Measurements needed - 2nd gen 4 cyl
Discussion in '4 Cylinder' started by T4RFTMFW, Jan 28, 2015.
  1. Jan 28, 2015 at 2:03 PM
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Anybody have a front and rear hub to fender measurement for a 4 cyl DCSB, 2nd gen PreRunner?
    Mucho appreciated.
  2. Jan 28, 2015 at 7:49 PM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    I currently have about 400 lbs in the bed, I could go get the measurement but it would probably be off(let me know if you want that number too), if nobody else responds on this by Saturday, I can get you an unloaded measurement, that's when I'm dropping this load off.
  3. Jan 28, 2015 at 8:21 PM
    T4RFTMFW
    Saturdays good! Thanks bro.
    You stock config? Wheels and tires, suspension?
  4. Jan 29, 2015 at 4:24 AM
    gazingwa
    Yes, 2,200 miles on it, stock everything, steel wheels.
  5. Jan 29, 2015 at 9:17 AM
    T4RFTMFW
    :woot:
    Thanks bro!
  6. Jan 29, 2015 at 9:32 AM
    gazingwa
    No problem. to hold you over
    With 400lbs of wood pellets in the bed
    Center of hub to fender
    F: 21"
    R: 20.75"
  7. Jan 29, 2015 at 9:36 AM
    T4RFTMFW
    Sounds about right. Reason I'm asking, I didn't bother to measure before installing anything, so I'm not sure how much lift I'm seeing on my setup. Just trying to ballpark. My front with .85 of preload is 22" and my rear with possible 1.5-2" of lift is 23.5" unloaded.
  8. Jan 30, 2015 at 2:48 PM
    gazingwa
    Unloaded w/ a half tank of gas
    F: 20.5
    R: 21.5
  9. Jan 30, 2015 at 9:35 PM
    T4RFTMFW
    Great, thanks bro.
    RyRy, less than 90 of my truck in the entire state of CA IIRC. If it was that easy, I'd do it. ;)
