindle lift can i combine the two to get a 6 inch lift and would 33's look fine with that set up?
  2. Oct 8, 2012 at 1:00 PM
    #1562
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    The reason they rub is due to the fact that the spindles make the tires stick out farther. Also I used to have the toytec spacer as well and the spindles with a 4" block in rear...rode like shit but it does work. Now im using 5100s at .85" with 1.6" eibachs and 1.5" aal and 2" block. So I'm right at 6.45" in front and 3.5" in rear. I'm running 33x12.50s as I felt like the 285s looked to skinny. Check out my build page for pics!
  3. Oct 8, 2012 at 1:05 PM
    #1563
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Got a picture of your setup? Kind of hard to believe you didn't have to trim anything. Unless, you just rub like crazy and that doesn't bother you? Either way, I would like to see pics of your setup....
  4. Oct 8, 2012 at 6:06 PM
    #1564
    YotaCrazy
    YotaCrazy Member
    Travis
    Dothan, AL
    i would , but i dont know how to add a picture and i have no rubbing what so ever expect a small bit at full lock and i also still have the mud flaps on. so if i kept the coil spacer and got the spindle lift and got 33/12.50R17 it wouldnt look like to small of a tire?
  5. Oct 8, 2012 at 6:08 PM
    #1565
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    no...and yes you can use a spindle in combo to whatever you want.....
  6. Oct 8, 2012 at 6:18 PM
    #1566
    YotaCrazy
    YotaCrazy Member
    Travis
    Dothan, AL
  7. Oct 8, 2012 at 6:37 PM
    #1567
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    You have little rubbing becAuse you're running stock backspacing wheels. With spindles, not only will they make your front tires stick out further(causing a larger area in the wheel well to turn the tire), but you cannot run stock wheels withoit spacers, causing them to stick out even further again.
  8. Oct 8, 2012 at 6:44 PM
    #1568
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Why do people set the 5100's to .85 if the spindle gives you 4" lift?
  9. Oct 8, 2012 at 6:45 PM
    #1569
    anthony250f
    Anthony
    San Diego, CA
    more lift
  10. Oct 8, 2012 at 6:46 PM
    #1570
    YotaMatt
    West Point VA
    To get even more lift...i wanted a 6" lift but didnt want a drop bracket lift. So with the spindles 4" and the bilsteins at .85" plus my 1.6" eibachs i achieved the look i wanted and the ride as well :cool:
  11. Oct 8, 2012 at 6:48 PM
    #1571
    GREEKBOY12295
    Nick
    Phoenix, AZ
    Oh ok cool. Thanks guys
  12. Oct 12, 2012 at 4:04 PM
    #1572
    HanleesTacoma
    HanleesTacoma Well-Known Member
    NorCal
    2013 MGM Prerunner V6 SR5
    Window Deflectors with (Tacoma) Logo Visor Yakima Locking Bike Rack Mount N-Fab Nerf drop step bars 2" tube Powder-coated Black 4" Maxtrac Spindles Steel braided extended (front) brake lines Bilstein 5100 Adjustable Front Shocks 1.6" Eibach Coil Springs 3-4" Bilstein 5100 Extended Rear Shocks 2" Toytec Progressive 3 Leaf AAL (made by Deaver Leaf Springs) 2" Rear Blocks Steel braided extended (rear) brake lines 1.5" rear wheel spacers Black TRD NORCAL Bedside Vinly Stickers from Sockeye Monkey 10g Powder-coated BLACK Skid Plate with TRD Logo from Matt123 (Black) Plastidip emblems Go Rhino Xtreme Rack Sport Bar Lightning Series (Black) 4" 18watt CREE LED Flood/Spot LED Work light (x4) Powerbass BTA8 150W 8" bass tube with built-in amp plus remote control 32" 180W CREE LED Bumper Light Bar Flood/Spot combo Bully Matte Black Exhaust Tip. Inlet diameter: 2.875", Outlet diameter:3.75", length 9" Redline Hood Struts (Black) Plus kit True Edge (Black) Riveted Textured Fender Flares
    Followed your build tread..awesome man!!. I think I'm going with the 6" lift as well.
  13. Oct 12, 2012 at 5:36 PM
    #1573
    YotaMatt
    West Point VA
    Thanks man!! You'll love it..rides great, towers other tacomas, and tons of ground clearance
  14. Oct 12, 2012 at 6:48 PM
    #1574
    HanleesTacoma
    NorCal
    I'm going to pattern my build to yours if you don't mind bro..so what's your estimate cost for the suspension set up,wheels/tires with rear spacers?
  15. Oct 13, 2012 at 6:39 AM
    #1575
    YotaMatt
    West Point VA
    I picked up the 5100s and eibachs for 200$ from a local member. The spindles and extended brake lines were 485$ on the group buy. 1.5" aal was like 70$ and 1.5" block and u bolt kit was around 50$. The rear brake lines were 75$
    I think. Wheels were around 600$ and I traded my 285 trail grapplers to a guy for the mud grapplers.
  16. Oct 13, 2012 at 11:07 AM
    #1576
    HanleesTacoma
    NorCal
    Wow you did good bro!!. This is absolutely an awesome build without putting a big dent on the budget. Gives me a idea how and where to start. Thanks for the info!
  17. Oct 13, 2012 at 12:04 PM
    #1577
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Hey are you still in? HMC?
  18. Oct 13, 2012 at 3:31 PM
    #1578
    HanleesTacoma
    NorCal
    Just retired a few months ago..how bout you?. on AD status?
  19. Oct 13, 2012 at 6:57 PM
    #1579
    YotaMatt
    West Point VA
    No problem...enjoy!!! I've only just begun!!!
  20. Oct 13, 2012 at 8:13 PM
    #1580
    HanleesTacoma
    NorCal
    Thanks!!. Gtg.
