Measurements for lifting: Center hub to fender vs. ground to fender
Discussion in 'Suspension' started by Bishop2Queens6, Oct 21, 2012.
What do you use to take your lift measurements??
Poll closed Nov 20, 2012.
  1. Center hub to fender
    6 vote(s)
    100.0%
  2. Ground to fender
    0 vote(s)
    0.0%
  1. Oct 21, 2012 at 10:46 PM
    Bishop2Queens6
    Bishop2Queens6 [OP] Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I have always heard that measuring from the center of your hub to the fender is the correct way to take before and after measurements for your lift, but why?
    Assuming:
    -Full weight of the vehicle is on the suspension
    -Truck is on level ground
    -You take before and after measurements at the same location
    How does it make any difference than measuring from the ground to the fender?
    Can someone please enlighten me?
  2. Oct 21, 2012 at 10:49 PM
    scocar
    scocar hypotenoper
    Measuring from the hub allows you to isolate the lift created by the suspension alone, rather than mixing in the tire size, which is what happens when you measure from the ground.
  3. Oct 21, 2012 at 10:51 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    well tire air pressure as an effect on it as well. soo when you take measurements say before you may have higher PSI than when you take them after. or the 2 days/times of day may have a bit tempter difference. temp plays a roll in air pressure.
  4. Oct 21, 2012 at 10:52 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    This
    hub to fender measurements exclude tire size
  5. Oct 21, 2012 at 10:54 PM
    scocar
    scocar hypotenoper
    Very concise. I bet you were a valedictorian once. Golf clap.
  6. Oct 21, 2012 at 10:55 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Could have said it better myself
  7. Oct 21, 2012 at 10:57 PM
    scocar
    scocar hypotenoper
    Go for it.
    Tyres, etc.
  8. Oct 21, 2012 at 10:57 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    well than say it better. :p how would you say it eh?
  9. Oct 21, 2012 at 10:58 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    damn it you beat me.
  10. Oct 21, 2012 at 10:59 PM
    OZ-T
    Peter North
    British Columbia
    :yawn:
    㘑以報嵃範乂幾務軟
    垧脆
    熘㙓去處
  11. Oct 21, 2012 at 11:01 PM
    scocar
    scocar hypotenoper
    You've been assimilated.
  12. Oct 22, 2012 at 10:09 AM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Damn. You guys are smart. I didn't even consider the tire size or variability in tire pressure causing the variance in measurements over the day.
    I'll do center hub to fender then.
  13. Oct 22, 2012 at 10:21 AM
    scocar
    scocar hypotenoper
    Both have a purpose. Overall lift including tires will give you your actual ground clearance over obstacles, especially at the rear diff, your lowest point. But when determining how much lift you gain from suspension modification, you need to go from the hub.
    I wouldn't worry too much about tire pressure unless you are airing down a ton for serious crawling (and have the tires that can handle that). A full tank of gas and your own fat ass (not that that's bad thing) can have more affect. So can lots of tools and equipment. These all increase the force of gravity locally.
  14. Apr 3, 2014 at 8:08 PM
    RNGRCaldera
    RNGRCaldera Well-Known Member
    Georgia
    14 AC TRD
    off road tires,toolbox, tinted window,Allpro Apex bumper, Toytec 3" suspension lift, Cb radio and firestik, 20" light bar.
    what should the measurements be for a 3" lift kit?
  15. Apr 3, 2014 at 8:13 PM
    OZ-T
    Peter North
    British Columbia
    3" more than the before measurements
