Maxtrac Spindle Lift for 2nd Gen Prerunners
Discussion in 'Suspension' started by markmatters, Feb 11, 2012.
  1. Jan 27, 2013 at 7:41 PM
    #1901
    YotaMatt
    YotaMatt Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Yep. ..matches almost perfect I think
  2. Feb 2, 2013 at 2:43 PM
    #1902
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Is there a how to thread on installing all pro leafs or leafs in general? I bought some last night.
  3. Feb 3, 2013 at 10:56 AM
    #1903
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    URGENT!!
    Anybody have a set of stock 2nd gen spindles they are willing to give or sell to a fellow TW member?? My friend Kenny (krans on TW) bent his driver side spindle the other night and is in desperate need of replacing it. He cannot drive the truck and has to go to work tomorrow.
    If you have a set, I can use the passenger side. Please call/text/PM if you have a set lying around. We are both located in OC, and will drive to neighboring counties to pick up at your convenience! Thank you!
  4. Feb 3, 2013 at 6:51 PM
    #1904
    Dylanmoore13
    Dylanmoore13 New Member
    Dylan
    Chattanooga, TN
    will i need wheel spacers all around or just the rear if i do a spindle lift ? will it look weird from the back without them?
  5. Feb 3, 2013 at 7:10 PM
    #1905
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    If you are running stock rims you will need spacers up front. The spindles will kick your front out 3/4" per side...
  6. Feb 4, 2013 at 7:10 AM
    #1906
    TX SR5
    TX SR5 Member
    Kevin
    HTX
    06 Prerunner
    Exterior: -fiberglass fenders front/rear -satoshi grill -scooped hood -black housing headlights -retro fit -black housing led tail lights -led daytime running lights -led reverse lights Suspension: -Maxtrac spindles -crown extended brake lines -total chaos alignment tabs -Bilstein 5100's front set at 2nch notch -rear fox 2.0's -ome dakar leaf springs Wheels & Tires: -16" Method Racewheels -315/75/16 cooper at/s -slotted and drilled rotors -allpro 1.25" wheel spacers Engine/Exhaust/Bolt on's: -Afe exhaust dumped before axle -K&N cold air intake -Air aid throttle body spacer -URD maf calibrator -Scan gauge II Interior: -black seat covers -weather tech floor mats -2 10" subs behind back seats -pioneer double din -black headliner -rhino lined interior pieces -led dom lights etc. Armor: -Trail Gear Low pro front bumper and custom rear bumper i made -21" single row led light bar
    i just bought the maxtrac spindles, im running 5100's all around. the front is the 5100's set at 0 with ome 885's, rear is the ome dakar leaf pack, do you guys think it will be level or no? please let me know!!!!
    thanks in advance!
  7. Feb 4, 2013 at 3:12 PM
    #1907
    Dylanmoore13
    Dylan
    Chattanooga, TN
    i was planning on running these tires either the 285's or 295's which would look better?
    http://www.treaddepot.com/tire/b77118.html http://www.treaddepot.com/tire/b92042.html
    and these wheels (16-8) but what would i need the backspacing and the offset to be?
    http://www.treaddepot.com/wheelsizes/h791b.html
    would this add a leaf work? is says.... ** SOME Tacoma models with a total of 4 leafs (3 main leafs, 1 overload) in the rear leaf pack require our TSB AAL- Part # TAC-AL-TSB. Please count how many leafs you have before ordering **
    how do i know how many leafs i have my tacoma is a 2008 double cab trd off road
  8. Feb 5, 2013 at 11:02 AM
    #1908
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    I just bought a set of Maxtrac Spindles I already have a rear add a leaf will i still need a block in the back?
  9. Feb 5, 2013 at 11:04 AM
    #1909
    YotaMatt
    West Point VA
    what do you have up front now?
  10. Feb 5, 2013 at 11:24 AM
    #1910
    SaraLynn44
    Sara Lynn
    Fresno CA
    08 PreRunner
    Piece of shit spacers... I have a slight front lean i wont mind a slight bro lean but i dont want it to look retarded...
  11. Feb 5, 2013 at 11:26 AM
    #1911
    YotaMatt
    West Point VA
    if your removing the spacers and running spindles only then it will be pretty level, may sit a little front high but no big deal..if you leave the "shitty" spacers then you will need to add a block as well or you will be REALLY front high...
  12. Feb 5, 2013 at 11:32 AM
    #1912
    SaraLynn44
    Sara Lynn
    Fresno CA
    08 PreRunner
    No im ditching the spacers.... well now im not too worried about it lol thanks
  13. Feb 5, 2013 at 11:35 AM
    #1913
    YotaMatt
    West Point VA
    no problem..love the new wheels and tires btw..looks alot more aggressive :cool:
  14. Feb 5, 2013 at 11:48 AM
    #1914
    SaraLynn44
    Sara Lynn
    Fresno CA
    08 PreRunner
    Thanks thats more what i was going for... :D I hated the way it looked before...
  15. Feb 7, 2013 at 4:39 PM
    #1915
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Anyone have rust problems with these? Anyone throw a coat of paint on them prior to install? And how much do they weigh? Thanks
  16. Feb 7, 2013 at 4:47 PM
    #1916
    YotaMatt
    West Point VA
    Heavy lol..but beefy...paint them or at least clear them like o did
  17. Feb 7, 2013 at 9:19 PM
    #1917
    jr114
    Jon
    SoCal
    Truck
    Can anyone confirm if these work with the Icon tubular uniball UCA's?
  18. Feb 8, 2013 at 8:23 AM
    #1918
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
    Yes they will work great
  19. Feb 8, 2013 at 6:25 PM
    #1919
    jr114
    Jon
    SoCal
    Truck
    Anyone in the Torrance/South Bay area install these on their own? Would anyone be willing to help if I order them?
  20. Feb 8, 2013 at 7:06 PM
    #1920
    jr114
    Jon
    SoCal
    Truck
    Shit well I just ordered them from Bytor. Haha. Can finally dial down the preload on my coilovers once they get here. Now just need to figure out the install.
