Mechanic says he isn't able to adjust caster/ camber on alignment
Discussion in 'Suspension' started by mr05taco, Mar 18, 2014.
  1. Mar 18, 2014 at 3:18 PM
    mr05taco
    mr05taco [OP] Well-Known Member
    South Jersey
    I just put my lift on last week, and took my truck to a family friend/ mechanic to get aligned. When I picked it up, he said there was no way to adjust the camber or caster... Is this b.s.? Here's the sheet he gave me:
  2. Mar 18, 2014 at 3:20 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Alignment cams could be seized , common problem
  3. Mar 18, 2014 at 3:29 PM
    mr05taco
    South Jersey
    Do you think I'm going to wear out my tires with it out of spec that much?
  4. Mar 18, 2014 at 4:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    With +1.4 deg of camber, the tires will see faster outer shoulder wear than normal, but probably no worse compared to those German SUVs, which run a lot of negative camber from the factory:
    If you don't want to replace the seized alignment cams, you'll have to religiously rotate the tires front-back at every oil change to slow down the wear.
  5. Mar 18, 2014 at 4:13 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    x2
  6. Mar 18, 2014 at 6:15 PM
    mr05taco
    South Jersey
    Thanks guys. Would you recommend replacing the cams then? I was planning on getting 33's soon but I don't want to spend the money on new tires if I'm just going to wear them prematurely
  7. Mar 18, 2014 at 6:25 PM
    T-Rex266
    Elon
    My OCD in me says yes.
  8. Mar 18, 2014 at 6:48 PM
    KenLyns
    Belly of the Beast
    Yes. Moog sells cams with a greasing channel, so you can grease up the new cams on installation and periodically pump in more grease, to prevent seizures in the future.
  9. Mar 18, 2014 at 6:54 PM
    OZ-T
    Peter North
    British Columbia
